Question about Vehicle Parts & Accessories
Astrostart rss-5224 starts then dies when pushing brake or gas
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 177 Answers
Thats NORMAL
Posted on Apr 30, 2014
I have an Astrostart hst5224, It will star then immediately shut off. My jeep is A manual transmission
[PDF]MODEL RSS-5225 - DirectedDealers.com
www.directeddealers.com/manuals/OG/Astrostart/RSS-5225_OG-Eng.pdf
Immediately report any malfunction to the AstroStart dealer that performed the ... Always turn off the main switch when not using the remote starter for .... The startmodule will inform you of the status of door locks, the alarm and of the engine. .... If the trunk is opened for more than 5 minutes, the system switches to the.
How do you reprogram an AstroStart remote HST5224
www.answers.com > Wiki Answers > Categories > Cars & Vehicles
In order to reprogram an AstroStart HST5224 remote, you must putthe key in the ignition ... lamp) b, press and hold UNLOCK button, after 1 second key LED will flash once c, .... C. Turn the ignition to ON (Do NOT Start) then back to OFF. ... B.Immediately after letting go of the lock and unlock buttons, press the lock button by ..
Nov 24, 2015 | 2007 Jeep Wrangler Unlimited Rubicon 2...
How do I fix error code 8 on my astrostart RSS-5225?
Disconnect one of the battery cables from its terminal for five minutes. Reconnect the cable to the post and it should be reset and your car should start. Be sure to tighten the clamp on the cable. It is very important to have a secure cable attachment to the battery post.
Jan 19, 2015 | Cars & Trucks
Astrostart and brakelights dont work
electrical problem. wires are crossed
Mar 07, 2014 | Vehicle Parts & Accessories
Astrostart troubleshooting
try in boot / trunk compartment, or behind the kick panels in the front foot wells and up under the dash board
Dec 24, 2013 | Vehicle Parts & Accessories
Astrostart won't start the car
You may need to reset the system.
SEQUENCE ACTIVATED BY THE PARKING BRAKE .
1. While engine is running (key in ignition switch), apply the brakes and hold the pedal down.
2. Move gearshift lever to neutral.
3. Apply the parking brake Once Twice
Note: The system can be set - at time of installation - to require that the parking brake be applied once or twice.
If set for two actuations, pause one second between the two.
4. Remove key from ignition (the system keeps the engine running).
5. Exit the vehicle.
6. Within 60 seconds, close all doors.
7. The system will stop the engine and blink the parking brakes once to confirm the sequence is valid (vehicle is
ready for a remote start command).
SEQUENCE ACTIVATED BY THE REMOTE CONTROL
3. Apply parking brake.
4. Send the start command (Model 801 & 2101 - Model 903 ).
5. Remove key from ignition (the system keeps the engine running).
6. Exit the vehicle.
7. Using the remote, send the STOP command. The system will stop the engine and parking lights will blink once
to confirm that the sequence is valid (vehicle is ready for a remote start command).
http://www.astrostart.com/Support/Guides.aspx
Nov 27, 2012 | Cars & Trucks
Car shut down when foot not on the accelerator
For this types of problem,there are few help links.I suggest you to click the link below and go through the troubleshooting procedure :-----Car only starts when gas pedal is pressed? http://technoanswers.blogspot.com/2012/01/car-only-starts-when-gas-pedal-is.html-----------Car won't start without hitting the gas pedal? http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-without-hitting-gas.html
----------Complete loss of brake pedal then all gets normal? http://repairhelpcenter.blogspot.com/2012/01/complete-loss-of-brake-pedal-then-all.html
----------Car dies when gas pedal is pressed? http://schematicsdiagram.blogspot.com/2011/12/car-dies-when-gas-pedal-is-pressed.html
--------------Pushing on the gas pedal, but the car slows down? Gas pedal to the floor and the car slows down? http://technoanswers.blogspot.in/2012/02/pushing-on-gas-pedal-but-car-slows-down.html
-------------Idles rough and quits when gas pedal is pressed less? http://technoanswers.blogspot.in/2012/01/1999-ford-f-150-idles-rough-and-quits.html----------This will help.Thanks.
Feb 02, 2012 | 2002 Toyota Camry
Bought this car, dont know how to use the remote start
To add a transmitter on an AstrostartTM Remote Car Starter, follow the
following steps:
• Open the hood
• Turn the key to the ON position
• Push and release the brake pedal
• Cycle the ignition OFF - ON – OFF – ON – OFF. Warning! At the end, the key
should end at OFF. If sequence is made successfully, the parking light will
blink 4 times.
• Push any button on the transmitter to enter in learning mode and the parking
lights will flash 1 time. Repeat the same sequence for any additional
transmitter that needs to be learned in the system.
• Push the brake pedal once
End of programming
Dec 20, 2009 | Astra Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
