PSM217-404-H-R psu problem
2 Dead popped capasitors on main board: C124 and C126 470uF 16v Replacement did not fix. PSU making a hissing noise near the transformer when plugged in. No power what so ever. Once turned on a white screen. (usually blue for no signal / idle) Noticed badly darkened part on soldering side of the PSU. Item verification number Q601 item barcode: D F / R W. No idea what part to look for.
SOURCE: main board dead
Sometomes does not show display
Posted on Jan 15, 2008
  • 56 Answers
SOURCE: psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Posted on Jan 27, 2009
  • 11 Answers
SOURCE: No picture on N3250W viewsonic
I just had a viewsonic supply all apart with a blown capacitor, I believe c36. q7 a surface mount npn transistor on the solder side of board was shorted. Replaced cap and transistor, set works fine. Also, check all your electrolytics on this board as they sometimes swell and go bad.
Posted on Jan 28, 2009
jell587
  • 447 Answers
SOURCE: PC will not power up
Check that the ram memory hasn't come unseated from the mobo. If you are using an above board video card also check that it is properly seated as well.
The clicking noise from the PSU is kinda perplexing though...
Posted on Mar 01, 2009
  • 1684 Answers
SOURCE: ViewSonic Vx924 No power
If youcan take a picture or two of the boards in your system as close and clear as you can and go to our web page and email them to me I will check and see if we can help you find the problem.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Aug 14, 2009
Our tv when itis on for a while some times the picture freezes an then goes blank an a loud hissing an squeech sound we have to unplug it to turn it off.
Hissing sound normally from Power Supply unit(PSU), usually from Transfomers in the PSU. Usually caused by bad capacitors. Try this capacitor replacement kit, on ebay only $15. http://www.ebay.com/itm/Repair-Kit-RCA-L32WD22-LCD-TV-Capacitors-/230637983468?pt=LH_DefaultDomain_0&hash=item35b31856ec
Could not find any PSU board available at the moment, but have tried that kit and it works.
Nov 30, 2011 | RCA L32WD22 32 in. LCD HDTV
When I put my PSU on the ON position, it makes no noise, but when I turn it off, it makes a hissing noise and does the same if I unplug it. It was bought two weeks ago and made noise when I first used it,...
if its only 2 weeks old should and its brand new be under warranty
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hope this helps and good luck building your first computer
Apr 29, 2011 | Eagle Tech ET-PSVT550E 550W ATX12V v2.0...
Server is not powering on
Switch PSU between bays Use spare PSU
If server is still not working PSU backplane needs to be replaced. IS spare PSU sovles the issue, then it was a faulty PSU
Feb 26, 2011 | HP Compaq ProLiant ML350 G5 Server
Hi, have a philips 42pf7321d/37 tv that won't turn on, I replaced 2 capacitors that were bad but when I tried to turn it on again two leds on the power supply turn on making a clicking noise they stay on...
Hi.
The clicking noise and the leds on mean that there is an incorrect voltage value detected from the main controller board. When this happen we say that the main controller is forcing the PSU to standby, sending the set in protect mode.In protect mode only
The PSU can be tested bridging the low voltage control lines that are turning the higher DC volts from PSU on.
The procedure to test the PSU is illustrated in the following article. I wrote the article for LCD, but the procedure is more or less the same on your plasma. Simply disregard the part on inverter (plasma work in a different way and have no inverter or backlight system) How to test an LCD TV or monitor PSU
Bridging the voltage lines is a repair suitable for an experienced technician. If you are a DIYer, better testing the resistors and components near to the faulty capacitors by reading Ohms to check if they have continuity. This operation is done with power not connected.
If you need to replace the whole board, here the part number: POWER SUPPLY UNIT LJ44-BLAH101C PHILIPS. The part is temporarily out of stock, and may be available ordering from Philips.
Here the service manual:
PHILIPS Chassis EP1.1U AA Service Manual.
May 06, 2010 | Televison & Video
My computer wont turn on
take out the psu completely from the cpu/tower, plug in the power cord,if there is a switch on the psu turn it on, next locate the main power connector (24pin) and find green wire,take a piece of wire and insert it into the green wire connector,next touch the other end of the wire to the psu outer case or a black wire on the main connector,if all is well the psu will turn on,if you have a dc voltage tester check the voltages on the red and black wires on molex connector...5vdc,yellow and black...12vdc.if ok look at the main board and inspect the capacitors to see if they are swollen, if ok
replace psu and disconnect hdd,cd/dvd,floppy ect from main board only leave memory,processor and video, power on if ok shut off and reconnect hdd, power on, if ok shutoff and connect floppy, if ok power off and connect cd/dvd drive.during this testing you will know what is bad.let me know how it turns out.email; arjoon.ken@gmail.com
Feb 19, 2010 | Computers & Internet
Panasonic DMR EH50 will not power on. All
REPLACE THE PSU REGULATOR- STRG6353A
Aug 01, 2009 | Televison & Video
Ferguson FRG-R121D digital radio doesn't work. Only works on fm stations and then very poorly. Takes a long time to switch on with continuous clicking noise.
I had the same problem and solved it. Mine took about 10mins to turn on (constant buzzing and beating before this).
The problem is the 1000uf and the 220uf capacitors on one of the circuit boards near the front of the device. I replaced these with new ones and problem sorted.
So if you know what your doing, take it apart and solder in some new caps. If not...maybe get a new one!
David
Jul 11, 2008 | Audio Players & Recorders
Mother board servicing
Have you verified that the PSU is OK.
DO you have a voltmeter?
Check the voltages on the main connector to the board
HERE is the 24 pin ATX connector
HERE is the 20 pin ATX connector
If the voltages are not there then either the PSU ON signal is not there, the ON switch is faulty or the PSU is dead.
Post back results and I will try to assist furher
Jul 09, 2008 | ASUS P4S8X Motherboard
Computers & Internet Logo
David Payne
David Payne
