Question about Breville & Sealed Bcg800xl Smart Grinder With 25 Grind Settings
Breville smart grinder does not grind course anymore?
When set to course grind it grinds way too fine. plunger on french press won`t move
EsWorld
  • 1618 Answers
SOURCE: severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
Posted on May 14, 2009
SOURCE: Why is the grind from my Breville BCG450XL in the
The Breville was designed to be used with Pressurized Portafilters, which most Home Espresso Machines have. These filters use a courser grind, so when it says Espresso on the Breville, it's really closer to Drip. The Turkish setting is barely fine enough for Espresso. There is a limiter on the Breville that prevents the user from going any finer, if you crack it open and remove the limiter, you can go as fine as the Solis. Becareful though, the burs can come so close to each other that they can chip and break.
Posted on Jul 10, 2009
SOURCE: Hi. On the Breville CG10 coffee grinder, is the
Yes, 1 is finest and 9 is coarsest.
From the manual: 8 - 9 Percolators 4.5 - 6 Espresso Machines - Steam System 3.5 - 5 Drip filter coffee makers 2.5 - 4 Espresso machines - pump system 1.5 - 2.5 Espresso machines - semi automatic pump system
Posted on Dec 28, 2010
ginko
  • 19396 Answers
SOURCE: I ground some nuts for
Hi.
The problem is not the motor.Coffee grinders must only be used with coffee. Even the beans used must be of quality suitable for the grinder. Too oily blends will result in a jammed grinder, as happened after grinding the nuts.
The repair is done disassembling the grinder, cleaning mechanics and reassembling. Unless you have disassembled a similar appliance before (eg. a blender gear box), there is a good chance that the attempt of fixing the grinder will result in more problems.
Rather than disassembling, a good alternative for the user is calling the Breville number listed on the grinder manual, and discussing repair with the manufacturer.
Regards.
Ginko.
Posted on Feb 01, 2011
  • 5 Answers
SOURCE: My grinder does not grind anymore. The machine
im only guessing here but id assume that the space between the burrs is likely controlled with a spring or something which has probably broken leaving the burrs as far apart as possible, if you gut the machine you may just be able to fix it with no parts if its simply a spring thats come off, the only other possibility i can think of is that your burrs or whatever they connect to are broken somehow, but all these are only guesses as im not familiar with your machine, my motto is if its broken you may as well pull its guts out to see if you can fix it, youve nothing to lose and youd be surprised how often it works
Posted on May 15, 2011
Why do I get lots of static electricity which causes ground coffee to spew all over the place
you are on the fine grind setting and the coffee dust is flying out? right!. change the setting to something a little more course, and empty the dust from the last grind.
Sep 01, 2014 | Breville Bcg450xl Conical Burr Grinder...
Grinder does not grind coffee properly
sounds like the motor is loosing efficiency,,,I.E. motor going out.
Jan 13, 2014 | Bodum Antigua 5670/5671 Electric Burr...
I have the saeco vienna coffee machine and lately it does not make a good coffee, it looks more like tea. I have the setting set to the strongest coffee and I also notice that the coffee grounds are really...
You can remove top panel and find the grinder.
Remove the limit lock screw and udjust in more fine grinding manualy. So now you can have more fine grinding.
Remeber that you have to move only two step at a time, then make coffee and then move again to more fine, this will avoid blocking the grinder and also burning the grinder motor.
Also before doing the above you can ckeck the grinding burrs if they are in good condition or they need to be replaced.
Sep 03, 2010 | Saeco Vienna SuperAutomatica Coffee...
Burrs spin but no grinding
Try this, remove the bean hopper, and vac out the burr chamber, then put 1 tablespoon white rice in the burr chamber and cover with hand and turn grinder on, if the rice grinds, then your grind might have been set too fine. Turn the grinder towards fine until you can barely turn the burr nut, you will feel them touching, then turn course about 16 notches (do not use numbers, use the small notches around the rim), that should give you a great starting point for your grind.
May 20, 2010 | Mazzer Mini Burr Coffee Grinder
Kitchen aid burr grinder adjustments
You are correct, the grider positions are locked internaly so the grinder will not go too fine since this can damage the blades and also too fine need more power from motor and also can block it by rottating normaly. However you ir open the grider you can overcome the lock and udjust so the grinder can grind more fine coffee. In order to be always at the safe side just move gradualy step by step until you find the perfect grinding and adjust so that will be the minimum plus one mor move for furure adjustment if you need.
Just for reference the corect grinding is for 7 to 7.5 gr of coffee the running time of the coffee from your machine should be 25 sec for 25 cc of coffee aprox.
Good luck.
Rember to vote for this answer.
Mar 02, 2010 | KitchenAid KPCG100PM Electric Burr Grinder
Cleaned the Solis Maestro grinder and re set it to a fine espresso setting but the grind is coming out very course. What should i do?
Hi Your burr is not locked in. You need to remove the beans from the hopper. Remove the hopper. Remove the burr. Turn the grinder upside down over the trash can. Put the burr back in only make sure that the burr is down. Install the bean hopper and when you turn the bean hopper it should move the burr. Then you can adjust your grind. Make sure that the grinder is running is your going to a finer grind or you could break the grinder. You can turn it to a coarse grind any time.
Jan 12, 2010 | Solis Maestro G385 Electric Burr Grinder
My Solis coffee grinder does not go a fine grind any more. We
Hi
Your grinder adjustment ring inside has its tabs broken. Contact Baratza at 877-701-2021 and they should be able to help get a new one.
Nov 15, 2009 | Solis Maestro Electric Burr Grinder
Mazzer luigi super jolly
Easiest way to set the grind on the super jolly is to remove the beans, turn towards fine until you can barely move the middle stem in the grind chamber, then turn towards course about 12-14 notches on the grinding adjuster(not numbers but notches between numbers). If you still cannot get a fine grind and it is not a brand new grinder replace burrs.
Feb 28, 2009 | Mazzer Coffee-grinder SUPER JOLLY Electric
Why is the grind from my Breville BCG450XL in the finest position coming out like a drip grind with a fair amount of dust mixed in? I have an old Solis with exactly the same conical burrs which is grinding...
Feb 20, 2009 | Breville BCG450XL Manual Burr Grinder
Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Breville & Sealed Bcg800xl Smart Grinder With 25 Grind Settings Logo
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
