Question about Microwave Ovens
I need to replace the burned out bulb (located under the microwave by kenmore elite I need to replace the burned out bulb located under the kenmore elite model 72188502. What is the part number for the bulb?microwave model 72188502 but unable to find the part number.
MicrowaveSvc
  • 9047 Answers
SOURCE: kenmore microwave range hood model 665.61612100 manufactured 2001
The problem is likely on the control panel, which we repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inopoerable or stuck on.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Oct 22, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Kenmore Microwave model 721 62624200
We see this a lot. The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: kenmore microwave model 721.62644200
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Jan 20, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Owners manual for Kenmore Elite Microwave Model 66462
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
You can just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View manuals" button. Click there.
d:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgd:%5cele%5crepair%5cmicrowave%5ckenmore_sears%5cview_manuals_button.jpgcaab351.jpg
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on Jan 18, 2009
How do I replace the bulb in my kenmore elite microwave model 721.62365201 ?
Remove the outside cabinet and be aware of exposed high voltage points inside before groping around to replace the lamp.
Jan 21, 2017 | Kenmore Microwave Ovens
Why is bulb so hot on cooktop light on Kenmore Elite Microwave Hood combination
depending on the type of bulb ( sounds like a halogen? ) turn it off for cleaning
Jun 26, 2014 | Kenmore Microwave Ovens
How do you repair the surface light on microwave
You know how when you turn on a regular light bulb and it burns out with a bright flash? What happens is that when the filament burns out, it breaks and bounces back and hits the other electrical post and basically shorts out causing that bright flash. Sometimes, when the light bulb in the microwave burned out, it shorted out, and caused the circuit-board trace to burn up. (This is not just conjecture; I've seen it.) If that's the case, then you would have to replace the main control circuit board. Unfortunately, a rather expensive repair for no lights. (Although the circuit board trace can usually be repaired by direct-soldering a wire to replace the burned trace. Sears repairmen won't do this, but an independent electronic technician could do it.
Apr 23, 2014 | Kenmore 62622 Microwave Oven
Kenmore elite microwave convection 721.67903 light bulb
27oct: BKOK, replacing the light bulb is not simple, and requires a T15 security bit. Our microwave bulb blew this week, and sears on-line was not helpful, so I took the cover off and removed the bulb and the filament is blown. Here is what you need to do. Sorry, it's not easy. 1) remove the cover - this has 3 standard black phillips head screws, 2 on one side and 1 on the other. Then, there are 4 standard silver phillips heads on the back, plus two size 15 Torx screws that require a security bit to remove. 2) remove the 3 sided cover by prying the bottom and then pushing the cover towards the back of the unit to remove the latch keeping the cover secure to the front of the machine. 3) Now, there is a wiring diagram on the cover, use this to locate the bulb, but I will tell you it is on the top of the unit near the control panel. The white plastic connector has 4 wires going into it... Red, Yellow, Brown and Black. The bulb is secured with one screw and permanently attached to a trapazoidal base. The markings on my bulb say KEI, Korea, 125V,30W. 4) Remove the screw and lift the bulb assembly out and see if the filament is blown. The bulb is clear and so it's easy to see the filament. 5) I'm gonna go to local repair shop to see if they have replacements, but I usually go to AppliancePartsPro. They do have this bulb listed for under $5. , which is ok, but I hate paying shipping on such a small piece. Maybe I'll buy some other stuff. Good luck, it's not easy, and not a easy do-it-yourself bulb replacement. But if you are mechanically and electrically competant, it's not bad. But seriously, this is a lot of work to replace a light bulb. I'll take a picture and post that as well
Jul 05, 2012 | Kenmore Microwave Ovens
Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
May 11, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore Elite microhood combo + when we install the bulb for the underneath light, it immediately burns out. What is the problem?
You should be sure the microwave is unplugged when you remove or install bulbs.
If you are, and it still blows the bulbs, you circuit board needs to be repaired.
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service with a full one year warranty.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Mar 04, 2009 | Kenmore Microwave Ovens
Kenmore elite microwave displays F9 after a few seconds
I have the same problem. The sears guy told me that I needed a phillips screw driver and a torx adapter/driver to remove the entire microwave cover ( it slides off0 to gain acess to remove and replace the bulb.
Dec 29, 2008 | Kenmore 63792 Microwave Oven
Microwave Ovens Logo
16 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
