Reset factory settings tv sharp
My sharp tv was locked with a personal password and i used the service menu to turn it on. Somehow, the colour has gone and everything is now viewed in black and white. How can i reset the colour?
  • 31 Answers
SOURCE: Sim Lock
did u try this one * 2 7 6 7 * 3 8 5 5 # it removes simlock but with all the pictures n music u had on the cell along with phonebook contacts saved on the phone
Posted on Nov 29, 2007
tvtek
  • 1284 Answers
SOURCE: KV-34XBR800 Reset everything in service menu
In the service menu or customer menus? On a Sony I wouldn't use a standard degausing coil as you will do damage to the CRT. Sony requires the use of a low power wand degauser.
Posted on Dec 01, 2007
SOURCE: RCA 27F634T
Have you tried to access the menu features and tried to retune the stations on digital, or are you hooked up for analog.
If you don't know about what i speak, give me a yell. jr@excel.net I believe my remote sensor card is bad. While this might explain why you can't turn yours off, it would not explain the blank picture. If the menu does show, i would think the picture tube is O.K. if the menu does not show, there are some other things to look at.
Posted on Jan 05, 2008
  • 395 Answers
SOURCE: Connect Apple TV to Sony 27FS100
the kv27fs100 is a standard 480i resolution check the output of the apple tv make sure it is not in progresive 480P
Posted on Feb 27, 2008
SOURCE: Plasma Tv 42PD580DTA, Black and white screen while viewing DVDs or Video
My sister-in-law has exactly the same problem and is a common one with this unit.
I've spoken to a technician who says that:
1. Hitachi are withdrawing from Australia and there are VERY limited service centres left
2. The problem is a chip on the main board and depending when the TV was made will determine whether the chip is a plu-in or soldered on to the main board - if it's the latter, you'll be up for a main board at around $400
3. He couldn't get the price of the plug-in chip because he couldn't get through to Hitachi.
Cheers
Dave M.
Posted on Apr 28, 2008
Can't find code for my bush tv model number btvd 91186b
code ..
just read through a bush TV user manual
does this help any ?
6.LOCK MENU
To enter the LOCK Menu, press MENU button and then press or buttons to select the LOCK Menu.
The default password is 6666.
Please set a new password to so it is easy to remember. Follow the on screen steps to set.
FACTORY RESET NOTE:
If you wish to reset your TV, please select the Restore Factory Default option, this will clear all settings.
Free Bush Flat Panel Television User Manuals ManualsOnline com
Jul 15, 2016 | Bush Televison & Video
Tip
Lock and Unlock most TV's
http://www.ecoustics.com/tl/17973/
Polaroid:
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
0000, 1078, 1111, 3808, 5050, 8202.
Mitsubishi LCD TV:
Bypassing the V-Chip Lock After you set the lock, you need your passcode to view
a V-Chip locked program, view the locked TV, cancel
the lock, or enter the V-Chip lock menus.
If you forget your passcode, you can view the locked
TV without entering your passcode. When your
password is requested, press the number 9 and QV
buttons on the remote TV control at the same time.
This process temporarily unlocks the TV.
When entering the V-Chip Lock menu, this process
deletes your old passcode and prompts you to enter a
new passcode.
AOC: 0,0,0,0
LG: 7,7,7,7
PHILIPS: 0,7,1,1
SONY: 4,3,5,7
VIZIO: 0000, 2489, 5351, 8202, 8205, 8206
Emerson/Sylvania/Funia: 0000
NOTES from Emerson/Sylvania/Funai:
1.Make sure to enter the exact same new password in the
"Confirm Password" space as one in the space. If they are
different, the space is cleared for reentering.
2. Your password will be erased and return to the default(0000) when a power failure occurs or this TV has been
unplugged for more than 10 seconds. If you forget the password,
unplug the power cord for more than 10 seconds to
restore the password to 0000.
Sharp TV:
Sharp LCD TV Clearing the secret number using the remote buttons and the TV's buttons.
If you forgot the secret number, clear the secret number using the following procedure:
1) Press MENU, and the MENU screen displays.
2) Press Left/Right arrow buttons to select 'SETUP'
3) Press UP/DOWN arrow buttons to select 'EZ setup', 'CH setup', 'Parental CTRL' or RESET, and the SECRETNUMBER INPUTSCREEN DISPLAYS.
