Question about Sanyo DP50747 50 in. Plasma TV
Power supply buzzes - Sanyo DP50747 50 in. Plasma TV
42 inch Philips buzzing in back and no power on
The TV still uses power when it is off. You need a small amount of power for the remote to work. The power supply is on even when the TV is off. The buzzing is not normal and could indicate a future failure in the power supply.
May 04, 2015 | Philips Televison & Video
N64 power supply buzzing
Well I think that the power supply piece inside of the other one is not working correctly so it keeps on buzzing you could get it repaired somehow or find someone or a place that fixes old consoles to take a look at it.
Jul 02, 2013 | Nintendo 64 Console
What is with the constant buzzing noise?!
That buzzing noise is the power supply. You probably have a bad capacitor somewhere on the power supply. You can find and replace the cap or change out the power supply. Herre is a link to one at TvPartsGuy.com http://www.tvpartsguy.com/servlet/the-1260/LG-42LB4D-POWER-SUPPLY/Detail
May 10, 2011 | LG 42LB4D 42 in. LCD HDTV
Set won't turn on. has a buzzing soune
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com for a refurbish power supply board.
Feb 20, 2010 | Toshiba MW26G71 26 in. TV/VCR/DVD Combo
Buzzing sound w/no pic or sound, lamp light comes on
Replaced the lamp.Buzzing sound,power supply have problem with some transformers in it.After replaced the lamp pic should come back.Power supply reqiure replacing don't know yet.
Feb 11, 2010 | Sony KDF-E42A10 42 in. LCD Television
Power supply buzzes when power turned on
Sounds like the power supply is bad or under powered for your setup. Have a friend test it in a known working system or try a known working power supply in yours. Had this happen in a old power supply on a newer board. The power supply was good, just not powerful enough.
Apr 01, 2009 | MSI KT4V (MS-6712) Motherboard
CONSTANT BUZZING SOUND
A buzz in the sound can come from having your audio cables to close to the power cords. Or a problem with the cable box. A problem with the Ac power supply like a bad input filter can cause a buzz. If it changes when you turn the volume up and down it is not power supply. Hope some of this helps.. It is hard to be sure without hearing it
Mar 24, 2009 | Vizio L32 32 in. LCD HDTV
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
Buzzing/humming noise in my computer's power supply
I wouldn't recommend leaving your PC on all the time but don't think this should have harmed your new power supply. The power supply may be faulty so try speaking to the store you bought it in to try another one. Alternatively, I would try moving your PC to a very well ventilated area at your desk to see if this helps.
May 06, 2008 | Computers & Internet
Sanyo DP50747 50 in. Plasma TV Logo
12 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
