Question about Cambridge Audio Azur 840C CD Player
Update formware cambridge 840C - Cambridge Audio Azur 840C CD Player
Why can my azur 840c not read cd
Hard to tell but in my city, most people changed the laser head or the whole assembly and things are all fixed in such case. The model of the laser head is Sanyo SF-P101N, not sure if the 840C using the same parts in the whole production run, but if one knows how to DIY, might worth a try.
Jul 12, 2014 | Cambridge Audio Azur 840C CD Player
Cambridge Audio AZUR 840C Transport Jamming when disk is loaded
The above comment is complete and utter nonsence !
Here's what you do . Take the lid off , take off the top of the cd transport marked "CD 1 Low Jitter Compact Disc Transport" held on with 2 screws , rince it under warm water (its made of plastic) and refit . Its a build up of dust . Yoy will have to do this every 2-3 years . P.S Leave on "stand-by" because you will do more damage to the circuit boards by cutting the power continually .
Sep 15, 2012 | Cambridge Audio Azur 840C CD Player
The 840c tray does not slide out.
Probably a worn belt in the drawer mechanism. A competent tech should be able to fix.
Aug 14, 2011 | Cambridge Audio Azur 840C CD Player
Developed a hiss crackle and pop on the right and channel [ analogue connected] This is present when the cd player is just switched on but no cd is playing. If a turn the volume up on my amp the noise...
What happens if you select the CD but have NO CD player connected? It could be garbage leaking in through a signal cable.
Or it might be a flaky switch contact somewhere in the signal path on your amp. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Apr 05, 2011 | Cambridge Audio Azur 840C CD Player
I cannot install my Deskjet 840c printer to my windows 7
The Deskjet 840c driver is included in the Win7 OS. You need to use Windows Update. Connect the data cable to the computer. Windows 7 should find the driver. If it doesn't, open Windows Update and check for updates. Look under Optional Updates.
If it still doesn't properly install the printer, disconnect the USB cable and then turn the printer off and then on again. Then open the Devices and Printers window and remove the printer (right click and choose Remove device). Remove all icons for the 840c if you have multiple in the control panel. Then reboot the computer and make sure your network connection is active. Reopen the Devices and Printers window and install the printer manually. To do this: click on Add a printer, choose Add a local printer then click Use an existing port. Select LPT1: (Printer Port) in the dropdown menu and click Next. Click on the Windows Update button and wait for the updates to be completed. Choose HP as the manufacturer and the Deskjet 800 series. Now connect the USB cable between the printer and the computer. You should see the installing device driver software window. Wait until the window disappears and then click Cancel on the Add a Printer Window.
If problems persist, try a new data cable. Try directly connecting to the computer if you are using a print server or USB hub. Make sure the computer USB ports are working. The ports can be disabled for security or power savings. (Check in the Device Manager (Start > Control Panel > System and Security > System > Device Manager) or from the advanced settings for the Screen Saver (right click on the desktop anywhere there are no icons or running programs, select Personalize and then click on the Screen Saver icon. then click on Change Power Settings and Change Plan Settings for the active plan).
I hope this helps.
Jan 07, 2011 | Office Equipment & Supplies
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
Need free updates for garmin 255
You can go to Garmin's website and use their free web uploader to update the firmware of your GPS for free. You just need the usb cable that came with your gps to connect it to your pc. That is for the formware only, updated maps can only be bought from Garmin.
Jan 04, 2010 | Garmin Nuvi 255 GPS Receiver
Need to unlock samsung tocco currently on orange
1.Try tis below.
» Samsung Unlock Code
2.Or If you enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deletedyou enter wrong password for more then 5 times,it ll ask you to enter the puk number....now call your customer care and
Nov 09, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
HP DeskJet 840c
pls. change your data cable of printer connected to computer
if it is work pls. remarks
Jan 30, 2008 | HP DeskJet 840c InkJet Printer
Cambridge Audio Azur 840C CD Player Logo
Top Cambridge Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
