Question about Garden
Need location on thermostat for john deere 6140D a picture on were it is on the tractor engine
  • Garden Master
  • 2,478 Answers
Following top raditor hose to housing.
Posted on Feb 11, 2014
SOURCE: gas tamk removal john deere 115
I had the same thing happen. I got the tank out, but it wasn't easy. Take out the bolts out that hold the rear end on. Take off the two springs that support the seat. Take out the battery and the battery tray. Take out the 6 bolts that hold the black cowling and the front of the green platform to the frame. This will allow you to lift the seat platform far enough off the rear end to allow the tank to be pulled out through the side. You also have to remove the metal bracket which holds the front of the tank and has caused the tank to leak in the first place. New tank is $56.00 not installed. I used a soldering gun and melted the plastic back together. I think it will hold quit a while. I know this is a little sketchy, but It worked for me.
Posted on Jun 02, 2009
  • 548 Answers
SOURCE: can't get front wheel off my john deere lawn tractor
remove the cap on wheel then there is a ring or cotter pin to remove then pull wheel off
Posted on Aug 22, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
Where the thermostat for the glow plugs on a 6130D John Deere tractor located
no thermostat for glow plugs
there is a relay that turns them on when the key is in the correct position
Dec 16, 2017 | John Deere Garden
John Deere won't start after sitting over winter. I hear the carburetor needs to be cleaned but I don't know where it is or where to start in the removal of it from the motor mount
because John Deere has used Onan, Kawasaki,Tecumseh,Briggs and Stratton one cylinder and two cylinder gas engines you will need to Give the Tractor model or engine information to get any help on this question .With that information it will be easy to get you pictures and video of this job.
May 21, 2016 | John Deere Garden
Where is the serial number for a john deere 4105 compact utility tractor and what do the numbers mean
follow the link to a picture of the location
http://www.greenpartstore.com/John-Deere-Model-4105-Compact-Utility-Tractor-Parts.html
Aug 23, 2014 | Garden
Can anyone tell me where the thermostat is on a John Deere 330 diesel lawn tractor?
follow the raid hoses to the engine should be at a bolt on neck
May 08, 2012 | John Deere Garden
John Deere 1520 bought used over heated wheN I
The thermostat is there to help cool the engine by slowing the flow enough to let the radiator cool the fluid. I would install a new one, but flush the engine and radiator first. Also are you losing any coolant? Could be a head gasket.
Jul 24, 2010 | John Deere Garden
Where on the engine of a john deere 6400 is the thermostat located?
it is located on the right side trace the top raditor hose where it goes into the block the thermostat houseing will be there
Jun 30, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Need to locate the oil pressure sending unit on a John Deere 1010 Gasoline tractor
looking at engine on oil filter side--the sender is on the left side of oil filter and to the right of dipstick in between both
Mar 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
How do I replace a hydraulic pump on a John deere 1050. Where is it located?
The pump is located in front of the engine.A coupler joins it to the front crank shaft pulley.
Nov 06, 2009 | John Deere Steel Chain/farm/tractor/john...
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
