Question about Shark Handheld Vacuum Cleaner SV75SP
Burning Smell It is about one moth old and has worked great. It just started to have a burning smell after it's on for a few minutes. Is the motor burning up?
The motor in the Kenmore canister started smelling like wire burning and then made terrible noise. I ordered the exact replacement motor and swapped them. Installed the same way the original came out, ran...
Actually there not supposed to burn up. I have read some reviews on that model Kenmore and it seems it is plagued by electrical problems.
I would definitely contact Sears customer service.
Sorry I couldn't be of more help.
Handie Andie
Mar 30, 2011 | Kenmore 25512/ 25513 Progressive Canister...
My vacuum was working fine, then started to smell a little funny like something was burning. Turned it off. Now when you turn it on it will run for a few minutes and then shuts off, like something is...
The smell is usually the fan belt. When the brush is stuck in place, the belt spins and burns. Check to see if the brush is free to spin. If the Belt is burnt, it needs to be replaced.
Jan 31, 2018 | Kenmore 28015 Bagged Canister Vacuum
Burning smell kenmore canister
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Mar 04, 2009 | Kenmore Vacuums
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Hoover only two years old an stopped working!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=564949
Hoover only two years old and it stopped working!
Posted by baby_nurse on May 02, 2008
My Hoover self propelled wind tunnel was working great until a couple of days ago when it started shutting on and off while vacuuming. I thought it was the outlet but when I plugged it into two different outlets it did the same thing. Then finally yesterday it just stopped working it won't even turn on when plugged in. I thought it was the switch but it is not. Is it the motor? Has the motor burned out? Do I need to buy a new one? Help!!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover U6616-900 WindTunnel Bagless...
Motor or pump problem?
my guess is you burned out the motor. go to thehooverstore site. look for your machine. they have a parts list for just about any hoover made.
Sep 07, 2007 | Hoover F6020-900 SteamVac Upright Vacuum
Shark Handheld Vacuum Cleaner SV75SP Logo
14 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
