Question about Frigidaire Dryers
I have a Friguidaire Dryer Model AEQ6000ES2. This Dryer runs only at the low heat control area (Delicate). Sometimes the Dryer, Cool Down, and Extended Tumble lights all flash. Replaced the High Limit
The lights would flash and there is no Error message. Can clear the lights with Select/Clear buttons.
godtech
  • 51 Answers
SOURCE: i need a wiring diagram for a hotpoint tumble dryer model vtd00
CALL 1-800-626-2005 ALSO CHECK THEIR WEB PAGE WWW.HOTPOINT.COM
Posted on Jan 16, 2009
  • 4 Answers
SOURCE: dryer keeps shutting off
maybe there is a sensor or a thermostate in it? check owners manual or call the company? just a thought.
Posted on Apr 23, 2009
  • 1531 Answers
SOURCE: Not Heating
there could be a problem with one of the thermal fuses located in the cabinet under the drum and along the side of the heating element can. the first one to check is the one furthest back on the can.
you can check them all for continuity and replace the one that is bad also check the heating element last.
Posted on Feb 23, 2010
TheMobilian
  • 8220 Answers
SOURCE: dryer heats and then sometimes
The cycling thermostat there on the blower housing have you replaced it?
And you know you have 240 going into the machine? The motor runs on 120 but the heater needs 240 to work. A weak breaker can cause some heating failure:
If the heater is fine and the components are good you might want to take a look at the timer. This one is fairly easy to fix.
Take you time and put her back together.
You might can get a few more years out of the old girl.
I have GE repair photos and video here
Posted on Feb 12, 2011
kvhappliance
  • 218 Answers
SOURCE: I have a Kenmore series
Blown high limit fusees can be caused by.
  1. Not enough airflow caused by blockage in the exhaust vent pipe.(most common) Check for strong airflow coming out of the back of machine, then check for good airflow at exterior vent. Clean vent if airflow is restricted.
  2. Bad drum seal
  3. Dirty lint screen
  4. Broken blower wheel
  5. Blockage inside the machine.
Posted on Jul 19, 2011
How to fix Maytag dryer MED9600SQ0
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum 9 this is why in some cases the dryer will operate at lower cycles like gentle or low heat but not at higher settings?)
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jan 26, 2016 | Maytag Dryers
What does area Error code E-05 mean on a Frigidaire front load dryer model # AEQ6000ES2
model aeq6000es2: the "e05" error code normally indicates that control board may need to be replaced or a stuck relay on the control panel. you can reset the unit by unplugging the dryer power cord for 5 minutes and then reapplying the power. if the problem persists then the control board or the control panel may need to be at fault.
Good Luck & All The Best, Justin McCartney
Dec 26, 2015 | Frigidaire Dryers
Maytag DE810 Dryer takes too long to dry
Have you checked the Hose and the pipe that exits your wall? Sometimes birds will nest in them. Pull the dryer out and run it without the hose connected to test it.
May 18, 2015 | Dryers
I have a Kenmore 64812 (110-64812200) electric dryer that produces a high heat at every temperature level, even "delicate/cool" is hot. With two thermostats and a fuse, what could be broken first?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Thermostat is bad...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 05, 2010 | Kenmore 64812 Electric Dryer
Affinity aeq6000es2. After two cycles of the
sounds like your heating element opened up,as it was running and when the element broke it arced and these were the sparks you saw,you will need a new heater element
Jul 19, 2010 | Frigidaire Dryers
My Frigidaire Dryer (AEQ6000ES2) won't heat. Did
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. The E56 error code means high motor current. To help you find out why, I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. You can probably verify the meaning of the error code there. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 26, 2009 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire Dryer Error E 04
I have the same problem. Does anyone have an answer?
Jul 26, 2009 | Frigidaire Affinity ATF7000E Front Load...
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
Dryer runs & heats but shuts off after 3-10 minutes
the motor overload can caouse that problem in that case new motor is needed if the dryer turn right back on after it turns off the even heat control board in panel bad if it humms are no noise after turn off and you have to let cool down the motor is the problem
Feb 28, 2008 | Kenmore 64952 Electric Dryer
Dryers Logo
24 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