Press and Hold both CH UP and VOL+ ON THE TV SIMULTANEOUSLY until the message appears on the screen. The SCECRET NUMBER IS ****.
on Aug 17, 2010 | Televison & Video
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Forgot mypattern to unlock phone its a concord zte768 I think can u help me
Try these steps:
ZTE Origin hard reset Master Clear/Reset Cricket Origin reset ZTE V768 ,
1. Make sure your phone has been powered off.
2. Hold down Volume up key and press Power key at same time until the screen lights up.
3. Press Home Key to access Android System Recovery screen.
4. Press Volume up\down key to locate wipe data/factory reset, then press Menu key to access factory data reset menu.
5. Select Yes-delete all user data, then press Menu key to confirm wiping data from the phone.
6. When finished, select reboot system now, then press Menu key to restart your phone.
Every data will be erased!
or You can reset your ZTE device's password: Turn off your phone, then turn it on. Select emergency dial. Input *983*987# in emergency dial-up pad. It will restore factory settings and your personal data will be erased.
or from the menu
Privacy: Reset to Factory Settings
1. Touch the Home Key > Apps icon > Settings > Privacy > Factory data reset > Reset phone.
2. Enter six zeros on the screen and touch Erase everything.
WARNING! All your personal information and downloaded applications on your phone will be erased after the factory reset. ZTE Origin V768 Phone Password A password can protect your phone and help prevent unauthorized use. When the phone is password protected, it will ask for the password every time the phone is turned on. Password protection is disabled by default, and the default password is 000000 (six zeros).
Jun 05, 2014 | Cell Phones
T-moblie Prism 2 (U8686) phone has locked screen.
With phone off (pull battery if that is the only way to turn off) hold vol up and power key at the same time until the phone turns on. This should bring up the service menu. Factory reset phone. If it not the vol up button, then use the same procedure while holdin bvoth vol up and down buttons.
May 07, 2014 | T-Mobile Factory Unlocked Huawei U8686,...
How do I reset the 52" TV to original settings. Screen is on Widescreen permanently
Could you please post exact model of your sharp tv. however i will give you this generic solution. In order to do this, you'll need to have your remote handy. You cannot reset the television using the control panel.
  • Turn your Sharp television on. Press the "Menu" button on your remote control. Press the "Right" arrow until you see "Setup."
  • 2
    Press the "Down" arrow until you see "Reset" displayed under the Setup menu. Press "Enter."
  • 3
    Type your secret four-digit code using the remote keypad. If you do not know it, you'll need to reset it by following the process in the section "Resetting the Parental Control Password." After you type in the code, "Reset to Factory Preset Values" will appear on the screen.
  • 4
    Press the "Right" arrow to select "Yes" then press "Enter." The screen will show "Now TV Will Restart." Press the "Right" arrow then press "Enter." Wait for the television to reset and revert to the factory default settings.
  • Nov 14, 2010 | Sharp Televison & Video
    My tv set comes with a menu password of 1111 from the factory as stated in the users manual; I have never used the menu lock nor change the password; today the tv demands the pasword to access the menu and...
    try different passwords, i had this issue with my cell phone, manufacturer said code was 1111 but it was set to 1234.... or check with manufacturer, maybe tv was returned and the store didn't tell you, that is what happened with my phone, i assumed it was brand new, when in reality it was not, even though it was sealed in the box.
    Aug 20, 2009 | Hisense LHD3204US 32 in. LCD HDTV
    Lc-32pd5x its a roof mount antenna not sure what brand it works fine on my other lcd
    so you could not wait 1 minute while I wrote to you how to reset it?
    by default from factory the pin code is 1234
    heres the full user manual for your tv
    http://www.cleverhome.com.au/user/Sharp-Aquos-Piano-Black-LC37PD5X-LC32PD5X-manual.pdf
    if the code doesn't work heres how to reset the tv
    HOW TO SET THE FACTORY PRESETS
    Turn off the TV by pressing POWER on the TV.
    After waiting for about 1 minute, press and hold down RESET and press POWER on the TV to turn on the
    TV.
    All setting items (except TV channel) return to the factory presetting.
    note Password will be cleared after running the factory presetting operation.
    You can run the Auto Installation again by using the following steps.
    1 Turn on the power of the TV.
    2 Press MENU. (Make sure the menu screen displays.)
    3 Press left or right to select “Setup”.
    4 Press up or down to select “Auto Installation”, and then press ENTER.
    5 Press left or right to select “Yes”, and then press ENTER.
    Jun 17, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
    I cannot adjust the brilliance on my wega trinitron kf32fx60u as it is locked.
    Hello Tone66
    You can change Brightness, Color * Sharpness settings in Menu.
    Push Menu button on remote and go to Picture settings and select Personal/ Custom settings and enjoy.
    May 27, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
    Freeview locked
    Phil.. to reset: Info>Menu>Mute>Power Button make sure tv is off to start with! messing around in here could void your warranty..it resets the tv to manufactures settings. if you just want to reset freeview.. 0 0 0 0 then press the colour buttons in sequence.. im having a much bigger problem..i think my freeview has blown on my LE46m87bdx..its only 1 month old..i turned it on and it went crazy..then no more channels..no signal..and i get a max bit error with 0 signal strengh..add to this with the fact that the screen goes crazy and resets on the DTV mode..ive got a service person coming round on the weekend! if it is blown..then ill have to do without freeview on the tv...im not letting him take away the tv...no no no no no!
    Jul 14, 2007 | Samsung LE40R74BDX 40 in. LCD Television
    Televison & Video Logo
    12 people viewed this question
    Top Televison & Video Experts
