1992 Toyota 4Runner Logo
J
Jon W Franzkowiak Posted on Feb 10, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1992 toyota 4runner sr5 speedometer stopped working and check engine light illuminates
Suddenly the check engine light illuminated on my dash and the speedometer, odometer, and trip odometer stopped working.
Stephen
Level 3:
Top Expert:
  • Toyota Master 21,873 Answers
  • Posted on Feb 10, 2014
 Stephen
Toyota Master
Level 3:
Top Expert:
Answers
21873
Questions
0
Helped
6203038
Points
67230
If you have someone check the engine computer for trouble codes, you'll probably find a code for the speed sensor in the transmission.
3 Related Answers
Frank Magliocca
  • 1461 Answers
  • Posted on Jan 08, 2009
SOURCE: 94 toyota previa brake lights not illuminating
CHECK THE BRAKE LIGHT SWITCH UNDER THE BRAKE PEDAL
Anonymous
  • 154 Answers
  • Posted on Aug 08, 2009
SOURCE: 2002 toyota 4runner with the engine,vsc off,vsc trac lights on
NEED TO HAVE COMPUTER CHECK FIND WHAT CODE MADE THE ENGINE KLIGHT COME ON.. AND HAVE IT FIXED,, VSC LIGHTS COME ON BECAUSE THE COMPUTER DEACTIVATES THE VSC AS A SAFETY FEATURE WHEN CK ENGINE LIGHT IS ON
Anonymous
  • 21 Answers
  • Posted on Nov 25, 2010
SOURCE: 1992 22re standard transmission toyota pickup
It sounds like the cluster is gone bad if everything is not working. Usually, if just the speedometer isn't working then it's the speed sensor on the transmission that has gone bad. But I think you have a cluster that has just died. Check on EBAY for a used cluster and ask them to roll the mileage to what is on your vehicle now.
Testimonial: "WELL, I'LL CHECK IT OUT. THANKS FOR THE INFO, IT MAY HAVE SAVED MONEY I DON'T HAVE"
How to replace check engine light bulb on a 2002 toyota landcruiser
Hello Susan,
Your check engine light is located in your vehicles dash cluster and will only illuminate when a fault is detected..no detected faults..no light, although it should illuminate (to prove it is working) for a short period of time at each engine start up.
If your light does not confirm operation during the start cycle, explore for access to the lights wiring connector behind the instrument panel cluster to see if you can easily remove the lamp from the cluster...sometimes it it easier to remove the dash trim bezels and remove the cluster from the dash to change lamps.
Of course your Toyota's engine management systems are controlled by an computer generally referred to as a ECM (engine control unit (ECU), also commonly called an engine control module) so if your lamp fails to illuminate during the start cycle the problem may not be due to a simple lamp failure.
2answers
My 2005 Toyota 4runner with a v6 will not start when the temp gets below 32 outside what could be my problem
There could be several reasons why your engine will not start. When you first turn the key to the On position (without starting the engine), the lights on your dash should illuminate. The yellow Check Engine light should come on, at least for a few seconds. If not, then you are not getting power to your engine computer. Perhaps the fuse is loose. Locate the Engine fuse in the cabin fuse panel and wiggle it while watching the dash lights. When the Check Engine light illuminates, you should be able to start the engine. If not, then it is time to check for spark. You can remove a spark plug, install a jumper between the ground electrode and the engine block, insert the spark plug securely into the spark plug boot, and have an assistant crank the engine. If you see your spark plug firing, then you can assume you have a fuel delivery problem. Have the system pressure tested. You may have a weak fuel pump.
92 toyota 4runner speedometer inoperable and check engine light comes on
so why not scan it first and wonder 2nd.
that is what the light means, Im seeing errors ,please do scan me now
to see all errors
back in 1992 , DIY you have only blink codes.
my guess is the VSS CODE is set and the VSS is in fact dead.
google Toyota 1992 4runner DTC check codes.
i bet code 9 (use a paper clip at the CHECK term.)
http://www.troublecodes.net/toyota/
or log in alldata.com and read. its all there ,all the time.
My speedometer stopped working in my Toyota 4Runner, 2001 model
it and odometer?
only.
is the CEL lamp glowing running
did you scan the PCM for DTC errors. oops.?
2000 Toyota Camry instrument panel gauges not working
check the fuses in your manual it will tell you which fuses are for the dash and replace them it sounds to me like they are blown! good luck
5helpful
1998 toyota 4runner reset check engine light
Hi. You can reset the check engine light by removing the blue 15 amp EFI fuse (fuse box under the hood). If you do this, and the check engine light is illuminated again, you will need to address the cause for the light to be on; you have a 'hard fault'; and a part may need replaced.
Dash board illumination not bright enough
look on the left of dash for the switch you turn your interior lights on turn it see if your dash light will brighten.turn up enough brighten dash lights. dont turn until it stop or your interior light will stay on.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
