Question about Kenwood Car Audio & Video
Dnx6160 no power - Kenwood Car Audio & Video
Model dnx6160 double din. What is the wire color code?
The wiring diagram & color code are in the installation manual which is available from Kenwood on the DNX6160 product site: http://www.kenwoodusa.com/DNX6160 . Click on the Manuals tab. The direct link to the manual is http://manual.kenwood.com/files/52d633463466d.pdf . See pages 4-5. Page 4 has the wiring for power, ground and other connections to the car's wiring/sensors. Page 5 has the speaker wire diagram. Page 6 has the diagram for connecting other devices to the GPS navigation system.
I hope this helps.
Nov 18, 2015 | Kenwood Car Audio & Video
How do you turn it off?
Have you tried pressing and holding the source button for a few seconds? This is the usual way to turn off a Kenwood radio.
Jan 02, 2014 | Kenwood Dnx6160 Bluetooth Navigation...
I would like to connect an ipod to my kenwood dnx 6160, got the cable but still not working
Make sure the aux mode is enabled.
The volume on both your ipod and radio is turned up.
And that the cord is plugged in firmly on both ends.
Mar 01, 2011 | Kenwood Dnx6160 Bluetooth Navigation...
Will this work for a kenwood dnx6160 dvd reciever
Yes should work fine for the 6160.. if you have not bought the 6160 yet.. but a 6960!
Feb 03, 2011 | Scosche Industries Scosche Ma1543b Mazda 3...
Can't use SMS with Iphone 4 and Kenwood DNX 6160 stereo. SMS option is completely grayed out on the stereo screen ???
Apple and most other phone manufactuers do not support the SMS features. Contact Apple and request that they support it.
Jan 23, 2011 | Kenwood DNX6160 Car Video Player
Good day, I bought a Kenwood DNX6160. I do not
Hey, Gisele did you ever get this problem fixed?
Thanks,
John
jmhanna28@hotmail.com
Dec 21, 2010 | Kenwood Dnx-6160 GPS Receiver
Installatoin Manual for Kenwood DNX 6160 for 1992 Lexus SC400
You can download the installation manual at
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Consumer/Manuals/dnx6960_Install.pdf
Oct 11, 2010 | Kenwood DNX6160 Car Video Player
Won't power on
The product uses a power cord, if the power supply is a power cord with electrical connections at each end. Figure 1: Power cord c00057913.jpgThe product uses a power module, if the power supply is a power cord connected to a power module. Figure 2: Power module c00745315.gif
  • If the product uses a power module (adapter), go to Step two: Check if power is supplied from the power module.
  • If the product uses only a power cord, go to Step three: Check if power is supplied from the power cord.If the product uses a power module (adapter), follow these steps to make sure that power is properly supplied to the product. Figure 3: Power module c00745315.gif
    1. Check the power module part number against the part number listed in the User’s Guide to make sure that the proper power module is being used.
    2. If the power module has a permanently attached power cord, do the following.
      1. Disconnect the power cord from the wall outlet.
      2. Disconnect the power cord from the product.
      3. Wait 30 seconds.
      4. Reconnect the power cord to the product and the wall outlet.
    3. If the power module has a detachable power cord, disconnect the power cord from the power module and reconnect the power cord to the power module.
    4. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
    5. If the product does not turn on, or the power light built into the power cord does not glow, plug the product into a wall outlet in another room.
      • If the product or power light turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
      • If there is still no power to the product, then the power module, power cord, or product might be defective. Proceed to the next instruction.
    6. Connect the power module or power cord to another HP Deskjet or Photosmart product to see if the power module is functioning.
      • If the power light does not glow, the power module might be defective. Replace the power module and the power cord.
      • If the power module or power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
If the product uses only a power cord, follow these steps to make sure that power is properly supplied to the product. Figure 4: Power cord c00057913.jpg
  1. Inspect the power cord for visible damage.
    • If the power cord is damaged, replace the power cord.
    • If the power cord is not damaged, continue with the next instruction.
  2. Disconnect the power cord from the wall outlet.
  3. Disconnect the power cord from the product.
  4. Wait 30 seconds.
  5. Reconnect the power cord to the product.
  6. Reconnect the power cord to the wall outlet.
  7. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  8. If the product still does not turn on, plug the product into a wall outlet in another room.
    • If the product turns on when connected to a wall outlet in another room, there is an issue with the power supply in the previous room.
    • If there is no power to the product, then the power cord or the product might be defective. Proceed to the next instruction.
  9. Connect the power cord on another HP Deskjet or Photosmart product to see if the power cord is functioning.
    • If the power cord does not work on the other product, the power cord is defective. Replace the power cord.
    • If the power cord works on the other product, the product facing the issue might be defective. Proceed to Step four: Service the product.
Step four: Service the Product If you have completed all the steps listed above and are still experiencing a problem, service the product by calling hp at 1800-474-6836
Apr 29, 2009 | HP Photosmart D5160 InkJet Printer
Car Audio & Video Logo
14 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
