Question about Frigidaire ATF6000ES Front Load Washer
HOW TO RESET FRIGIDAIRE MODEL FTF2140ES3 - Frigidaire ATF6000ES Front Load Washer
FTF2140ES won't spin
How old is the machine ?
if about 3years old check carbon brushers
Dec 14, 2013 | Frigidaire FTF2140ES Stacking Front Load...
Frigidaire ftf2140es3 all lights flashing and beeping
Hello Bradley Clark - Does the cord or plug look damaged? If it does not, try resetting the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. If it proves to be ineffective, I suggest contacting a professional to move forward accurately. The may be possibly be experiencing an issue with the control board, faulty door lock assembly, faulty pump, or the timer itself is not operating correctly.
Dec 16, 2012 | Frigidaire ATF6000ES Front Load Washer
Ftf2140es3
How about save yourself some cash and put it on spin manually and try that see if that works.
Apr 04, 2012 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Frigidaire washer ftf2140es3 will not spin in any mode
I am having the same problem! I cleaned out the coin trap, shifted the loads for balance, still will not go into a full spin!!!! Does anyone have a solution??
Oct 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Jun 08, 2010 | Frigidaire FTF2140E King-Size ENERGY STAR
I have a frigidaire washer, model ftf2140es3. It ...
try pressing select and option button at the same time. We had all the lights lit up but it would not start or cancel until we did that. or slam the door,,
May 16, 2010 | Washing Machines
Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Dec 02, 2009 | Frigidaire Washing Machines
Ftf2140es3 won't completely drain or do final spin.
I have one that does the same thing at times. remove the bottom front panel. You will see a black boot that comes down from the tub. Loosen the clamp on top of the boot. You should be able to pinch the boot and feel something hard inside the boot. Pull the boot down from the tub and put your fingers down inside the boot and pull up the coin collector. It may be full of junk, coins ect. Clean it and replace the boot and clamp. This should help you.
Jul 16, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Frigidaire ATF6000ES Front Load Washer Logo
66 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
