Question about RCA Ipod Tabletop Charger With Usb Port And Ac Outlet
Charger broken can't charge my tablet
    Problem Solver:
  • 25 Answers
Go to ebay, type in the exact model of your tablet and search for the tablet, you can order one from there.
Posted on Jun 13, 2014
Keeps saying connect charger even wben charger connected.iam trying to charge tablet
probably your charger is broken or your charging port is broken. either way, if the charger is broken, its cheap to replace. if the port is broken, its cost a bit more
Dec 05, 2015 | Dragon Touch Touch 7 Purple Dual Core Y88...
I have a Mach Speed JLAB tablet. It wont power on. Just showes battery with exclamation point in the middle. Why?
That symbol usually indicates the battery isn't charged or charging. It could be a connection problem, a charger problem, or a battery problem.
If you have an extra wall charger, try that first as they don't always last forever. Make sure the plug that connects to your tablet looks clean and not corroded.
If it still won't charge, then chances are the battery needs servicing to make sure the connection is OK or the battery just might need to be replaced.
May 11, 2015 | Tablets & eReaders
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Mar 17, 2015 | Tablets & eReaders
PLT7223G power pin broken
Try charging it with the USB cable from the computer. It could be your charger pin is faulty. This happens from frequent in and out charging. The pins on the charger tip get worn out. If it charges with the USB cable then get a new charger.Charging from the computer is slower but it works.
Mar 03, 2014 | Proscan PLT7223G-K 7in Android 4GB Tablet...
Power port broken
you can charge it through USB from any laptop or multichannel charger, if it's 7 inch or 10 inch you can use any charger for car toys for kids it will work fine.
Jan 13, 2014 | Tablets & eReaders
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
P5113 not charging properly
There are a couple of common problems that can cause bad charging:
  1. Bad charging cable - try a new cable
  2. Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
  3. Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
  4. A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
Jan 07, 2014 | Samsung Galaxy Tab 2
Tablet wont charge
The charger socket has probably broken its solder connections, happens because of repeated movements straining it by using it when the charger is plugged in. Have you tried charging it through the mini usb socket?
Jun 05, 2013 | Samsung Tablets & eReaders
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Mar 13, 2017 | Ainol 10" Novo 10 Hero 16GB Dual Core IPS...
RCA Ipod Tabletop Charger With Usb Port And Ac Outlet Logo
46 people viewed this question
Top RCA Tablets & eReaders Experts
Ron Dufek
Ron Dufek
ccsi99
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
