Question about DBPOWER Quality Original Skybox F3 1080P HD PVR Satellite Receiver Dual CPU
How to wake up
Is dead no lights
2007 jeep gc won't start. Lights, battery all Dash lights had been acting strangely before this happened. Turned the car off, Swapped AC relay with starter relay and nothing.
i guess you mean starter is dead, and all lights dead.
pointing to....
the battery is dead, did you jumper cable start it?
if that works the battery is bad, dead or only dischanged.
if that dont work make sure the battery cable lugs are cleaned.
no rust on cable ends( that green junk there that all cars get)
if the head lamps die (they work key off so...)
then the battery is dead, or rusty lugs.
if battery is dead, charge it. using a charger.
Nov 08, 2015 | Jeep Cars & Trucks
What's your question?only breaklights and reverse lights are working
I guess this means your tail lamps for just running are out. Start with fuses, then bulbs, then light switch.
Jun 24, 2015 | Cars & Trucks
Is there a fuse that protects the tachometer and temperature gage?
wow not even saying what it dont do?
the back light dead or needles dead?
sure all loads on every car made has a fuse
(cept starter)
why not post the full symptoms of what works or not.
then ask how to diagnosis it.,
does car run, and shift ok, doe head lights work
do the warning lights work in the cluster, keyon, no start?
the 1996 suzuki has the only free service
chapter 8a-81
no the IG-coil fuse runs the tachometer (electrics )
if IG-coil blows, engine dies.as does cluster lamp test. dead.
the speedometer is not electric its cable driven
is the odometer dead? if yes the cable is dead.
key on , all cluster lamps must glow
or IG coil is blown fuse or battery dead, or main fuse in engine bay blown.
Feb 23, 2015 | 1996 Suzuki Sidekick
Inner lights on dash and speedometer dead
fuseboxes normally are in one of 3 places..under the drivers dash.. in the glovebox.. or under the hood near the battery..dealer can say for sure..
Jan 04, 2014 | 1997 Mercedes-Benz Mercedes Benz Sl Class
Hard disk light not flashing
It might be dead? (The light or the hard disk)
Does the notebook still work? If it works then the light is dead if it doesnt the HDD is dead.
Dec 31, 2012 | HP ProBook 4510s FM849UT Notebook
2005 chevy silverado misfires we changed plugs and wires no check engine light comes on at all goes dead when in gear
Have the PCM diagnosed, it may be defective. If the engine is really misfiring and you are dead sure of that the check engine light should be blinking at you. Are you sure the light works? Does the CEL prove out when key is turned to run?
Jul 03, 2012 | 2000 Chevrolet Silverado 1500
I purchased a new battery for my 1997 hyundi sonta but everything is dead. when time to come home from work hopped in my car everthing was dead jump lead no problems went straight away drove home about 17...
Sounds like the ground wire for the battery is not making clean contact. Trace that wire and clean both ends and the area it connects to the engine block. Good luck!
Aug 06, 2009 | 1997 Hyundai Sonata
Headlights work but dash lights and parking lights are dead
dash and tail sre tied together, so chk tail light fuse.
May 13, 2009 | 1989 Mercury Grand Marquis
Battery goes dead often. Must jump or charge almost everyday
perhaps your problem is not so complicated. maybe one of your vanity mirror lights arent shutting off or something. go out in your car at night and look for light after your dome light shuts off.
Jan 11, 2009 | 2001 Jeep Grand Cherokee
DBPOWER Quality Original Skybox F3 1080P HD PVR Satellite Receiver Dual CPU Logo
32 people viewed this question
Top DBPOWER Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DBPOWER Audio Player and Recorder Expert? Answer questions, earn points and help others
