Question about Hamilton Beach BrewStation 47224 Coffee Maker
Hamilton beach brewstation 48465 leaks under unit
  • 3 Answers
SOURCE: parts for Hamilton Beach BrewStation® 12 Cup Coffeemaker With Timer
http://forumappliances.com/images/Hamilton%20Beach/Hamilton%20Beach%20Parts/Hamilton%20Beach%20P-990021600.jpg
It's called a tank, not a pot. $9 CDN. Haven't been able to find in US yet. This is very hard to belive considering they make so many small appliances I think HB is not making parts available intentially to get consuners to buy again. Not sure this is smart.
Posted on May 16, 2008
SOURCE: Hamilton Beach BrewStation 47224 Coffee maker
My coffeemaker makes the coffee just fine every morning, and we leave it on for 2-3 hours and then it turns off automatically , but later it leaks back to the water reservoir and then out the bottom all over my cabinet. What is wrong?
Posted on Jan 29, 2009
SOURCE: My hamilton beach brewstation is leaking.
There is a spring between the lever and the o-ring. It may have popped out when you cleaned the pot. That has happened to me before. The spring is necessary to hold the seal down until the lever is pushed.
Posted on Mar 16, 2009
  • 3 Answers
SOURCE: Leaking Coffeepot
I have the same leaking problem. I just called Hamilton Beach and gave them the model and serial numbers. They are sending me a new "gasket" complimentary but she said if that doesn't work, I'll have to order a whole new coffee tank.
Posted on Apr 09, 2009
SOURCE: HAMILTON BEACH BREWSTATION LEAKS FROM SPOUTS
I had the same problem with this same machine. On this model there is a spring-loaded piece of plastic that operates the pouring of the coffee. After a few months of regular use, there is a design flaw in this piece that wears out prematurely, causing the pour to slow down. This is why the stream runs towards the machine and not in your cup.
Eventually the plastic piece will break at the weak point and will stop pouring altogether. To make matters worse, HB uses a weird screw that you cannot turn unless you have the right bit, and, once you do finally get to the piece, there is no where to order a replacement.
Summary: Hamilton Beach built an intentional flaw that is difficult/impossible to repair so you will need to purchase another machine in under a year.
Posted on Feb 24, 2010
Testimonial: "I have concluded all this answer told me. This is a very inferior machine."
Hamilton beach brewstation leaking
Sorry but if this company is like the BUNN corp there are not parts available to repair. they want to sell new only.
Nov 17, 2015 | Hamilton Beach BrewStation Deluxe 47474...
Problem with Hamilton Beach Brewstation I have the water tank apart and I need to know how to put the spring and seal back in
I'll assume you have the pivoting arm with the rubber washer stopper apart. The rubber stopper pulls out of its housing. If you have that out you need to stuff it back in its hole with a small screwdriver. If not: the pivot for the arm rests in two grooves; the arm is held UP with a spring under the arm. (The top of the washer seals the dispensing hole from inside the pot.) The pot has an indentation the spring fits in, the arm also has a depression to hold the spring. It's tricky, but u can get everything lined up in order to put the holding plate (with the 2 screws) in place. (Hold the assembly in place with one finger and with the other hand put a finger thru the holding plate. Move the holding plate toward its final position and switch fingers holding the assembly in place. You're now holding the assembly with the finger that has the holding plate.) Position the holding plate and tighten the screws.
Jun 11, 2014 | Hamilton Beach Brewstation 48465
Hamilton Beach BrewStation 12 cup Coffee Maker, coffee leaks into the bottom water reservoir after brewing.
there is a small rubber flap valve in the tank. if you carefully clean that on a regular basis your problem should end.
Dec 26, 2011 | Hamilton Beach BrewStation
Brewstation Leaks
Mine did the same thing, except I have the model #47665 because the model you have I had to replace twice. It would start/stop numerous times during brewing. Anyway, if yours leaks coffee the same as mine it's because the tiny plastic part holding the small rubber gasket that controls leaking (inside the tank under the screen) is most likely broken. Apparently it's a common problem. I called HB at 1-800-851-8900 and talked to customer support. They are sending me a whole new tank (cannot just fix the gasket) for the whopping price of $5.00 to cover shipping. That's right, $5.00 for shipping gets you a whole new tank. I love Hamilton Beach. They truly do stand behind their products. Again Hamilton Beach product support, 1-800-851-8900 good luck to ya........Katherine
Jul 12, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Leaking Coffeepot
it is the rubber seal it just pulls off push new one on
Jun 01, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Mar 13, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Oct 14, 2008 | Hamilton Beach BrewStation 47224 Coffee...
I have a Hamilton Beach Brew Station Deluxe coffee maker that has been leaking from the bottom of the unit with almost every pot that is made.
IF BY BOTTOM YOU MEAN BOTTOM OF THE POT, YOU'LL LIKELY NEED A REPLACEMENT POT (CALLED A TANK). REPLACEMNT PARTS YOU NEED ARE NO WHERE TO BE FOUND BY ME AND I HAVE LOOKED FOR HOURS.
Might want to call to assure this will work in your model Brewstation.
This vendor is in canada. $9 CDN is cheap enough.
Apr 30, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Parts for Hamilton Beach BrewStation® 12 Cup Coffeemaker With Timer
Feb 12, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Hamilton Beach BrewStation 47224 Coffee Maker Logo
29 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Greg Cann
Greg Cann
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
