Question about Sylvania 6632LCT 32 in. LCD Television
The power won't come on my Sylvania 6632LCT 32 in LCD tv
The manual said to unplug the power cord but I can't find it?
  • 4090 Answers
SOURCE: Sylvania LC320SS8 32 in. LCD Television Hi my
The light staying on is afterburn or power stored in a capacitor to start up the solenoid.
The protection circuit has been invoked to protect other components from being burned out. This unit needs professional intervention.
Unplugging and leaving for a few hours will not fix it it will merely delay the inevitable.I suggest it is taken for repair ASAP and refrain from trying to run it to prevent major damage or even fire.
Please remember to rate our help++++Thanks for using FIXYA
Posted on Oct 11, 2009
Testimonial: "thank you for the advise keep up the good work"
dave1645
  • 834 Answers
SOURCE: how can I change NTSC tuner to PAL tuner of Sylvania 6632LCT TV
i did some rearch on that /and it cannot be done without changing the complete mainboard
Posted on Dec 07, 2009
  • 139 Answers
SOURCE: vertical lines in my sylvania lcd tv
They go away after 10 minutes of what? **** She Wrote? Dancing with the Stars? Or simply being powered On? You have some cold solder joints on one of the PCB boards. Once they heat up they work perfectly. The only way to fix this is to have them reflowed by a tech with a soldering tool or have the board replaced. Good luck! Cheers
Posted on Dec 29, 2009
  • 8457 Answers
SOURCE: Sylvania 6632LCT 32" the bottom
Vertical colors bars appearing and disappering are the causes by the board that call the T-CON board it is dying or the fiber optic cable that connected to it lose or damages internally.Mostly of the times about 99% of the times the T-CON board it is dying and it is not decodering pixels codes correctly anymore before it send those pictures pixels codes to the tv LCD screen panel.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a new refurbish T-CON board for the replacement.
Posted on Jun 29, 2011
gopakumarg43
  • 75289 Answers
SOURCE: I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Posted on Sep 29, 2011
Sylvania HDTV Model LC370SS8 won't turn on.
u should check std-by volt .when u press power on , the power on volt must not b drop
Oct 09, 2012 | Sylvania LC320SS8 32 in. LCD Television
Jun 29, 2011 | Sylvania 6632LCT 32 in. LCD Television
I recently dropped my remote control on the floor. Somehow this caused my 32 in. Sylvania 6637LCT television set to go into service mode. I called Sylvania and they told me to buy a new remote. Only after...
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 09, 2017 | Sylvania 6632LCT 32 in. LCD Television
SYLVANIA 6632LG its turns on everything works then when i turn it off and turn it back on it shows green light then red light. but if i unplug main board or inverter board and plug in in and turn power tv...
First, it does not make sense if you unplug the main board from the power supply and the TV comes on, please verify which connectors that you unplug. I would unplug the inverter board power connector to see if the 24vdc and 12vdc will work porperly first.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Aug 28, 2010 | Sylvania 6632LCT 32 in. LCD Television
How to get rca tv out of standby mode
Try tv unplug,replug an hour later.The tv should reset it self and work.Not,than the power supply board is the cause,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Aug 27, 2010 | Sylvania LC320SS8 32 in. LCD Television
How can I change NTSC tuner to PAL tuner of Sylvania 6632LCT TV
Dec 07, 2009 | Sylvania 6632LCT 32 in. LCD Television
Oct 11, 2009 | Sylvania LC320SS8 32 in. LCD Television
Sylvania plazma tv-forgot unlock code?
According to the manual, you should unplug the TV for 10 seconds and replug it in, password should reset to 0000.
Oct 03, 2009 | Sylvania LC320SS8 32 in. LCD Television
Desconectar
Decime el modelo de tu televisor tiene que ser un numero como este
Sylvania SST4324S 32"
Sylvania SST4324A 32"
Sylvania SST4324 32"
Sylvania SST4323 32"
Sylvania SST4322 32"
Sylvania SRT2432S 32"
Sylvania SRT2432P 32"
Sylvania SRT2323 23"
Sylvania SRT2232X 32"
Sylvania SRT2232S 32"
Sylvania RSET432E 32"
Sylvania RSDCT3203 32"
Sylvania LD320SS8 32"
Sylvania LC320SS8 32"
Sylvania C6432TE 32"
Sylvania C6432TD 32"
Sylvania 6632LG 32"
Sylvania 6432TFY 32"
Sylvania 6432TF 32"
Sylvania 6432TE 32"
Sylvania 6432TD 32"
Sylvania 6432GG 32"
Sylvania 6432FE 32"
Oct 19, 2008 | Air Tools & Compressors
Sylvania 6632LCT 32 in. LCD Television Logo
22 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
