Question about Singer 9960 Quantum Stylist Sewing Machine
Makes one stitch then abrupt stop with threads bunching up from bottom
I am an amature sewer at best, and last night I began a project on a Hexi quilt. I had over stitched and used the hand wheel to go back on space. I had forgotten to take out the slack with the thread and back stitched with the machine. In doing so, the thread became all bunched up and the needle jammed. I cleared the thread but each time I try to sew it takes one stitch (almost) and the machine again jams up. I have changed needles, cleaned any lint in the machine with canned air. I watched the video on you tube for "fixing a top load bobbin" that was posted on a similar post on this site, but I am not sure what I need to do. I appriciate any help very much! Thank you in advance!
  • 27 Answers
Have you taken the bobbin out and made sure there is nothing caught in the bobbin race area. Maybe even unscrew the plate and take the whole bobbin race assembly apart and clean well. Once that is done put back together then re thread machine. Next I would start by hand turning the machine and doing some stitches slowly with the fly wheel make sure to to forwards only never turn the fly wheel back wards. If everything seems clear give it some power slowly and see how it goes.
Posted on Feb 13, 2014
5 Suggested Answers
kent581
  • 87 Answers
SOURCE: bottom of stitch is bunched with alot of thread and machine jams
Try these time savers:
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test, then let me know, we can go to step 2. If not, try different spool of thread, same test until you get a smooth pull (tip: always check your thread this way when you thread your machine)
Step 2:
Pull on your threaded bobbin thread while it’s in the machine. Does it pull smooth and even? If so, go to step 3. If not, try a new bobbin (bobbins get bent or distorted if wound too tight).
Clean thoroughly in the hook and bobbin case area and oil 1-2 drop is all.
Posted on Mar 18, 2009
  • 96 Answers
SOURCE: Jamming brand new machine
the tension on the bobbin case needs to be adjusted to needle size and type of fabric the medium fabrics usually use a size 11, light fabrics need a size 9 and heavy like ( corduroy denim or upholstery fabric needs a 14 or 16 Heavy fabrics need a little less tension on the top side so it will feed properly just play with it until it looks good on a scrap of the same fabric
Posted on Dec 13, 2009
  • 460 Answers
SOURCE: sewing machine will not stitch.
Is this the first time you have used the machine? If so you need to bring up the bobbin thread by hand before stitching. Only when both bobbin and top threads are up through the needle plate nad pulled towards the back of machine, will the machine form a stitch.
Posted on Dec 17, 2010
  • 6 Answers
SOURCE: Bobbin thread will not stitch.
I had Singer Sewing Maching which was supposed to make different stitches. It had an electric motor, legs, cabinet with drawers & legs. For 20 years this machine never worked. Warranty & servicing made no difference. The thread would not come up from the bobbin or it would come in bunches or the thread would keep breaking (Ameto threads used, same in bobbin). The retailer from whom the machine was purchased sent mechanics to adjust tension, change needles, threads, oiling, cleaning etc but it never worked. We always used our neighbor's sewing machines or gave our clothes to the tailors. Whilst moving home we threw it. People saw the brand name & didn't even pick it up for free.
Posted on Jul 24, 2013
The lower thread on this machine continues to bunch up, no matter what we try.
Please check whether it is the bobbin thread or the top thread that is messing up. If it's under the fabric, it is 99% the top thread and is called bird nesting or thread nesting.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Also check that the bobbin is loaded and turning the correct direction in the bobbin case.
Now, retest the machine.
You may need to tweak the tension to get it where it looks best.
Jul 25, 2017 | Euro-Pro Sewing Machines
Thread on the bottom side of stitch is all bunched up
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Oct 09, 2012 | Sewing Machines
Thread keeps on bunching up on the bottom side of the fabric
try changing the needle
check the top thread tension to make sure it's not to loose
rethread the machine top & bobbin, make sure the bobbin is wound
correctly & inserted correctly into the machine
Jul 11, 2012 | Brother CS6000i Computerized Sewing...
How do you stop stitches bunching up on a Singer Symphonie?
also try changing the top tension
clean under the needle plate & in the bobbin area for lint or loose threads
Apr 21, 2012 | Singer Sewing Machines
When "locking " a stitch, bottom thread breaks and/ or bunches up.
Make sure you hold thread in back of the lowered presser foot when you begin stitching, and that the needle is piercing the fabric so that the fabric isn't slipping down into the feed dogs (under needle plate area).Hope this helps you out,alexlefebvre.Jimmy
Apr 12, 2012 | Sewing Machines
Sewing a bunch of thread from the bottom, this stops the machine from actually sewing
Yes, it does. There are a couple of reasons the bobbin thread could be bunching up on the underside of the fabric. It could simply be that the machine needs cleaning. Take the bobbin assembly out, brush all the old lint out as best you can, reoil the machine once it's all clean, and make sure there aren't any little bits of thread caught in the bobbin assembly. Rethread the machine (carefully) and change the needle. This solves the problem usually--especially if the machine was sewing along fine and the problem develops suddenly. '
The other thing to check is your tension. It could be that the top tension is too loose. But different color thread in the top and in the bobbin, stitch a few inches (be sure to held the top and bobbin thread ends behind your needle as you start to stitch) and check. WIth the pressure foot down, adjust the tension, and stitch again. Keep stitching, checking, and adjusting until you see little if any bobbin thread on the top or top thread on the bobbin.
Another thing to reminder: use the appropriate thread and needle for the fabric you're sewing.
Let me know if this works, ok?
Robbie
Jan 31, 2010 | Elna Sewing Machines
I have a Singer Sewing Machine 5817C, the thread bunches under the fabric while sewing. I have tried adjusting all the switches so that I just get a standard straight stitch, but it bunches up on the...
Make sure that there is tension on the thread when you have passed it through the tension unit, by making sure the presser foot is down, and then gently pulling the thread to feel tension. If there is no tension, as seems to be the case, check the tension discs inside the unit to make sure that there is no debris stopping them from closing.
Oct 14, 2009 | Singer Sewing Machines
Amatur Sewer?threads tangled below
Stop sewing! You need to adjust your tension. Your book will explain exactly how to do this. If you can't find your book, try setting the tensions to the same number. If your tension adjustments have a mark at a certain number, use that setting for most materials. If not, try setting it to about 3.
To test your settings, thread your bobbin with a different color, then do a test stitch. Check the top and bottom stitches for a spot of the other color thread showing through. If the bobbin thread shows in the top, raise the bobbin tension setting a bit and try it again.
Hope this FixesYa!
Aug 11, 2008 | Singer 3116 Simple
Bobbin thread bunching
Remove your needle plate, and take out the black bobincase. Check the edges on the black bobbincase for scratches or damages. The upper tread should glide smootly around the upper edge of this bobbincase.
If you find any scratches, you may use a very fine sandpaper/grindingpaper (not shure what you call this in english) to remove the scratches.
Feb 20, 2008 | Janome Memory Craft 4000 Sewing Machine
Singer 9960 Quantum Stylist Sewing Machine Logo
156 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
