Question about Minka Aire Ceiling Fan
Fan makes humming noise - Minka Aire Ceiling Fan
Humming noise when turned on
The montherboard doesn't have anything that would make a humming noise. In all likelyhood it's the fan that sits on top of teh processor. It could be normal, but might need to be replaced or cleaned.
Mar 01, 2011 | Computers & Internet
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Compac Presario F700 makes constant humming noise
Sounds like its the fan . The more demand you place on the system makes it run hotter so the fan speed automatically increases to compensate
Jan 19, 2010 | Compaq Presario 700 470024-192 Notebook
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Loud humming noise
Usually a humming noise is a transformer going bad.
Jan 06, 2009 | Samsung HCM4215W 42" Rear Projection...
My Samsung RS263022 fridge makes humming noises that comes and goes. One day it will hum, the next it won't. The time the noise varies. Listening to the humming, I can tell it is coming from the back....
The most common problem is the condenser fan, if it has one. It may need cleaning and or oil. Most of them do not have a place to be oiled. The fan can be replaced cheaply. Make sure the power cord is unplugged before taking the cover off of the compressor and fan area.
Nov 26, 2008 | Samsung Refrigerators
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Minka Aire Ceiling Fan Logo
37 people viewed this question
Top Minka Dryers Experts
Merv Vickery
Merv Vickery
Are you a Minka Dryer Expert? Answer questions, earn points and help others
