Question about Samsung WF210ANW 3.5 cu. ft. front load washer
WF210ANW not fill hot water
We have enough water pressure and temp is 45 C, later we switched cold and hot hoses to see if they were plugged. We get only hot water after switching them. Humming noise is there when is suppose to add hot water but no water comes in
    Prodigy:
    An expert who has answered 500 questions.
  • Samsung Expert
  • 517 Answers
Change the valve
Posted on Feb 12, 2014
4 Suggested Answers
odiebugs
  • 949 Answers
SOURCE: is it getting enough water?
For front loaders, they usually have the level underneath the door, they use small amounts of water, but they spin so all the clothes do get
soaked with water.
Posted on Feb 05, 2010
  • 8 Answers
SOURCE: Just moved my Samsung WF448AAP, hooked it up and
you might have anti flood hoses that are braided going to the machine . remove them and make sure your water supply is coming through the water hoses.
Posted on May 06, 2010
Joe Onley
  • 363 Answers
SOURCE: Machine used to fill normally now water only
I would say that the screen on the back of the washer is clogged, take the hose back off, and look inside the connection, you should see a screen there, remove it and clean and replace it. you can run the machine without it, but it is better to have it on to prevent water impurities from entering the washer.
Hope this gives you some hope and help, Please rate and comment, Thank You
Joe
Posted on Sep 07, 2011
Will not fill with hot or cold water and is connected
You need good water pressure on hot for these machines to work, gravity fed systems may not be enough. I had to attach a pump to mine to improve the hot water pressure (UK)
Switch over the inlet pipes ie hot to cold and cold to hot and try filling the machine when switched to fill with hot water, (machine will fill will cold). proving the valve is opening and it is a pressure issue on you hot water.
Nov 29, 2010 | Admiral AW22 Top Load Washer
When going to wash with my GW11 it stops during the was cycle and the cold and hot water light blink and the machine beeps
Hi just read your posting.Now, when the hot and cold lights flash at the same time it means that you are not getting enough or no hot or cold water.Remove the cold and hot inlet hoses from the machine end and put the ends into a bucket.Now turn the taps on to see if you have water coming out the hot and cold hose and if the water pressure is adequate.Try a cold fill on the wash cycle and see how it goes.please reply and let me know if there is water coming out of the hoses at a good pressure and also what water temp do you select on the wash cycle.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
My Maytag Neptune FAV6800 washing machine overfills on the rinse cycle. Pulling the electric power does not stop the water flow. I have to turn off the water at the faucet feeding the hose. It seems to...
If you pull the power to the machine and water continues to flow then the water inlet valve is stuck open. You will need to replace the water inlet valve. The Service manual will step you thru the process.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
The water inlet valve is p/n 25001046 Substitution: 12002242 Water valve shop around for best price.
Is this Cold water inlet valve issue? If so and you only do Cold water wash/rinse like me you could switch the fill hose connections from hot to cold to hot at the faucet. Turn the hot water faucet valve off and select Warm/Warm temp selection and you will be filling with cold water wash/rinse. Maybe that would hold you over until you replace the Water Inlet Valve assembly.
You can check out your pressure switch transitions as I had this poster do for his issue at this link http://www.fixya.com/support/t5471295-washer_fills_water_begins_agitate_but
His issue seems to be a definite stuck pressure switch not water inlet valve such as yours. Check to make sure your pressure switch is OK by watching the fill point transitions as I mention in the post.
If you machine is a series 12 or above the Low and Mid fill pressure switch transitions will toggle at the same time. Series 12 and above us a 2 level pressure switch. Series 10 and 1 use a 3 level pressure switch.
Good Luck………….. D*ick
Aug 05, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Kenmore Washer will not fill and run consistently.
Can't make any promises here. There could be several reasons for this issue. But from your description I would suspect that the hot and/or cold water hoses leading into the washer may be pressure locked. In recent years I've notice these hoses have been specially configured with a way to cut off the water flow in an emergency. Sometimes if you relieve the pressure on the hose the in-line cutoff valve will reset and the water can flow again.
Turn off the hot and cold water supply to the washer. Then dissconnect the water hoses from the spigot and reconnect. (relieve any pressure) Take this oppurtunity to inspect those hoses. Usually these flow controlled hoses indicated thier purpose with somekind of label (maybe even direction indication for water flow) Then turn the water back on. Dont open the spigot all the way just turn it on enough to get the water flowing. See if that helps.
Apr 24, 2009 | Kenmore 24032\24036 Top Load Washer
Water intake
sounds like a problem with your selector switch , or you ve hooked up your hoses backwards(pretty common issue).new accutemp water temps will indeed turn hot water on even though yuove sselected cold/cold wash. Energy guidelines state that there is an optimimum "cold" temp and if your water is too cold it will turn on the hot water to stablize a warmer "cold".
Oct 27, 2008 | Whirlpool Washing Machines
Water fill temp.
check to make sure that your hot water isn't connected to the cold side this is the number one cause for your problem all washers rinse in cold so if you switch to and its hot cold then your hose is on the wrong valve just switch the fill hoses see if that don't fix it
Mar 27, 2008 | GE WBSE3120B Top Load Washer
E10 error with NEW front loader fridgidaire
Are you sure that water fills the tub ? Close the hot water tap and check if cold water fills in, then close the cold water tap and open the hot water one and check whether hot water fills in. Let me knw with your test results.
Aug 12, 2007 | Frigidaire ATF6000ES Front Load Washer
Samsung WF210ANW 3.5 cu. ft. front load washer Logo
119 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
