Question about Sabrent Computers & Internet
Light flashing blue not reading drive - Sabrent Computers & Internet
Flashing blue light above the on off switch
That means that your hard drive is reading and writing just as it should be nothing to worry about when its blue
Nov 03, 2013 | Packard Bell Computers & Internet
Flash drive not read
If it does not read in any computer, you can send it back to PNY as it is covered under warranty.
Mar 13, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
Bought a new network hard drive 1tb iomega. Operating system requirements is XP. Saleman said it would update on line & work with windows 7. doesnot happen for me . Is it compatible or not? CD will not...
The drive will not update itself automatically. You will have to download the firmware update and update it yourself. You may also want to get the latest Manager software that is Windows 7 compatible.
Firmware Version 2.064: https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21149
Iomega Home Storage Manager (Windows) https://iomega-na-en.custhelp.com/cgi-bin/iomega_na_en.cfg/php/enduser/std_adp.php?p_faqid=21688
The blue indicator light is the Drive Capacity LED - Displays drive capacity information without logging into the administration tool.
a) Off: Drive is below 70% full. b) Flashing blue: Device busy. Drive Starting up or shutting down. c) Solid blue: Warning! Drive is over 70% full. d) Solid orange: Caution! Drive is over 85% full. e) Flashing orange: Critical! Drive is over 95% full. f) Alternating Blue/yellow: DHCP Server Unavailable. Your Home Media Network Hard Drive was not able to get an IP address. Check the network connections and router settings.
The white indicator light is the Status/Activity LED - Indicates the Home Media Drive's power and drive activity status.
a) Solid white: Drive powered up and ready. b) Flashing white: Drive in use, transferring data (reading / writing). c) Solid red: Drive not ready/Drive Failure. d) Alternating white/red: Boot device not found.
Dec 06, 2010 | Iomega 1TB Home Media Network Hard Drive...
The blue light does not come on the red power light flashes and the red power light flashes i see nothing on the lap top
it might have been dropped, if so it could have bent the little read pin inside causing it to not be able to function correctly, those little harddrives cant take a very big hit
Sep 18, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
LED light has gone out
Lights up blue when the Drive is powered on. Flashes red when reading or writing data. It was just stuck between color as it does not flash green,red-blue make green. Contact the company and see if it is under warranty, if not see if they will send you a new light, because
if it is not under warranty,it does not matter if you open it.
All that is inside is a hard drive, chip board. The light plugs onto the chip board same as a fan plugs onto a motherboard. I hope this helps you and it is under warranty,or at least they send you a new light if not.
Mar 24, 2009 | Acomdata 500GB External Firewire HD 500 GB...
The blue led around the disc drive is flashing
As long as it reads the disks ok, then wouldn't worry about it much, its just a led indicating where to insert your disk.
Nov 14, 2008 | Nintendo Wii Console
Communication between hard drives
Flashing light on enclosures  usually means the drive is being read, written to, or mounting.
Oct 27, 2007 | Maxtor OneTouch II 300 GB Hard Drive
Computers & Internet Logo
129 people viewed this question
Top Sabrent Computers & Internet Experts
Martin Murray
Colin Stickland
Colin Stickland
Steve
Are you a Sabrent Computer and Internet Expert? Answer questions, earn points and help others
