Question about Boating
Fluid shoots out of filler tube and won't run while in operation
  • 5370 Answers
SOURCE: transmission runs fine except when
It can be the problem with transmission oil cooler, causing this problem.Transmission cooler lines are usually located near the radiator under the car.While driving the transmission oil get hot after few minutes. As the transmission fluid gets hot it expands and the excess air has to go somewhere.And due to this the oil comes from the filler tube.But if the oil is getting cooled properly then it will not leak,so get the transmission cooler checked.You should install an auxiliary transmission fluid cooler to increase the cooling capacity of the system. You can get a kit for it at any auto parts store.Get this checked.Also check the transmission oil filter.If the oil in the transmission looking burnt then it can be due to faulty filter.That is causing the leak.--------This will help.Thanks.Helpmech.
Posted on Dec 16, 2010
imufo2
  • 3773 Answers
SOURCE: filler tube in back leaks or shoots off fitting
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 07, 2011
1wipokerpro
  • 62 Answers
SOURCE: ****** blowing fluid out filler tube on 2001 ford windstar
Overfilled
Posted on Apr 05, 2012
teds_repairs
  • 2101 Answers
SOURCE: 2001 Taurus transmission blows fluid out of the filler tube. Vent was clean
how much fluid did you put in. sounds to be over filled
Posted on Dec 06, 2012
SOURCE: 1982 gmc f150 truck. Just put in another automatic
GMC --is a general motors
F150--is a ford
So you need a repair shop or trans shop
That trans wasn't built correctly or you
installed a used junk unit that had failed
Posted on Dec 02, 2014
How do u top gearbox oil up on a automatic clio 51 reg
For vehicles without ATF filler tubes and dip sticks accessible in the engine bay, the ATF needs to be pumped in from the side of the transmission and from under the car. There is a specific filling procedure that must be followed. If your particular model has no Auto transmission fluid filler tube with dip stick in the engine bay this is what must be done. If unsure on your particular model then check your owners manual or contact the dealer service people.
If your model has no engine bay ATF filler tube I suggest you get the dealer to do it for you or a transmission business that knows these transmissions and will not overfill it. The vehicle needs to be up on a lift and perfectly level in cases when fluid is required to be pumped into the Auto Transmission from under the vehicle.
These transmissions are sealed units and if fluid needs to be added then you will have a significant leak that needs to be attended to. Running the transmission with low fluid which requires adding to will result in expensive damage to the the unit. If you have a model with no engine bay transmission filler tube and dip stick to check the auto fluid level you will have no idea how much fluid is being lost if you have a leak.
Nov 20, 2015 | Cars & Trucks
1982 gmc f150 truck. Just put in another automatic transmission. Transmission fluid is shooting out of filler tube when running.shot out all of transmission fluid to where it wouldn't move.
F150--is a ford
Dec 02, 2014 | Cars & Trucks
How to check tranny fluid
To check and add transmission fluid on your Ranger:
1. Drive the vehicle 20 miles (30 km) to reach normal operating temperatures.
2. If driven in hot weather or city traffic, allow transmission to cool for 30 minutes.
3. Engage parking brake, start engine.
4. Press the brake pedal and move the gearshift lever slowly through all gear ranges.
5. Shift to P (Park) and leave the engine running.
6. Remove the dipstick, wipe clean with a dry lint free rag.
7. Install and fully seat the dipstick into the filler tube.
8. Remove dipstick and inspect fluid level. It should be in the cross-hatched area.
9. If necessary, add fluid in 1/2 pint (250 ml) increments through the filler tube until the level is correct at normal operating temperatures.
Additional tips start on page 262 of the Owner's Guide: http://www.motorcraftservice.com/pubs/content/~WOARAN/~MUS~LEN/41/10ranog2e.pdf
Apr 11, 2014 | Ford Ranger Cars & Trucks
My windshield washer reservoir won't hold washer fluid.
The seam on the windshield fluid container is broken and leaking like crazy.
Jun 10, 2017 | 2001 Oldsmobile Intrigue
Bought a used 2006 Toyota Corolla a few months back. Car has been working great until I noticed what I feel is a slight transmission slip. I checked what I think is the transmission fluid and it appears...
