Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Brew group stuck and makes loud clicking noise
dutchman05
  • 487 Answers
SOURCE: dump box and brew group stuck
sounds like you inserted the brew group wrong.
if stuck it can be sometimes a hassle to get it out.
ok try these options.
Turn on ,off and on again see if that straightens the brew group out. If not open the door and try to push the knob of the brew group, push it inward and than pull it out . Make sure you try it first with power off. If this does not work pull on the moment you power the machine on.
Let me know what happens. We'll fix it
Posted on Apr 16, 2008
SOURCE: Saeco Odea Giro - alarm light continually slow flashing
I had the same problem. I filled everything up and closed it then took the hopper top and placed a small magnet that fit the circumference of the hopper sensor (I took one off of a refrigerator magnet and it fit down into the sensor) and it immediately went green. Hope it works for you.
Posted on Jun 30, 2009
  • 2039 Answers
SOURCE: where to apply grease to brew group
i no what you mean if you grease the slot you gonna have more maintenance to more often coffee dust goes in that grease have to clean with hot water more often but its what you have to 95% of time when those machine break down its bad maintenance had mine for over 14000 shot the only thing i had to do beside maintenance is completly dismantle the brew group for a good clean up that it clean or machine once a mounth descaling it every 3 mounth you gonna have it for a long long time p.s the grease make it easyer for the gear inside thanks
pierre
Posted on Aug 02, 2009
EsWorld
  • 1618 Answers
SOURCE: SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Posted on Oct 07, 2009
  • 1089 Answers
SOURCE: son in law added whole beans in ground coffee
The notches should be at 10 and 12 approx. If the noise is a clicking sound you have a broken brew drive, and the gears have to be replaced. The brew unit can't compress whole beans and something has to give.
There are to triangles on the front of the brew unit at the round hole where it piviots. They need to be pointing at each other, if the 2 notches are in the correct position, its ready to install
Posted on Dec 03, 2010
While performing the descaling the brew group gets stuck
Have you check if the knob on the top of the machine to distribute hot water is fully closed. If on the edge, you may not get hot water flowing but the light may be on.
Look on page 12 of the manual. It explain the the meaning of the led flashing or stayed on from the control panel
Good luck
Aug 30, 2014 | Saeco Odea Giro Plus Coffee Maker
My brew group was stuck, followed instructions and got it out and motor turned to correct position. Put it back together and now nothing...green light comes on and thats it. No motor sound, that's i
Unfortunately I cannot locate your problem or duplicate it. The various units that turn on the red "stop" light are the grounds container, the drip tray and the brew group. When they are reinstalled the light goes out . So if your brew group was stuck and you had to force it out then you should check very carefully that there are no cracks or breaks on the back. Remember this, the brew group must "click" into place and lock so that it does not move in and out unless the "Press" button is depressed. It is possible that one of the above switches that signals the motor to start is stuck, even if the red light is out, and not allowing the motor to turn on. I don't see the reason why your brew group was stuck to begin with. How did that happen?
Nov 19, 2011 | Saeco Vienna De Luxe Espresso Machine
Motor stuck in brew postion wont reset even with the brew group out
Hi
Leave the brew unit out but put everything else back in and then turn the machine on. the brew drive should reset to where it should be so you can put the brew unit back in, but make sure that the brew unit is ready to install.
You must make sure that the brew unit is ready to reinsert into the machine. To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. If you have you key you can insert it in the front of the brew unit. There is a round hold in the center below the "Push", and twist it clockwise until it stops and the 2 marks are lined up. If you don't have your key you can do this. Push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not, locate the slide on the left side of the brew unit, (it should be hanging down, a flat rectangular piece attached to the cylinder) and push the slide to the right until it does. Press the "Push" lever until you hear a click and you are now ready to reinsert the brew group in to the machine.
Dec 31, 2010 | Saeco Incanto Classic Espresso Machine
Son in law added whole beans in ground coffee slot, I replaced the brew group however the machine makes a noise when turing on and no water comes out after grinding coffee. With the old brew group it did...
Dec 02, 2010 | Saeco Royal Coffee Bar Coffee Maker,...
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Brew group on saeco odea giro wont go back into machine
try to put in the dregbox to the machine, close the door and power on the machine. When the machine not make any noise, open the door and put in the brew group.
Aug 01, 2008 | Coffee Makers & Espresso Machines
Saeco Vienna delux
The brew group is out of place.
--> --> The brew group cannot be taken out.
--> --> Turn on the machine and close the service door. The brew group will automatically go back into place.
The brew group is out of place -Turn on the machine and close the service door. The brew group will automatically go back into place.
May 07, 2008 | Saeco Vienna Deluxe
Dump box and brew group stuck
Apr 16, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna gear jammed
This has happened to me. If the problem is the brew group gear is in the wrong position, you can manipulate the brew group until it matches up with the drive gear in the machine. You'll know it matches if you can insert the brew group back in the machine full until it clicks.
Nov 07, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
