LG 47LD450 comes on, then unexpectedly shuts itself off. No standby power indicator, no nothing. It turns itself back on after 2-3 minutes. This isn't a sleep timer issue. What else could it be?
This TV is about 3.5 years old, used maybe 5 hours a week. It was working great up until yesterday. When I turn it on, it works like normal, recognizes all inputs, acts like it should for about one minute. Then, without any input from me or from any devices, it shuts itself off. This is a hard off, without the standby power indicator on. Again, when the TV is on (for the minute or so it is on), it functions completely normally. I haven't moved it or messed with anything inside it, and the sleep timer isn't on. What could be the issue? Thank you!
    New Friend:
  • 62 Answers
Well I'm not a T.v. expert but sounds similar to over heating problems. Is the ventilation covered or filled with dust? Try unplugging it and take an air can to the vents to blow out any dust it's collected over the years.
Posted on Feb 10, 2014
SOURCE: Audiovox LCD FPE3206 problems
Hi, All.
I ordered a new power supply module on ebay. Cost about 106.00 delivered. Came in a few days. I replaced the unit, bunch of screws, all wires were cable plugins, no problems at all.
After reassembly, it worked. What can I say? Sometimes ya just get lucky.
tom
Posted on Oct 21, 2008
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Posted on Oct 23, 2008
gsalmen
  • 77 Answers
SOURCE: lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Posted on Jul 09, 2009
SOURCE: Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Posted on Jan 03, 2010
  • 76 Answers
SOURCE: HItachi Model 42HDS69 Stuck in Standby
Tv problems?. any warrenty on the set? how old is the set?
Posted on Mar 18, 2010
Recently replaced the power supply unit in my 47LD450-UA tv. It was turning turning for a few minutes then would turn off and not come on. After replacing the power supply unit, it stayed on long en
Your original problem of failed electrolytic capacitors (common) may be the same one occurring in the replacement if it was a 'pull' from another set.
Normally, depending on the quality of the parts used, these supplies will survive for several years before failing.
If this was in fact removed from another set, it's time to return it if there was any kind of warranty.
If not, the repair cost isn't that great if you have an honest tech in your area.
Jan 09, 2015 | LG 47LD450 47 in. TV
How can I fix my 42' lg it is stuck in standby mode.
I had the same issue with my 47' LG. If it's under warranty just have someone look at it. Mine wasn't so I took off the back panel, checked the power supply for the correct voltages coming out, which were unfortunately were correct. Which only left the main PCB, which was more expensive than a new TV and could only be installed by a "technician." However, the blinks could be a fault code. Here's the link to my question. have 47 LG LCD TV 47LD450 AU and when try to turn it on the red LED...
Jun 17, 2014 | LG 47LD450 47 in. TV
No Picture, but sound for a minute, then shuts off
I think your Display card not proper work so please contact LG Technician.
Thanks.
Feb 17, 2014 | LG RU-44SZ61D 44" TV
I have 47" LG LCD TV (47LD450-AU) and when I try to turn it on the red LED just blinks slowly. So I took it apart to check the power supply panel (P/N: EAX61289601/12) and it seems fine, at least all the...
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy.
To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 01, 2013 | LG 47LD450 47 in. TV
I have a LG RU-52-SZ61D. It Shut down this morning, will come back on for a short time, then shuts down again. The Lamp Indicator light flashs several times and then goes out.
Problem on power supply.
Solve: If you fix this problem itself,change capacitor or power transistor,Drain section LT diode fault change it.then solve your problem.
Jan 10, 2010 | LG RU-52SZ30 52" Rear Projection...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
LD 37LC7D
This set has a modification that needs to be done. It will also start turning on by itself and changing channels rapidly. It's two weeks old. Take it back to the Retailer or if that is not an option contact LG at 1-800-243-0000 to get a local servicer in your area.
Aug 18, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
103 people viewed this question
Top Televison & Video Experts
