Question about Craig CLC501 15 in. TV
Remote control problem
Need code to make tv work with charter cable remote
How do I program a charter remote to a rca converter box
Charter 1060BC2 and 1062BC3 - Setup
www.urcsupport.com/html.php?page_id=762
SETUP. The Charter 1060BC2 and 1060BC03 Remote Controls are preprogrammed to operate the cable box (converter) provided by your cable system, an RCA TV, a Toshiba DVD player, and a Pioneer audio receiver. To control devices other than the default brands, perform the following steps; otherwise skip this section.
Program the Digital Cable Remote Control
mscharter.custhelp.com/app/.../program-the-digital-cable-remote-control
Dec 10, 2013 - Highlight or write down the codes and device you wish to programbefore moving on to Step 2. On the remote control, press a device key once (i.e., AUX, DVD , AUD, TV or CBL); it will blink once. Then, press and hold SETUP until the selected mode key blinks twice, then release SETUP.
Charter.net Charter Remote Controls - 1060BC2/1060BC3
www.charter.net/.../charter-remote-controls-106...
Charter CommunicationsProgramming Codes: Select the manufacturer of your device from the list. The codes will appear beside the list boxes. Not all manufacturer brands listed may be ...
Charter.net Charter Remote Controls - OCAP-4
Jan 21, 2016 | RCA Televison & Video
What is the remote code that a charter OCAP uses to control a TruTech 20000-D TV/DVD player?
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Aug 31, 2014 | Charter Ltd Ocap-4 C4000 & S4000 4-device...
Why doesnt the volume on my remote control work?
The wrong code on the remote has been used. Though some codes will work parts of the system only the right code will operate all.
If you don't know the code for the TV, then you will have to try ALL the codes until you find one that operates all the controls.
Aug 09, 2017 | Charter Ltd Ocap-4 C4000 & S4000 4-device...
HOW DO I PROGRAM MY AKB73615801 LG BLU-RAY PLAYER CONTROLLER TO MY SAMSUNG TV
I've NEVER been able to get this remote to work with my ProScan PLED2243A-G television. My Charter cable remote finds my TV perfectly, but this remote is useless for controlling the TV.
Feb 01, 2013 | Televison & Video
Charter remote will not change channels--I have put in tv code but still nothing--noting on the remote will work except to power the tv on
You will need to program it to your cable box to change channels. Remember, the channels in your tv are coming from your box, so if the remote can't control the box, you won't be able to change channels. Call charter for help on programming remote to cable box.
Jan 22, 2011 | Televison & Video
I need the universal remote control code for Toshiba MD20P1 20 inch TV/DVD combo.
Enter code 20695 for both the DVD Control and TV Control. This worked for a motorola universal remote with a Charter cable box.
Jan 19, 2011 | Toshiba MD20P1 20 in. TV/DVD Combo
Need the code for the charter remote for my vizio
For example, to search for a code for your TV:
  1. Turn on your TV.
  2. On the remote control, press TV once; it blinks once. Then press and hold SET UP until the TV key blinks twice.
  3. Enter 9 9 1. The TV key blinks twice.
  4. Press 1 (the device code digit for your TV). The TV key blinks twice. Aim the remote control at the TV and press POWER once.
  5. Press and release the CH+ key continuously, then stop when the TV turns off.
NOTE: In the searchmode, the remote control sends IR codes fromits library to the selected device, starting with the most popular code first.
  1. Press POWER. The TVshould turn on, then press SET UP to lock in the code.
NOTE: If the TV does not turn on during step 6, then slowly press and release CH- to go back through the codes, then press SET UP when the TV turns on.
Jan 12, 2010 | Vizio VO47L 47 in. LCD TV
Need remote code for LC420SS8
SEARCHING FOR YOUR CODE
If your home entertainment device does not respond to the remote control after trying all of the codes listed for your brand, or if your brand is not listed at all, try searching for your code.
For example, after trying all of the codes for your TV, you still cannot get the remote control to operate your TV, then:
Turn on your TV.
On the remote control, press TV once. Then press and hold Setup until the key blinks twice, then release Setup.
Enter 9 - 9 - 1- 1. The TV key will blink twice.
Note: Substitute 1 with 0 if searching for a Cable code, 2 if searching for a DVD, VCR or PVR and 3 if searching for an Audio device.
Press Power and aim the remote control at the TV and press CH + one or more times until the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its library to the selected device, starting with the most popular code first.
Press Setup once to lock in the code. The TV key will blink twice.
To search for the codes of another device, repeat steps 1 to 5, but substitute the AUX key for the auxiliary device you are searching for.
Apr 05, 2009 | Sylvania LC420SS8 LCD TV
Dynex code for Charter cable remote
I need the current codes to program my remote control for Dish Network
Jan 19, 2009 | Dynex 32 in. LCD Flat-Panel HDTV
Code for Vizio tv
I contacted Vizio the other day. They tell me that they use the same generic codes as LG. I have Suddenlink Cable, formerly Charter, so I still use the Charter remote. My remote only needed 3 digits and I have noticed that many need 4 or 5. I can tell you that the LG code worked for my tv. I can power on/off, volume, and change the channel. All other functions require the manufacture's remote. The code I used is 005. There was also 004 but that did not work on my tv. Hope this helps someone!
Dec 26, 2007 | Vizio L32 32 in. LCD HDTV
Craig CLC501 15 in. TV Logo
27 people viewed this question
Top Craig Televison & Video Experts
Raj Patel
Are you a Craig Televison and Video Expert? Answer questions, earn points and help others
