I can't see a movie when i insert it into my dvd drawer
How do I start the d v d player on aspire e 15
Insert a DVD movie disc into the player and close the drawer. Wait 10 or 15 seconds. The disc should spin up and recognise the content of the disc and start playing.
Mar 02, 2015 | Acer Aspire Computers & Internet
Tip
Backup or Copy 2009 DVD Movie on Mac OS in holiday
2009 has been past, 2010 is Coming!
2009 is wonderful, and so are 2009 Movies! There are so many excellent movies that we can enjoy them in Xmas holiday. Want to Backup DVD movie or Share Movies with Family and Friends?
We need a cool software which can help us copy DVD movies on mac, I think some third party softwares will be a better choice than Disk Utility.
Just like Mac DVD Copy Pro which is specially designed for Mac OS X users to lets you Backup DVD Movie on Mac with just a few clicks. It also allows you to output DVD folder and directly burn DVD Movie on Mac to new DVD discs.
Step 1: Open Mac DVD Copy Pro and Insert DVD Movie need to be backuped.
These Movies can be Sunmmer Movies or Christmas Movies, such as Transformers 2, Harry Potter and the Half-Blood Prince, 2012, Twilight, The Twilight Saga: New Moon, A Christmas Carol and so on.
Step 2: Select DVD Copy Method
After inserting DVD, the main interface will turn around. And you can see the DVD whole contents in the menu list. If you insert DVD9 disc, you can choose the D9 to D5 compression option to compress DVD9 disc to DVD5. You can choose Main Movie Copy, Customized Copy or Full Copy from Copy Options according to your needs.
With the help of Mac DVD Copy Pro, you can Backup these DVD Movies to ISO Files, Video_TS or .DVDMedia files on Mac OS X, even on Mac OS Snow Leopard. You also have the choice to backup the above three formats to your external hard drive.
After simple tips, click Start button to begin burning.
Step 3: Finish the DVD Settings
After clicking ?start? button, you need to type in the DVD name for the new disc. And you also need to choose optical driver to burn the disc if there is more than one driver. You can also choose the copy speed and quantity according to your own need.
Step 4: Start Copying DVD Movies
When the setting finished, DVD Copy Pro will start burning DVD and save the data to a temperate file. After burning, the program starts encoding DVD and will inform you to insert a suitable blank DVD disc.
Now you can share DVD movies with friends or watch them on Mac and DVD player in the New Year holiday.
on Jan 11, 2010 | Computers & Internet
How do I open disc drawer with a movie in it? Help, it's a library dvd..
Power the unit OFF then straighten out a paper clip and insert it into the small hole in the front panel of the player and push it toward the unit, the drawer will manually open slightly, then just pull it opened the rest of the way. REMEMBER, the unit MUST be turned OFF or it will not work.
Jan 16, 2015 | Computers & Internet
Dvd drawer locked and dvd wont play
Is it a store purchased dvd movie or is it a dvd that someone made and gave to you? Computers sometimes have problems reading cd's and dvd's that someone made. Try a store purchased movie dvd or music cd.
When you press the button on the dvd drawer it does not eject? Clcik Start/My Computer then Right Click on the DvD Drive and click Eject.
If it still does not open, take a Gem Clip (Paper Clip) and straighten it out as much as possible. Then look at the DvD Drawer and you will see a tiny hole that you can insert the Gem Clip (Paper Clip) into. Push the Gem Clip (Paper Clip) while you press the button on the Dvd Drawer and drawer will open. Don't worry about damaging or breaking something, that is why that tiny hole is there.
May 16, 2012 | Computers & Internet
I was watching a dvd movie the other night and in the middle of the movie, the dvd player stopped working and shut off. Now, it will not turn back on. I have tried unplugging it and then plugging it back...
Yes. In order to get the dvd out you will have to grab a knife or something similar to pry the front cover of the drawer off. Then get a pair of pliers and pull the drawer out. Careful not to damage the disc when you do it.
Mar 23, 2011 | Philips DVD 622 DVD Player
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Nov 23, 2010 | Denon DVM-1805 DVD Player
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
RDR-VX530 will not play DVDs rented from Video store. Set of 3 DVDs, played first DVD will not play DVD 2 or 3. Displays loading message for couple of minutes then ejects DVD. Intermittent problem with any...
When a DVD player starts doing that, it either needs to be cleaned, or something is going wrong with the DVD mechanism inside of it. You can purchase DVD lens cleaner from any large retail store that has an electronics section. However, if you clean it and the problem persists, it will likely be cheaper to replace the unit rather than trying to have it repaired unless you're under warranty in which case any repair or exchange will be covered by said warranty. If you call the manufacturer they will give you your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 04, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Lg rc797t dvd drawer will not close consistently
I have a Compaq Presario desktop running XP Media Center. The DVD tray would open on power up, and kept openinig when pushed shut.
I discovered that the tray would frequently remain closed when I held open the flap (the flap with the open button). A few days after discovering this, I got to add some more tracks to my MP3 player - I only mention this intermediate stage in case it is material in curing the problem, as the next thing that happened was a power failure whilst the PC was on. Since then, the CD/DVD drive has behaved perfectly. I did have a temporary problem with AVG INternet Security being unable to load the necessary DLLs to run correctly in MS Outlook 2003, even complaining of a corrupt installation, but this dissappeared after a proper restart and AVG update.
So,
Compaq users: try holding the flap open when you attempt to close the tray.
Generally: with PC running and all applications closed, switch the power off at the wall socket.
HTH
Roger
Shaftesbury (UK)
Jan 25, 2009 | Computers & Internet
H02 Error after inserting a dvd disk
The trouble started with an error to close and open the DVD drawer. It indicated "close" when the drawer was open, or "no disc" when the DVD was inside, and I had to try many times before I get the right response and go on with the procedures.
But then it also started playing just a few MP3 tracks and stopping to work, showing again the inserted DVD data. Later H02, and then H07 and STOP. It doesn't even start playing stuffs, movies or MP3 tracks!
Aug 11, 2008 | Panasonic Televison & Video
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
