Question about Saws
I have a tile sealer a hydro it will not turn on I am considering disassembling it But I am Not sure that this is a reasonable thing to do
I have a large gap to seal btwn tile and tub. Any suggestions?
how big is large ?
if it is over 1/2" but under 1" cut a slice of tile to fill the gap
if under 1/2 inch use a silicon sealer ( no more gaps) to fill the space
to get a smooth finish on the sealer use your finger --wet it in water or suitable applicator that is wet with water
once the desired finish is achieved , let it dry and it becomes water resistant
Nov 11, 2016 | Washing Machines
How to clean glass tile after installation
Follow the steps
1.Rub the grout haze with a dry cheesecloth. Shake out the cheesecloth as you work to remove grout dust.
2.Scrub the glass tile with a nylon bristle brush and warm water if cheesecloth doesn't work. Wipe away the loosened grout haze with a sponge as you work. Avoid using the nylon bristle brush in the grout lines of recent tile installations, as the stiff bristles may loosen or cause damage to the grout.
3.Mix a solution of 1 cup of white vinegar to 1 gallon warm water if haze remains on your tile. Scrub the grout haze with a nylon bristle brush dipped in the solution, wiping away the loosened grout haze as you work. Continued use of vinegar can weaken grout, so only use this method to remove haze and not for regular cleaning of glass tile surfaces.
4.Apply a commercial tile cleaner to the glass tile if the previous methods fail. Scrub the haze gently with a nylon scrubbing pad, letting the cleaner do most of the work. Rinse off the tile cleaner with clean water. Use a tile cleaner that is labeled for use on glass tile.
5.Remove the grout haze with a tile cleaner containing phosphoric acid or sulfamic acid as a final resort. These acids are safe to use on glass tile and are highly effective for removing grout haze. Avoid using phosphoric acid on colored grout, as the acid may cause bleaching or discoloration. Read the labels of these products carefully before using, and follow all manufacturer's safety precautions.
http://www.regalotiles.com/productinfo/details/terrazzo-terrasso-polishing/17
Oct 06, 2015 | Bellavita Tile Glass Tile - Bellavita...
How do i seal a crack in the grout on the shower floor using wet area silicone? Is this suitable and what do we do?
problem usually happens when grout is not fully cured and sealed when water penetrates it so... remove old grout using grout removal tool (you can pick up from any where that sells flooring(tile) pick up some new sanded grout to match and sealer apply then seal 24 hrs cure time is req. before sealer wait 2 hrs then re-apply sealer 7_2_2014_6_45_58_am.jpg
Aug 31, 2013 | Home
Can I laquer over pebble tile that has been sealed?
Check with the "dry treat" manufacturer for their recomendation.
Be very careful if the pebble tile are the floor of a shower.
If you wet the pebbles and they get a wet look you should be OK.
If they stay looking dry the wet look sealer may not stick.
Some roughing up with sand paper may do the trick.
Aug 27, 2013 | Saws
How do you quick grout tile floors
I think fresh bucket of water, again wring out your sponge and begin to wipe down the tiled floor in circular motions and it is often the perfect place for black mold, fungus, and bacteria to take root.
Mar 25, 2013 | Home
Best way to clean grout
I have used a solution of Baking soda and water....with a toothbrush but it only gets some of the dirt up.
The best thing to do is redo the grout and then SEAL it. The sealer seems to keep the grout looking like it's natural color for much longer.
My bathroom needs to be done right now and I was just starting to think about this.
I might try to do it myself first and if that small area doesn't go well then I might need to call my tile guy.
You should never clean the grout with a cleaner. That's what my tile guy said. Just water.
Chemicals turn the color quicker
Apr 05, 2012 | Maytag Vacuums
Listello resin 3 by 12 : tile;white grout stuck on the tile
yes, you should seal all tile with a 3-5 year sealer. there are many brands to choose from. excess grout should be removed with a sponge and water before it dries. clean food splatters with any safe kitchen cleaner.
Jul 31, 2009 | Daltile Bathroom Accessories Resin Soap...
Installation Rules?
There are four golden rules for installing a shower enclosure. The first golden rule is to make sure that the shower tray is level. If it is not, then problems will occur throughout the rest of the installation. Use a good quality spirit level and where possible install a tray that has adjustable legs. There are often problems associated with tiling over upstands as some are thick and difficult to set into the wall. The second golden rule is to install a tray that has a slim tiling up stand which is vertical and an integral part of the tray: This will make the installation easier, quicker and ensure it is totally watertight. Before installing the shower enclosure the third golden rule must be followed. A silicone sealer needs to be applied all the way around the join where the tiles meet the tray: This must be sealed first, to ensure there is no chance of water getting behind the wall channels and then into the walls. This is one of the biggest problems associated with shower installations but is easily solved if the silicon sealer is applied before the enclosure is fitted. The final golden rule is to fit the enclosure to the tiled surface and not on to a plastered wall, tiling up to it afterwards. Having installed the enclosure it is essential to use the same high quality silicone sealer around the outside of the enclosure. Sealing on the inside will cause leaking- not prevent it.
Aug 27, 2008 | Dynasty Hardware Pacific Shower Basket or...
Kenwood Steam mop
The Manufacturer suggests you clean the hose by removing the water tank dammed if u can get it off though.
Nov 26, 2007 | Eureka Enviro Steamer 310 Stick Vacuum
Saws Logo
29 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
