Question about Cell Phones
My screen is broken what do i do
I cant touch the screen to unlock the phone and the screen is shattered
    New Friend:
    Problem Solver:
  • 11 Answers
There is only one way, you have to replace your screen, the way you do it depends on model, usually it isn't worth trying to do it by yourself.
Posted on Feb 11, 2014
4 Suggested Answers
Remag1234
  • 387 Answers
SOURCE: PUK code
2 Options, 1, get the phone repaired at your cost. Water damage is not covered by warranty or insurance. 2, buy a new phone which most likely will be cheaper than the repair.
Posted on May 17, 2009
billa vimal
  • 64 Answers
SOURCE: how to send a text message on a htc touch pro shattered screen
there is no way out other than getting your display corrected..
Posted on Jul 26, 2009
  • 713 Answers
SOURCE: shatterd phone screen!!!!
Hi,i think the inner touch pad of the LCD screen is bad and it needs to be replaced,here is a detailed guide to help you disassemble your LG arena;
Tools required: Phillips screwdriver, mobile phone opening tool, plastic tool such as a guitar plectrum or credit card, double sided tape.
STEP 1 Remove your back cover, battery, sim, memory card etc. Remove the four circled screws.
STEP 2 Run your mobile phone opening tool around the join of the front and back of the phone. Start at the top and then pull the phone apart when you can get enough of a grip.
STEP 3 A ribbon connector (circled) needs to be disconnected. It attaches like a plug and socket. Just lever this up to unplug. Next, peel the blue sticker off.
STEP 4 The circled ribbon connector needs to be disconnected. Just flick the black latch up and pull the orange ribbon away from the circuit board.
STEP 5 Pull the circuit board towards you. A little force is required but be careful as a cable is still connected to the board and you don't want to damage it.
STEP 6 on the left is a connector that disconnected when you pulled the circuit board towards you. Remove the screw, in the upper right corner. Disconnect the two ribbons beside the camera. Each attaches like a plug and socket. Just lever each one up to unplug. Lever up the white wire above the battery slot . Remove the blue sticky tape above the white wire.
STEP 7 Lift away the part above the camera. The ribbon connector needs to be disconnected. Just flick the black latch up and pull the orange ribbon away from the circuit board.
STEP 8 Pull the circuit board away from the phone. Note that the connectors,disconnect when you remove the circuit board. Lever up the wire at the base of the phone. Remove the 2 screws at the edges of the base . Peel back the silver sticker
STEP 9 Use your mobile phone opening tool to lever up the metal part bounding the screen . It's stuck down with double sided tape so using a hairdryer to heat the part may make it easier to remove
STEP 10 Slide something like the edge of a credit card or guitar plectrum under the right edge of the touch screen. Again, this part is held down with double sided tape which may be easier to remove if you heat it up a little first. You should replace the double sided tape when you put the phone back together.
STEP 11 Lift the touch screen from right to left.
STEP 12 Lever the two long stoppers out and then use the recesses as levering points to lift the screen out.
STEP 13 You should now have the LCD screen removed. Reverse the whole procedure for reassembly.
The screen costs only 39USD.
Thanks and take care
Posted on Apr 26, 2010
How can I get contacts from broken android cell phone
Go to google store on a PC and download an app for contacts that is compatible with your android. Sync the phone with the PC and then move them to an email account you can sync with the IPhone.
Easy, did it for my kid when he broke his S3
Aug 19, 2014 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
Sciphone I68 Touch phone screen touch not work.
Either the screen is defective/broken or the unlocking process may have corrupted the system software that translates touches on the screen to actions on the phone.
Mar 03, 2011 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Shattered screen
You will need to take it to your local cell phone store and have them repair it.
Mar 31, 2010 | Cell Phones
MY ipod touch has black dots all over the front and the touch screen doesnt work but the menu button does work and it turns on but i cant unlock it after i turn it on... I tried turning it off but since...
If you have black dots one of two things is broken
  1. The Video Controller is broken
  2. The LCD is broken
If you cant use the touch then the issue is a broken or disconnected touch panel (The touch and LCD are two separate components)
This is easily fixed for about $100. I replaced mine after a fatal fall shattered my front glass. and components.
If you are not tech savvy, call Apple they can fix it, but if your not covered by warranty then it'll cost you A LOT!
Aug 21, 2009 | Apple iPod touch
How to send a text message on a htc touch pro shattered screen
Jul 26, 2009 | HTC Touch Pro Smartphone
TOUCH SCREEN SHATTERED
So, you brushed up against your desk, and shattered your phone's touch screen? I have the same phone, and I have dropped it several times, including on concrete and pavement, and the screens have not even been scratched. I am not saying I have not been lucky, or that you might not have a dud phone, but I think you are understating the truth a bit. Also, you are asking people to solve a problem that has only a couple (very obvious) solutions: Check if the the phone can be repaired by a professional, or, most likely, get a new phone. Sucks, but that's how it goes ;)
Jun 12, 2009 | LG VENUS Cellular Phone
Broken screen
No the only way to fix it would be to take it to someone. Cracked screens do not have an at home fix, plus if the backlight or bulb has shattered then you'll need a new one.
Jun 07, 2009 | LG KU990 Viewty
PUK code
May 17, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
The display screen looks shattered.
that happened to me as well. I had it in my back pocket and when I stood up, the screen looked shattered. it has also happened with my ipod and phone. the screen doesn't look broken, but it needs to be replaced.
Nov 23, 2008 | Kodak EasyShare V803 Digital Camera
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
