Asko w6451 display F4 problem during working
W6441 Error message
google this with the model # and the brand along with the F4 error code
Jul 25, 2015 | Asko W6441 Front Load Washer
We have an ASKO W6451 flashing F6. appears to jump from 1 minute to go to 20 minutes to go then flashes F6. would it be something electical?
Asko F6 error is apparently a motor fault. The motor could be jammed, open circuit , burnt out?? It may just be a broken wire or connection come off. Check "Google" and type in Asko F6 error. There is a lot of info about it.
Dec 27, 2014 | Asko Washing Machines
I have an Asco D3350 dishwasher. When the cycle starts the machine fills with water and when there appears to be the right amount of water in the machine an error code F4 shows on the panel. 3 clicks can...
There could be a variety of problems most common clean filter sensor water level faulty replace or pump not working how old and how often do you use it?
Aug 29, 2017 | Asko 24 in. D3350 Dishwasher
What does a "F4" code mean
Welcome to FixYa.
I can tell you on the Asko machines the "F4" indicates an error related to the thermistor.
Whether the thermistor is actually at fault is another matter. It may be a faulty wire connection, the thermistor has become dislodged from the bracket mounting it to the tub or yes indeed the thermistor may be at fault.
Here`s what to look for and what it does...
THERMISTOR
Part no. : 80 616 63
Resistance: 40-60K ohms
Room temperature: 68°-86° F (20-30° C)
The thermistor ( for temperature measurement ) is
located between the motor cradle and the holder.
The thermistor measures and controls the water temperature via a heating element. In the event of errors the heater is switched out and F4 displays if the thermistor short-circuits or is disconnected from the program control board or programmer.
**unplug the unit from the dryer or wall whichever applies to your situation...safety first**
If you are capable, remove the rear panel and top panel to ohm out the thermistor to verify if it is within` the values I provided...or perhaps it has dislodged from it`s position as I alluded to.
In the event you need a thermistor and you feel you can replace it yourself I`ll show you how...I do recommend calling in an authorized Asko service provider.
CHANGING THE THERMISTOR
1. Remove the top cover as mentioned
2. Remove the rear panel as mentioned
3. Remove the thermistor by pulling it out to the left.
4. Remove the thermistor header connector from the program control board.
5. Install the new thermistor by threading it through the hole between the cradle and holder.
6. Connect the thermistor to the program control board.
7. Replace the rear panel.
8. Replace the top cover. (Don't forget the two
star washers for the outer screws.)
Hope this helps move you forward or at least gives you an idea of what needs to be looked at.
Let me know if you require further assistance or this is not clear I can post pictures/illustrations. Thanks for choosing FixYa today.
Good luck.
Regards,
Macmarkus :)
Sep 21, 2010 | Asko W6441 Front Load Washer
Hi,\r\n
yes you need to reset dishwasher to time fill.turn off the power button wait 10 sec,push and hold the programme and start buttons then turn power back on.hold buttons down until display lights up then release them.press programe button until 4 shows in display,then press start.test dishwasher. F4 is an inlet fault.
Jun 07, 2010 | Asko 24 in. D3350 Dishwasher
F4 error message. Cleaned out screen at water inlet and still get error message.
There may be excess water in the water reservoir. Empty the washer Turn it off at the mains, and unplug it, then put some old towels on the floor, tip the washer forward until the excess water comes out, Reconnect and try again. Hope this helps it works for me and saves ££££'s in repair fees
Oct 04, 2009 | Asko W6461W 24" Front Load Washer w/ Delay...
F4 error code
unfortunatly i can not find any support for your washer you can contact them at www.asko.com
Aug 29, 2008 | Asko Washing Machines
Asko washing machine
f4 code is sapose to be the thermister, i'm looking for whosale parts supplyer can you help?
Mar 13, 2008 | Washing Machines
F4 problem
f4 fault means set to time fill,turn power off wait 5 sec then press and hold prog and start buttons in and turn power on wait for previos fault to show then release.then press the programme button the dishwasher will show 1 and start filling,press and hold prog button until it stops filling then press prog button until 4 shows on display,then press start finished,turn off then on and test on cycle.
Aug 15, 2007 | Asko 24 in. D3350 Dishwasher
F4 Fault indication
F4 is a water inlet fault. It doesn't make sense if you have this fault indication with water flowing into the unit. Does the dishwasher drain properly? Usual suspects for an F4 indication would be a clogged inlet line, water supply turned off, bad fill valve, or a control board failure. Let me know if this helps, or give me a little more information on what you have done to correct so far.
Jul 09, 2007 | Asko 24 in. D3350 Dishwasher
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
