Question about Proform XP Weight Loss 620 Treadmill
Walking belt stops while motor is running - Proform XP Weight Loss 620 Treadmill
3 Suggested Answers
  • 16 Answers
SOURCE: belt stops running while standing on the treadmill
Either front roller may need to be replaced or the motor drive belt may need to be adjusted. This problems are caused when a walking belt is worn out and in need of replacement. Too much tension can cause bearing failure in the motor and the front roller and front roller pulley failure.
Motor drive belt adjustment: The motor drive belt is adjusted independently from the walking belt. Some newer models have an auto tensioner which is a lever that has a wheel that puts pressure on the drive belt and a spring on the other end that automatically loads the belt to the proper tension. You should not adjust these since they are preset. Tension can be affected slightly by adjusting the tension of the walking belt but if you have a slipping problem, the drive belt will require replacement. If your drive belt is too loose, it will slip on the front roller pulley or the motor pulley. If it is too tight, it will increase your amp draw to the point that you may have an electronics or motor problem. Due to this, it is better to be on the safe side and replace a drive belt rather than risk over tightening it.
Posted on Feb 20, 2010
maxtreadmill
  • 832 Answers
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in2_bing.gif and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
Posted on May 16, 2010
Healthrider 500sel
B) Walking Belt/Motor Belt too Tight:
If you have adjusted the walking belt or motor belt recently, check for this problem. When the belts start slipping, some people just crank
down the belts and on treadmills, tighter is not necessarily better. The tighter the belts, the more the drive system has to work to keep
everything moving. You should be able to lift the walking belt (with the treadmill unplugged) in the center of the treadmill about 3" without
straining. Tighter belts should be loosen but make sure you don't create a dangerous slipping situation by loosening.
The motor belt (with the treadmill unplugged) should be able to be turned by hand to almost a 90 degree angle from its normal operating
position. Loosen the belt if too tight. Make sure to test for slipping
and if it does with the proper tension, replace the motor belt.
http://www.youtube.com/watch?v=GPI6dFJCUA4
http://www.youtube.com/watch?v=-oeXTKqWECw&feature=related
http://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=related
sincerely.
E. CUADRA
Oct 30, 2011 | Exercise & Fitness
Proform tredmill---stops after a couple of steps--will start back up after getting off---motor control board?
Inspect the walking board and belt first.Feel the tecture at the outer edge of the belt, then feel the center. If it feel fuzzy, the walking belt is worn.
Check the walking board for damage, deep scratches, excessive friction will cause an over current shutdown of the controller.
If the walking belt and board are good, lubricate the walking board and belt and try again.
Does the motor spark allot when running?? This will also cause over current.
Have you tightened the belt (too tight??)
After covering these suggestions, if the same problem is apparent, change the motor controller..
Dec 16, 2010 | Proform 755cs Treadmill Motor Control...
When i start running it isnt a steady flow of the belt there is jerks every few seconds making it very hard to run and almost is enough to make you fall what do you think the problem might be
It sounds like you either have a loose walk belt or a slipping front drive pully. The walk belt shoould be tightened so that you can pull up on the edge of the belt about 2 inches. If that is OK, pull the motor cover, start the treadmill and walk trying to stop the belt with you feet. Watch the drive belt this time (the small one going from the drive motor to the front drive roller), if this belt stops, you need to tighten motor, or replace if it is older/wornout. If the drive belt keeps turning fine, watch the front roller and see if the pully connected to the drive belt keeps turning while the roller connected to the walk belt stops, if so you need a new front drive roller.
Hope this helps
Nov 03, 2010 | Epic View 550 Treadmill
Belt runs with hesitation. stops during rotation and starts again. like it's slipping
If it does this while you are exercising it is one of two problems. First make sure that the walk belt is adjusted correctly( you should be able to pick up the outer edge of belt about 1.5 inches), if the belt is tight enough, then remove the front cover ( 3 screws at fron and 2 or 3 under), start the treadmill with cover off and watch as you walk, see if the drive belt(small one going from motor to front roller),is still turning after you try to STOP the walk belt with your feet. If the drive belt still turns, see if the front roller stops but the drive pully (other end of drive belt)still turns. If so you need a front drive roller assy. Od if the belt(drive) quits while the motor stays running, adjust the motor, or replace the drive belt.
Nov 03, 2010 | Proform Sport 1000 Folding Treadmill...
My Proform 695 LT runs fine when Iam not on it but when I get on the machine it starts pausing in between running or even a slow walk
Unplug unit remove motor shroud then plug unit back in , press start and begin walking on the belt normally and try to stall the belt to make it slip ( planting foot to stop the belt).
Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Here is the procedure for adjusting the drive belt.
Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting. Loosen this bolt(s) but do not remove. Jack bolt models will have flat mounts and may contain up to four bolts.
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with this bolt, skip to Step 4. If your treadmill is equipped with this bolt (very few are) the repair will only require one person. Using 2 7/16" wrenches, make a few turns to this bolt, tighten the bolts and test your treadmill for slipping. If belt continues to slip, and if their is too much tension ( you should be able comfortably twist the drive belt 90 degrees ) then replace drive belt. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller, here the procedure adjusting the walking belt.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn.When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley. If this is the problem, you will notice it because the plastic will usually make a loud squealing sound on the metal front roller. The front roller assembly will need to be replaced and the drive belt must be replaced also. We suggest replacing the drive belt as well because it is a low cost item and will most likely, have suffered unusual wear from the problem. Another possibility is that the drive belt has worn down. In some cases, belt dressing may help correct the problem. If not, the drive belt must be replaced.
May 29, 2010 | Proform 695 LT Treadmill
When I step on the treadmill, the runner stops and
Unplug unit then remove motor shroud the walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting..
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step If your treadmill is equipped with this bolt (very few are) the repair will only require one person.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller.
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 27, 2010 | Proform 575 Crosstrainer Treadmill
Reebok treadmill
Hi James
May 24, 2010 | Reebok 8050 ES Treadmill
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
I need to tighten the belt, it keeps slipping while walking on it
Unplug unit then remove motor shroud then do the following: If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
1) Adjusting the running belt if the problem: If the walking belt slips when walked on, UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
2) Adjusting Drive belt: Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
May 14, 2010 | Proform 860 Competitor Treadmill
How can you tighten the walking belt on a Image 15.R treadmill. Im pretty sure that its the belt you walk on that is slipping and not the one under the hood but I could be wrong. Any advice?
If you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped (adjust back rollers) or the roller has stopped and motor is rotating ( adjust Drive Belt)
Mar 03, 2010 | RTO Image 15.0R Treadmill Walking Belt
Proform XP Weight Loss 620 Treadmill Logo
14 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
