Question about Royal 160MX Shredder
Paper has filled up the spaces between the gears in some spots so that even one sheet of paper does not shred - it just gets holes poked in it. I have tried the usual needle nose pliers to pick out t
I thought it could be address labels making the blades sticky but my sister puts them her shredder regularly without a problem. I'm a widow with only one working hand at the moment but need to know how or if the cutting mechanism can be removed for unclogging.
  • 5 Answers
I just had mine apart yesterday to clean the paper sensor and remove some paper that fed the wrong way. First unplug the unit. Tools needed Philips screw driver and needle nose. Remove the paper bin and put the shredder on its back then remove 4 screws that hold the base cabinet to the top.Once you have the top off put the top upside down on the floor / table. There are 6 screws that hold the top together. Be careful of the wires for the bin full and bin in place sensors that connect between the bottom and top half's. You can gently lift the bottom up and swing it away to access the cutters. From here you should be able to clean most of the paper. The cutter assembly isn't screwed in but has some wires that will have to be removed if you need to remove the cutter assembly. Also there is lots of grease on the cutter assembly so be careful of where you touch.
Posted on Feb 12, 2014
5 Suggested Answers
  • 35 Answers
SOURCE: My shredder keeps running and won't stop in on/auto mode
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Posted on Mar 03, 2009
FixinFax
  • 3085 Answers
SOURCE: Royal 10x Crosscut Paper Shredder (PCUA: 29054E) paper jams.
Try soaking the cutters with soapy water, yes it works. Oil after you are done.
Posted on Aug 02, 2009
  • 1218 Answers
SOURCE: Royal VF 1000, overloads with one sheet of paper
Try pouring some shredder oil into the cutting blades where you insert the paper then run the unit in reverse for a while. Then put some of the shredder oil onto a sheet of paper and try shredding the sheet of paper. Some lubrication on a x-cut shredder does not hurt.
Posted on Sep 05, 2010
  • 1218 Answers
SOURCE: ROYAL RL170MX Shredder won't shred
Did you ever put shredder oil onto the cutting blades?????
The blades can clog with paper dust and then it can't shred as many papges as it should or even jam completely...you should occasionally shred a sheet of paper with shredder oil poured onto the sheet.
Posted on Sep 06, 2010
When you insert the paper the shredder is only cutting the outside edges, the middle part comes out crimpled but still in tact.
The center cutting blades end up cutting more paper than the ones on the edges. It could be they are just dull.
Shredders are supposed to be lubricated with a special oil. If not available, some manufacturers will recommend vegetable oil.
I just put some on a couple of sheets of paper, and shred them. This is supposed to be done on a regular basis.
If items that are sticky have been shredded, the spaces between the cutters could be filled up. Some envelopes are padded with. Thin bubble wrap. That stuff will mess up a shredder.
May 20, 2016 | Shredder Office Equipment & Supplies
My ativa 12 x-cut paper shredder runs for 1/2 sheet then stops. how would you identify problem and fix it
The sheet detector may be malfunctioning. Your shredder may have to be cleaned to restore proper operation. Mine gets clogged periodically and has to have the bin removed so the entire shredder can be turned upside down to perform dental hygiene on the teeth. Paper shreds even get jammed in the spaces between the teeth. Flossing doesn't help!
Mar 07, 2015 | Shredder Office Equipment & Supplies
SHREDDER CONTINUALLY SAYS OVERLOAD EVEN THOUGH 2 SHEETS OF PAPER ARE INSERTED
It might need cleaning; mine had the shredded paper jammed in by cutters and some shreds got between the gears. First, try using a "cleaning sheet": a piece of paper lightly sprayed or smeared with vegetable oil or spray cooking oil. If that doesn't do fix it, the shredding mechanism, which has many parts, some of which are sharp as razors, might need to be disassembled and cleaned. Though I did that disassembly and cleaning, I would not recommend it to the casual DIY-er.
Sep 08, 2014 | Royal HG140MX Shredder
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
Why paper won't feed when shredder turns?
This may seem to simple but.......sometimes when you put too much oil into the blades through the top portion, the paper get drenched with oil and will not feed in. Plz try a few sheets or a thicker paper to push through. It may just be that simple. Good luck.
Plz N' Thnx, Bogie
Jul 11, 2014 | Fellowes DM8C Cross-Cut Shredder
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
My shredder overload light comes on immediately with only one sheet of paper inserted and it won't go.
Try running the machine in reverse and putting some shredder oil onto the cutting blades to loosen things up. Then try running the machine in the forward direction but hold the paper in the eyes but dont let it go into the shredding blades...see if it runs forward.!
If it will do this then slowly try paper 1 sheet at a time..but put some shredder oil onto the sheets of paper you are shredding.
If the overload light still comes on without even letting you shred 1 sheet of paper then you likely have another problem...maybe the motor or pcb..you can contact Royal at 1-800-524-0799 for parts assistance.
Oct 28, 2010 | Royal RS9512C Shredder
Paper getting stuck once shredded
As a test try shredding into a small box or even the cabinet itself with the bag holder and bag removed. Just to see if these are causing the problem.
The bag Full switch is activated by an arm which is pushed up by the pressure of the shredded paper in the bag as it fills.
When a sheet of paper is shredded, after the trail end of the paper goes past the "eyes" the machine should still continue to run on for a few seconds to drive the shredded paper out.
May 13, 2010 | Elcoman Kobra 300 SS4 Shredder
Aug 11, 2009 | Royal 1280MX Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Royal 160MX Shredder Logo
130 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
