Question about Regent Halex 50538 Foosball Table
How to assemble parts on a wooden helix foosball table
Which Foosball table would be the best for my office? Where I would get it?
There are lots of Foosball table you can get online as you will be having lots of option there. You should buy the Foosball table weighing not less than 200 pounds with a recommended rail thickness of 1 ½ inches.
I ave also purchased the Foosball Table from the "mancavemaster". Here you will get the table under $1000 and there are many varieties for the Foosball table.
Oct 26, 2016 | Sport & Outdoor - Others
Sportcraft foosball table parts
I found parts on amazon, click here and take a look: new Spin on Foosball Real Teams Players. I hope this was helpful. Cheers
Nov 29, 2012 | Sport & Outdoor - Others
What are foosball bearings?
Foosball bearing are parts in the foosball tables that allow the rods to slide in and out. The bearings go inside the holes on the sides of the foosball table.
Aug 12, 2012 | Sport & Outdoor - Others
What's the difference between traditional foosball (table) players and modern foosball players?
Traditional foosball balls are cheap balls that came about during the 1970's. Today, they are found in low quality foosball tables. The annoying thing about them is the inset lines that make the balls constantly roll even when the table is leveled.
What features should I look for when buying a foosball table?
When buying a foosball table, make sure the rods are light and can be moved easily, the surface of the foosball table is even, handles are easy to grip, and the foosball players are capable of catching a pass and pinning down the ball.
How much do high quality foosball tables cost?
High quality foosball tables range from $200 all the way to $1000, depending on the brand and quality of course. A very high quality Dynamo foosball table costs $900.
Aug 08, 2012 | Sport & Outdoor - Others
What's the dimension of a foosball table?
Football tables can vary in size, but a typical table is about 120 cm (4 ft.) long and 61 cm (2 ft.) wide. My own foosball table is 120 on 74 centimeters and it fits right for a normal sized room and very comfortable to play with, I suggest you to get the adjustable when you buy your table.
Jul 29, 2012 | Sport & Outdoor - Others
What's better standard foosball table into an adjustable one?
My advice is to buy an adjustable foosball table because the regular one stays at the same height level and can't be changed in case it's too high or too low making the foosball experience not very comfortable.
Regent Halex 50538 Foosball Table Logo
231 people viewed this question
Top Regent Sport & Outdoor - Others Experts
Are you a Regent Sport and Outdoor - Other Expert? Answer questions, earn points and help others
