Question about Sewing Machines
Need to set the default tension on an elna 925 dcx overlock
Michaelle
  • 65 Answers
SOURCE: Replacing needle on Elna Pro 905 DCX serger
Try and loosen the screw, and use a magnet to pullout the broken piece. It likely slightly bent in there so you may need a pair of tweezers as well
Posted on Jan 24, 2009
jyackle5
  • 8197 Answers
SOURCE: Elna serger 925 presser foot lift lever broke off.
Here are 2 dillers that will repair it for you.
Sew Pros Inc 393 Broadway
El Cajon, CA 92021 (619) 442-3100 4.61 mi Burdick's Chula Vista Sew 278 Third Ave
Chula Vista, CA 91910 (619) 422-5325 10.56 mi
Good luck and please rate
Posted on Sep 16, 2009
  • 1116 Answers
SOURCE: trouble with my Huskylock 680D overlocker Tensions
You need to re-thread the serger.
Refer to the manual or open the front of the serger to see if the threading diagram is there.
With most sergers, you begin with raising the presser foot, then set the tensions to zero.
Begin the threading with the upper looper (curved looper), then the lower looper and the needles last.
Pull the thread under the presser foot and to the left side of the serger.
Set the tensions back to normal 4 - 5 usually.
Lower the presser foot and hold onto the threas tails as you stitch a chain. If the chain of the four threads is ok, you are ready to serge fabric.
Posted on Feb 21, 2010
SOURCE: User Guide for Contessa MO 103 Overlocker
Hi Nikita,
I also am after the manual for the Elna contessa mo-103 and was wondering if you might be able to scan and email it to me? Am going crazy trying to get it threaded and tensioned correctly!!
Thanks
Posted on Apr 12, 2010
isaiahpro
  • 35 Answers
Purchased an Elna Pro 925 DCX and it was missing the sewing cover to do sewing without using the blades. This is a plastic cover piece that snaps on to the machine when coverstiching. Where can I fing this part?
Posted on Aug 19, 2010
NEED TENSION SETTINGS ON ELNA OVERLOCKER F4 PLEASE
The tension settings on an overlocker are meant to be changed depending on the stitch your are trying to make. For the basic overlock stitch, it is usually recommended to start with the tension dials set at the midway point. However, machines differ, so those may even need to be tweaked. The tension is correct when all the threads meet in the middle of the fabric. It helps to test your machine using the 4 colors of thread so you can better see what is happening with the threads and you will be able to adjust each as needed.
overlocker tension Google Search
Feb 20, 2018 | Elna Sewing Machines
My needle holder on the Elna serger 925 DCX broke. How can I fix it?
You should probably talk to your Elna dealer about getting a replacement part.
Feb 14, 2018 | Elna Sewing Machines
Where can I get the part number for a needle holder for a Elna 925 DCX?
Wal-Mart, Amazon and maybe jo-ann fabric and craft store have a wide selection. Good luck
(396015-14)
1PR39601514
Elna Overlocker PRO 905 DCX manuel
Search for:
Make Model manual
Apr 29, 2017 | Elna Sewing Machines
How do I get a balanced tension with my Elna 624 overlocker?
The best way is to thread with 4 separate colors of thread and then studying the stitch result. With the 4 colors, you can easily tell which thread tension is "off" and whether it should be tightened or loosened. However, a serger is not like a sewing machine where you can set the tension and use that setting for most projects. With a serger, a change in one or a couple of thread tensions will create a totally different stitch.
For most machines, there is a mark at the midway point on each tension control that is the "optimal" tension for a 4-thread overlock. HOWEVER, every machine differs, so these settings may need to be tweaked.
Make It Handmade Perfecting Serger Overlocker Tension
The Anatomy of The Best Serger Tension My Tips Bonus Unpick it Serger...
How to Adjust Thread Tension on an Overlocker Singer Australia
Different Serger Stitches and How to Use Them
You may want to download the serger workbooks at this site (Bernina), and work through each of the stitches. Make notes in the workbook as to how you have set up your machine to get the best of each stitch. This will be a great reference manual for many years.
Bernina Mastery Workbooks
Feb 23, 2017 | Elna Sewing Machines
What is the settings on the elna overlocker 614de
For basic overlock stitch, usually the tensions are all set at the midway point, although there is usually some tweaking for any particular machine.
Oct 22, 2016 | Elna Sewing Machines
My elna overlocker 925 puckers fabric at pressure foot please how can i fix this?
This is usually caused by incorrect thread tension. Light weight fabric with the tension too high will pucker fabric. Thread that is too heavy or light for the fabric throws the tension off.
Feb 04, 2015 | Elna Sewing Machines
How do I sell problems
tension on an Elna L4 overlocker (or serger in USA) is controlled with the four dials on the front of the machine, an overlocker has a tension dial for each thread (usually 3, 4 or 5) and the mid range setting will be 5 on each dial. It is critical to lift the thread pole to its maximum height and follow the threading diagram correctly taking the thread from the cone, through the thread eyelets on the pole, then usually a thread carrier on top of the machine, down and around the tension dial, then usually through another couple of thread carriers until reaching the needle or loopers. Many overlockers will have a threading diagram inside the front looper cover and will use colour coding on the components so you can see where each thread goes.
Jun 02, 2014 | Elna Sewing Machines
What should the tension settings be for Elna Club 4D overlocker
Hi Nikita86,
Do you perhaps still have a scanned copy of the Club 4D overlocker?
Jul 10, 2012 | Elna Sewing Machines
Sep 16, 2009 | Elna Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
