Question about Mitsubishi L75A91 75 in. LaserVue HDTV
I have a Mistsubishi L75-A91, I would turn it on and it would stay on for 15 seconds and then shut off. It did this about 4 times so I did a total reset on the TV and now it comes on but very blurry. Is there any ajustments I can do?
techman
  • 3130 Answers
SOURCE: replaced bulb but tv comes only comes on for about 10 to 15 seconds then shuts down and red light flashes
It sounds like you have a bad ballast board, or possibly the power supply going to the ballast bulb. I'm afraid that if you do not have the repair experience on solid state TV sets, you will need to contact and authorized Mitsubishi repair center. Good Luck
Posted on Jul 10, 2007
SOURCE: Power turns off automatically
Same w/ mine.  Repairman said they turn off auto to protect the set no matter what is wrong.  Take it to be fixed.  Mine was right at $100.  Works great again.
Posted on Oct 25, 2007
Shuttle83
  • 1139 Answers
SOURCE: Mitsubishi vs-50609 wont stay powered on
Hello nicolastran,
I gave this advice to someone with this same problem so here it is again:
It sounds like your shutdown circuit is being activated. This is due to excess current being drawn. This usually happens in the High Voltage section of the TV or one of the deflection stages. Due to the nature of this problem I would suggest that you take it to a local TV repair shop or have a TV repair person come out and take a look at the issue. The HV section is dangerous and should be dealt with by a qualified TV repair technician.
Thank you,
I hope this helps
Shuttle83
Posted on Jul 13, 2008
  • 54 Answers
SOURCE: TV WILL NOT COME ON
Your tv is probably going into a "protection mode" this means something inside the set had failed. This is the tv's way of shutting down before more damage can occur. This could mean many different things that could have gone wrong with this unit. Your best bet is to call your local dealer and have them come out and look at it for you. Tearing apart tv's is very dangerous! Some sets have up to 30,000 volts on the anode! GOOD LUCK!
Posted on Aug 17, 2008
  • 927 Answers
SOURCE: Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Posted on Sep 26, 2008
I have a Mitsubishi L75-A91 tv. The picture is getting dim. Is there a bulb that I can replace to fix the problem?
did you go into the menu and check the brightness there?
other than that could be a main power board or the video board
Aug 01, 2017 | Mitsubishi Televison & Video
Hi i jave a mitsubishi L75-A91 and my hdmi ports have stopped working how can i fix this
Try a factory reset. If it do not help you, check and replace its main digital board.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sep 16, 2016 | Mitsubishi L75-a91 75 1080p Laservue Hdtv
Cannot power on TV.
Error code [66]. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 22, 2014 | Mitsubishi L75-A91 75-inch 3D Ready 1080p...
Pls i need equation for :- The sum of N1200 is invested in three project X,Y,Z at the ratio of 4,5,6 respectively. The expected cash inflow per annum is N700. the combined income for projects X and Y is...
Two ways to get to the same answer:
1) If X,Y, & Z are invested in the ratio of 4:5:6 then the amount invested in Z is 6/(4+5+6) times the total of N1200
= 6/15 * 1200
= N480
(Note: X is 4/15 and Y is 5/15 of the total investment,
4/15 + 5/15 + 6/15 = 15/15)
2) The second sentence says: Income from X plus income from Y minus income from Z is N140 and total income is N700. Total income is 700/1200 of the investment.
As formulas:
(Inc X + Inc Y) - Inc Z = 140 (rewriting: Inc X + Inc Y = 140 + Inc Z)
Inc X + Inc Y + Inc Z = 700
Substituting second formula into third:
(140 + Inc Z) + Inc Z = 700
140 + 2 Inc Z = 700
2Inc Z = 700 - 140 = 560
Inc Z = N280
Inc Z is also 700/1200 of investment in Z.
N280 = 700/1200 investment in Z
Investment in Z is 1200/700 * N280
Investment in Z is N480.
Feb 19, 2014 | Bagatrix Computers & Internet
How to reset nook when it only stays on 3 seconds?i just got done charging
You can return to factory settings. Press "on" button and hold it for 5 second. Then, during boot, press "on" button and hold it for 15-20 second. Repeat this steps 7 more times (8 totally). Then just turn on and watch the restored factory firmware from hidden area.
Sep 05, 2013 | Barnes & Noble Nook Color
MY CYBER HOME TV WONT STAY ON
The reason for this type of faults are very difficult to detect. Contact any service technician.
Jun 06, 2013 | Cyberhome CH-LCTV 150 15 in. LCD...
Mitsubishi L75-A91 colors are breathing..Mostly white color..
Mine is the same way man, what alot of money I have wasted on this, lasts 1 year due for maintence
Jul 11, 2012 | Mitsubishi L75A91 75 in. LaserVue HDTV
Mitsubishi 57734 shuts off occasionally
Hi,if your tv is between 1yr-2yrs maybe its time to replace the lamp.This will be the part # 915P061010 you can find it on discount-merchant with the Philips lamp which last longer 2-4 yrs 6000-8000 hrs.
Sep 24, 2009 | Mitsubishi WD-57734 57" HDTV
RCA CC311 camcorder it turns off after a few seconds
If your are still looking for an answer... The camera has some bad capacitors on one, or more, of the internal boards. I had the same problem.
There's a man named Cameron in Florida that can fix it (AV Repair), but it won't be cheap! I had him fix mine... it cost $350.00! But I love my camera... filmed many, many, things with it. It works great, and looks professional, and is... recorded tapes have excellent quality, and when transfered to DVD they can be enhanced (if you need to)!
Jun 19, 2009 | Quasar VM-L450 Camcorder
Mitsubishi L75A91 75 in. LaserVue HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
