Question about Brother MFC-5460CN InkJet Printer
Clean brother mfc 5460 printer heads - Brother MFC-5460CN InkJet Printer
Mix-it-up
  • 832 Answers
SOURCE: brother mfc 5460 cn Paper jam problem
thx infonet. Sorry for reading that you have another prob. Did you open the printer? In case yes, you might have disconnected the small plastic foil which leads the printhead (encoder strip). The foil is located paralell to the driving belt of the printhead. try to fix it in place again. Have a look at the foil (encoder strip): is it stained with ink? If yes you need a new encoder strip. If not you have to place the head on the leftside (where the three white disks are) You can pull the head up in that position and watch the encoder strip when pushing it back in place. Another reason could be that the head crashes somewhere on his cycling way: Open cover and press the two plastics by thumb (located on the other side of the arrow-knob facing to inside) to avoid : cover open message. Power up machine. watch the head cycling. Does it run the hole way from right to left side and back? Or does it stuck some where? Please write here where it stopps.
Posted on Sep 16, 2007
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC-5540cn Print Head replacement
Its quite siple to do if you are able to use a srewdriver... 1#: Go get a 2.hand dcp 110c or 115c at eBay with a good printhead (and a broken scanner glass???). It should print without probs! opening mfc 5440 is nearly the same as a mfc 215c, since all brother printers are of the same built :) follow pictures here http://www.hstt.net/refill-faq/inside.html#Brother_mfc215c For your mfc you have to unfasten some more screws which can be seen very well. After that you can take up the cover. Now you should realize that it looks the same inside as on photos given in the link. Read the rest of "how to change the printhead" here: http://www.fixya.com/support/t209702-get_color_print_black_works_fine there is just one more difference to your mfc! You have to take out the sensor in the ink cart assy of your mfc 5440cn which is clipped at the side and reinsert it into the cart assy of the "new" one! This sensor is placed at the BK cart and signals the mfc that there is a HBK cart. Thats it. This job could be done for a novice within less than an hour. If there are questions afterwards or during surgery post it here!
Posted on Oct 05, 2007
  • 320 Answers
SOURCE: Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Posted on Jan 17, 2009
cene765
  • 787 Answers
SOURCE: I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 02, 2009
  • 265 Answers
SOURCE: How to clean the print head - Brother MFC-685CW Inkjet Printer?
Replace the printhead !
Posted on Dec 11, 2009
Clean brothers mfc240 print head
You need to follow these options for cleaning your printer.
1. open your case and remove the cartridge from your printer and clean your cartridge area.
2. now you need to clean paper rolloer area.
3. once you will do that then you need to clean your printer tray and other area.
How To Clean The Cartridge For Brother MFC 240C Printer
for more information please watch this video.
Feb 21, 2015 | Brother MFC Office Equipment & Supplies
How to clean printer head on brother MFC-J625DW
every brother has the ability to clean head, open control panel, open add printers, check your brother properties and click clean heads.
you also should have keypad access on brother to clean heads.
suggest you read the manual for proper code sine most Brothers have different codes.
Feb 07, 2015 | Brother MFC-J625DW Wireless All-in-One...
Print unable 51 code on brother MFC-5460 CN
paper jam or some sensor error, try to clean the sensor, locate the sensor under the pump, where the printer head park the dis assemble and get the sensor, then clean with water or alcojol..
Jul 21, 2014 | Brother MFC-5460CN InkJet Printer
Unable to clean 50 (brother MFC-845CW
Hi, to clean up brother MFC-845CW
Open the printer
Remove the ink cartridges from the print head.
Use cotton swabs dipped in hot water to thoroughly clean the print head.
Repeat this until there is no ink residue coming off on the cotton swab.
Once finished, allow to dry and replace the cartridges
Try to print something now
You can also use the manual for help.
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002117/Mini3_MfcLcdW_UsaEngUsr_D.pdf
Jun 14, 2011 | Brother MFC-845CW InkJet Printer
I have a brothers MFC 5460 CN all in one,with a paper tray jammed so it will not release.how do I get the tray to release
Hi kenttti,
I have provided link here where you can get the instruction on how you can address paper jam with your Brothers printer. It's complete with instruction and illustrations on how to release the tray as well.
Hope it helps.
Thank you for using Fixya.
Feb 16, 2011 | Brother MFC-5460CN All-In-One InkJet...
Clean unable 46 my printer is Brother MFC-295CN
printer head not working new head required. call : 09425386687 or email - suvidha_times@yahoo.co.in
Jul 29, 2010 | Brother MFC-440CN InkJet Printer
My MFC-5460 is not feeding the paper. There's no jam...
Remove the paper and invert the printer and give it a healthy shake. just be careful not to drop it.
you may hear whatever is obstructing the pathway, rattling around. Use a small flash light to identify and remove it. Then shake again until all is found and removed.
... the ink jet track obstruct the paper?
Feb 02, 2010 | Brother MFC-5460CN All-In-One InkJet...
My printer is showing an error
our printer brother mfc 5460 is not printing.....even though there's an ink....how can we fix that? pls help....
Dec 27, 2009 | Brother MFC-5460CN All-In-One InkJet...
Line on copy
In the ADF there should be a glass strip where the sheet is scanned. Not sure on Brother but you should be able to open and lift the top out of the way. Clean the glass with cloth and water- Windex. Should fix that problem
May 13, 2009 | Brother MFC-5460CN InkJet Printer
Brother5460fax
Turn off Error Correction. Most VoIP cannot handle it.
Sep 19, 2008 | Brother MFC-5460CN All-In-One InkJet...
Brother MFC-5460CN InkJet Printer Logo
63 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
