Question about LG Audio Players & Recorders
RH735T playback freezes - LG Audio Players & Recorders
Lg DVD RH735T is there a way of making it region free
Have a look at http://www.videohelp.com/dvdhacks There is no hack yet posted for the RH735T. But you could try the hacks that work for similar LG models on the offchance that they'll also work for your 735. If you find it works, then update the site and say so. It will help others as you have just been helped now. :)
1.Switch Player ON
2.Hold the CLEAR button on the remote control whilst
pressing and holding the programme down button on the player
for 6 seconds.
3. A menu will appear. NOTE.. be careful when using the
remote to move the cursor as you can inadvertently change
other codes.
4. Using the cursor buttons on the remote move left or right
( not up or down ) to move the cursor to OP 6.
5.Move the cursor to position aa and change the code using
the up and down cursor keys so that the code is changed to
8e.
6. Press the OK/Enter key on the remote control
7. Press the Menu/List key on the remote control
8 This should result in the region code being edited and the
player should switch off.
As with all editing of the software it is worth making a
note of all existing codes
before making any changes in case
you make a mistake along the way.
Oct 17, 2014 | Televison & Video
Recording freezing/lagging during playback
Replace the VCR and tapes if it uses one. If this is digital... I will need more info.
Oct 09, 2014 | Home Security
How do I set time and date on LG RH735T DV3T twin HD tuner 500GB
I think its automatic when you set your timezone in setup. There's no other directions in the manual.
Jun 07, 2014 | Televison & Video
Unlock code for DVD player LG RH735T
Found a video on YouTube with instructions, except the standard pass code for the rh735t as stated in the handbook was 0325. If that doesn't work take it back to factory settings and reset. http://youtu.be/gjUYDHgBrLE
Jun 09, 2013 | Televison & Video
Picture "freeze up" during playback
your laser lens is probly dirty ;/ just use a qtips and alcool and gently clean the lens if it not work proper ly may be your laser assembly going out...
hope that will help you....
Apr 20, 2010 | Toshiba SD-3750 DVD Player
During playback picture freezes
it's having trouble reading the disk. clean it. use a disc cleaner from walmart or radio shack to clean off the optical lens, too..
Dec 14, 2009 | Televison & Video
Intermittantly freezes on playback. Toshiba rs-tx20 dvr
shut down tv/dig box/dvd. unplug and then leave a little (cuppa time)
replug .then start up dig box then tv then dvd.sounds like in need of "reboot"
Sep 01, 2009 | Toshiba RS-TX20 DVD Recorder
PLAYBACK FREEZE
Hi i have had the exact same problem, been to sony 3 times and they are now messing me around, they said they have replaced the decking system but the problem is still occuring, when the footage is on my timeline in prem 8 the freeze shows up as a black cheques and smears and also red video. driving me nuts i am pushing for a refund or a brand new cam in exchange steve
Dec 18, 2008 | Video Cameras
Pioneer dvd has no sound on playback and freezes the pc
update the drivers and video graphics card, also you may need to upgrade to higher memory, do a windows update
Dec 06, 2008 | Creative Labs PC-DVD Encore 8x with Dxr3...
Windows Media center recorded TV playback
Some possible causes can be system heat causing the video card to freeze. Sometimes it can also be related to the video driver or MPEG2 decoder. Make sure to use the right decoder and filter for the video playback.
Mar 06, 2006 | Microsoft Windows Media Center Edition...
18 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
