Question about DBPOWER Quality Original Skybox F3 1080P HD PVR Satellite Receiver Dual CPU
Skybox is dead
I need a bin to revive thsi receiver skybox f3 f5
Can you tell me which jacks i need to use to connect a sky box to the receiver.I have Red, White and yellow
If you have a skybox F3 or F5 it should be a straight connection from the red, white and yellow jacks to either the DVD, DTS/Cable, or DVR-In Inputs on the HTR-6030. The V series looks to be HDMI only, so connections will not be possible without some type of external converter. The FS series looks like most of them support composite video output also.
Feb 07, 2016 | Yamaha HTR-6030 Receiver
Where is the fan located?
The fan is located behind the bin dispenser assembly. It is a low voltage fan, and runs as soon as the SkyBox is plugged in. The thermostat controls only the compressor.
Jul 17, 2014 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox f3
Im having same trouble mate, bit of a novice on this only had it few days any luck doing it??
Mar 30, 2013 | DBPOWER Skybox F3 Digital HD PVR Satellite...
Skybox is not dispencing any pops,when you push the button noting
Check the wiring harness at the bottom of the door AND the child lockout switches at each bin. The switches disable the bin in the down position.
Jul 24, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Hi my skybox stop cooling
The SkyBox operates with two individual systems. The dispenser assembly, the LED indicators and the circulating fan operate on a low voltage circuit. The circulating fan runs anytime the SkyBox is plugged in.
The cooling system operates on 120vac. The cold control inside the beverage compartment is an on demand switch that sends 120vac to the compressor when cooling is needed. There are no parts available for the compressor, so if it determined that power is reaching the compressor, the windings are ok, a 3 in1 hard start kit (Supco URCO210) can be installed by a qualified service technician.
Mar 16, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag SkyBox
For the soda name tags, I pulled logos off the internet and printed them the correct size on 20-pound paper. Different paper gives different translucence, so you might have to experiment to get the right amount of light coming through.
PS: thanks for the part no. on the relay
Apr 21, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Maytag Skybox
Looks like I found the answer to the problem of Skybox not dispensing. I replaced the sensor in the dispensing door and my Skybox now works great!
Part is available from partselect.com just look up your Skybox model number, mine was Skybox model MBV1976AAB. The diagram on the website should show you the exploded view of the door section of your Skybox. You are looking for partselect.com part number 901892 or on the exploded view it will be number 21. The Maytag part number is 11001182, board flipper sensor. My Skybox had been down for two years and now works again!
Mar 27, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Skybox wont dispense
I did some extensive searching for the inserts, and found nothing. I ended up making my own in a graphics program and having it printed at a blueprint shop.
Are you saying that three bins work and one does not, or the other way around? The sentence was hard to understand.
Dec 23, 2007 | Maytag SkyBox MBV1976A Beverage Dispenser
DBPOWER Quality Original Skybox F3 1080P HD PVR Satellite Receiver Dual CPU Logo
Top DBPOWER Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DBPOWER Audio Player and Recorder Expert? Answer questions, earn points and help others
