Question about Vehicle Parts & Accessories
Viper alarm Bought a new viper replacement remote. Followed instructions to a T. After pressing the pressing and holding the valet button on the antenna (door open) nothing happens. No chirp, honk, nothing. 5701
  • 625 Answers
What's the year, make and model of the vehicle?
Posted on Mar 04, 2014
5 Suggested Answers
  • 53 Answers
SOURCE: I press the lock door/alarm activation button and
sounds like the remote is not program try programing the remote again
Posted on Jul 12, 2009
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
slick42371
  • 42 Answers
SOURCE: Does Viper 5701 VIPER 5701 2-WAY ALARM w/REMOTE
No this alarm does not do that. You can set it up for passive arming where 60 seconds after the last door is closed the alarm will turn itself on.
Posted on Feb 04, 2011
Testimonial: "Thank you"
  • 22 Answers
SOURCE: I have a Viper 5701.
make sure the 2 way remote has 2 batteries of the 2016 type.
Posted on Mar 07, 2011
How to program remote for viper 650xv?
You can find a copy of the manual at the link below or try this:
  1. Open driver's door - leave it open (door trigger must be connected on the alarm).
  2. Turn ignition key on.
  3. Within 5 seconds, press the valet/programming button once and release.
  4. Press valet/programming button again and hold it down.
  5. With valet/programming button held down, you should hear the siren chirp within a few seconds. After the chirp, press the lock button on your new remote.
  6. After pressing the remote's lock button, you should hear a short blast from the siren. Now release the valet/programming button.
Viper 650XV Installation Manual
May 13, 2014 | Basic Remote Vehicle Alarm System
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
I had to replace the battery in my car and now my remote will not do anything lock or unlock the doors start the vehicle or pop the trunk what do i do?
Reprogram the remote: turn ignition on, press and release valet switch one time. Press and hold valet switch. While holding valet switch, press lock button on remote. The alarm should chirp to confirm entry into the programming mode (when you press and hold the valet button) and when you press the lock button. Turn ignition off. Test remote.
Jan 24, 2011 | 791XV The 791XV is a 2-way Security and...
Which one is valet button on the viper 474
No key in ignition, door wide open, press lock-unlock-lock within one second. That will valet the alarm and the led will light up steady. Follow same instructions to remove alarm from valet mode.
Oct 04, 2010 | Viper Security and Remote Start System...
My remote starter for my viper 5900 2 way trans isnt working...my battery went dead in the remote, than after i replaced it, it's not working properly
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Oct 03, 2010 | 5900 SST 2-Way Security System / Remote...
How to program viper 5701 remote
Unlock doors
Key out of IGN
Test unit
Nov 21, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
How do I program a Viper 473 V Replacement Remote, to my 2004 Hyundai Santa Fe?
Set lock/unlock button
· open drivers door
· turn key to ON position
· press valet switch 1 time
· press valet switch again and hold
· when alarm chirps press lock/unlock on remote
· release valet switch
· turn key off
Oct 05, 2009 | Viper Security and Remote Start System...
I lost my remote for my viper 350 hv,and when i used my key to open the door the alarm went off,and disconnect the viper box,and bought a new remote,and when im trying to program my new remote and plug my...
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Sep 20, 2009 | Viper Security and Remote Start System...
Viper auto alarm stuck in valet mode
u can open the drivers door if u have a 2 key remote just press lock aux lock again pretty fast and u should be great.
Oct 15, 2007 | Viper RCVGC022 Remote Control
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