The transmission filler is located towards the driver side front of the transmission. Look for a tube with a red " T " on top of the tube. Check the fluid with the engine running, in park, at normal operating temperature. If you need fluid, add the type of fluid printed on the dipstick. Add the fluid thru the dipstick tube. Thanks for choosing FixYa for assistance.
Jul 13, 2011 | 2006 Toyota Corolla
WHILE DOING AN ENGINE OIL CHANGE I DRAINED THE AUTO TRANS FLUID BY MISTAKE. HOW DO I RE'FILL THE TRANS ?
Fluid Level Checking & Filling To Check:
  1. Connect a scan tool to the vehicle to read ATF temperature. ATF checking temperature should be 95° - 113°F (35° - 45°C).
  2. Start the engine.
  3. Raise and safely support the vehicle.
  4. Place a drain pan under the transmission.
  5. Allow the ATF temperature to reach 95° - 113°F (35° - 45°C). Automatic transmission fluid inspection plug vw-07-00-7273.gif
  6. Remove the inspection plug from the transmission housing. Fluid is pipe will run out. If fluid continues to drip out, no additional fluid is needed. If only the fluid in the overflow pipe runs out, additional fluid is needed.
To Fill:
  1. Pry the cap from the filler pipe. The cap locking device will be destroyed during removal.
  2. Pull the plug from the filler pipe.
  3. Add fluid slowly with VAG 1924 or equivalent until fluid runs out of the inspection hole. Install the inspection hole plug.
  4. Install the plug in the filler pipe and secure with a new cap.
Aug 17, 2010 | 2003 Volkswagen Jetta TDI
Where do you check the transmission fluid
It's synthetic fluid and there is no dipstick , transmission sealed.
How to check fluid:
Warm up engine , raise vehicle on the lift with engine runing on park position , unscrew drain plug (don't warry it has tube in there ), if you see fluid coming out for 10-15 sec.- level is ok.
If nothing coming out - level is low.
There is a filler tube in front of the transmission with the red cap and red plustic sealing clamp.
If you able to take clamp out without braking it , you can reuse it after.
Fill transmission through filler tube with engine runing
and trany on park position , till fluid starts runing from drain plug , reinstall drain plug , reseal filler tube.
NEVER TURN ENGINE OFF WITH TRANSMISSION DRAIN PLUG UNINSTALLED !!!!!!!!!!!
Jun 06, 2010 | 2000 Volkswagen Beetle
Transmission fluid all leaked out of 2002 dodge grand caravan, are they easy to replace?
Kelli,
replacing the transmission fluid is easy, but you really need to find out why and from where the old fluid leaked. Under the hood in the engine compartment you will find a dipstick (gauge to check the fluid level) which is essentially the same as the oil dipstick in its performance, but different in location. It should be clearly marked as such.
Pull dipstick out and insert funnel into the opening (filler tube) and add 4 quarts of ATF Plus 3 Type 7176. Start the engine and allow it to idle for approx. 2 minutes
Apply the parking brake and push down on the brake pedal while idling and run the gear selector through the gears, stopping at Park.
Check the dipstick and add fluid so that the level is 1/8 inch below the "ADD" indication on the dipstick if necessary. Allow the van to run for around another 10-15 minutes to achieve normal operating temperatures.
Check the fluid level again to make sure it reached the "Hot" indicator level on the dipstick, and add more fluid if needed and then replace the dipstick in the filler tube.
I would definitely find out why you have leaked all of your transmission fluid before refilling it.
Feb 01, 2010 | 2002 Dodge Grand Caravan
Where is the transmission fluid filler on ford fiesta 1996 auto
You need a medium-sized funnel; or a specially-designed transmission fluid filler funnel with a short hose attached to it (at Auto parts store for $5)... use a medium-sized funnel....
The filler tube is the same as the transmission dipstick tube.
Check the fluid level with the engine running, in park.
before adding fluid, turn off engine.
Insert the funnel into the tansmission dipstick tube, slowly pour in fluid (slowly!)..
In an emergency, you can make a funnel with paper or cardboard or sheet of plastic. ... and maybe duct tape...
Hope this helps!
Sep 10, 2009 | Ford F Cars & Trucks
Boating Logo
294 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
