Question about KitchenAid Dishwashers
Kitchenaid kudc10fxss4 high temp scrub not working
High temp scrub button beeps when pressed but does not light up and cycle does not run
  • 62 Answers
SOURCE: dd603 top drawer won't start
on the hinge slide there is a micro switch the draw needs to be removed to locate it.
Posted on Feb 13, 2008
SOURCE: Kenmore Elite 8269645
I have this model, but not this problem (my impeller motor seems to have burned out). Anyway, try pressing Hi Temp Scrub, Air Dry, Sani Rinse, Air Dry, in that order and see what happens. Mine appears to reset and run through a set of warm-up tests.
Posted on Jul 27, 2008
  • 9 Answers
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Posted on Aug 31, 2008
huuum
  • 750 Answers
SOURCE: Problem starting fridgidaire model FDB1050REC2
hello kwill8
welcome to Fixya.
You said, You just installed the dishwasher and the only cycle it will go through is the rinse cycle. When You turn the dial to any of the other cycles:pots&pans, normal, light wash and upper rack, the start button as well as the heat dry button and the high temp button do not work. only button that will light up when pressed is the delay button. How can you fix this?
Is this your model FDB1050REC2This is a brand new model and you said you just installed it!
If it is brand new!
You do not have to fix it.
You have a full years warranty, parts and labor!let them fix it no cost to you.
The first thing they will do, . You can do your self!
Go to the breaker and turn it off for 5 minutes and then on again. This should reset the system and this usually is the end to most bad starts!
try it!
Huuum
Posted on Oct 03, 2008
WRMtech
  • 70 Answers
SOURCE: Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Posted on Feb 19, 2009
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
I have a kenmore ultra 665 1627. The green front panel light blinks. And we can not run a cycle. Thanks
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller; but the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Jul 27, 2014 | Kenmore Dishwashers
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
Sep 03, 2012 | Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
The "clean" light blinks 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 28, 2011 | KitchenAid Dishwashers
It is stuck between cycles. How do i reset?
Have you tried turning the mains power off and on after a short delay?
If this does not work then press the following buttons in quick succession (about 5 sec) and when all lights light up press Cancel.
HIGH TEMP SCRUB, AIR DRY, HIGH TEMP SCRUB, AIR DRY
Oct 22, 2010 | Whirlpool 24 in. GU1200XT Built-in...
We can't get it to cycle.... the green light next to 'clean' is flashing on the panel - can't get it to stop flashing and run??
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Jul 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Blinking clean light, will drain with cancel button,wont wash
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
Dishwashers Logo
77 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
