Indesit IDV65 I have a Indersit IDV65 and the timer went wrong,if it was set to 60 mins it only worked for 6 mins and then the timer was at the finish point so it was working 10 times faster than it should.I bought a new timer and fitted it. Now the drum only turns for a few mins then it stops, the power is still on the timer as you can hear it running.I checked the voltage at the capacitor that goes to the motor and when the drum is turning the power is there,once the drum stop the power has gone from it.I have tried it with the heating element disconnected and the same thing happens.I have checked the 2 thermostats on the heater element and their both ok
4 Suggested Answers
  • 209 Answers
SOURCE: hotpoint wd62 washer dryier (aquarius 1200)
i am a retired engineer of 20 years, and its about a year since i worked on combination washer/dryers but if the heater elements fine and power comes from timer there must be cut out somewhere around where it should warm up, look all round the machine one may be hidden or hard to spot there maybe about 3 one of them one of them could be a trigger device (you can press a button to reset it) that style is a very small cube about the size of a sugar lump with2 spades on it, others look like a small flat oval or round shape the size of a five pence piece with 2 spade wires on them, remove the plug from wall and remove these spades and check the contacts for continuity, you need not remove from machine to do so, no circuit + no heat, replacement item not expensive, thats where to start based on the information given, check the sensors you mention again, it sounds like your so close, good luck and work safe
Posted on Sep 09, 2007
  • 409 Answers
SOURCE: Kitchenaid KAWS750JQ3 Top Load Washer
hi there,
make sure that the program is not on the "Intermittent Agitate Program". that would be the cause of the delay.
the other issue would be the timer itself. the timer is mechanical, so once the contact on it is corroded, it will only function intermitently or not at all.
please let me know if i can be of more help.
thanks
Posted on Sep 28, 2008
barkencoa
  • 3463 Answers
SOURCE: No heat on Indesit IS60V tumble dryer
The heater and stats are located at the rear of the m/c behind a removable panel.
you need a meter to test them, more likely to be a stat problem, but again you must test them for continuity.
Plz leave feed back for my solution.
Thanks.
Posted on Dec 14, 2008
How to replace fan belt indersit IDC85
use the manual to change the fanbelt: http://www.indesit.co.uk/indesit/_pdf/manuals/19508388602_GB.pdf
Jun 15, 2014 | Washing Machines
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
My indesit tumble dryer idv65 runs for 10 mins and then trips the electric and stops
if its an old dryer its probably the motor thermostat heating up and shutting the motor down ,replace that or even the motor
Jan 14, 2013 | Dryers
How to access belt on indesit idv65 tumble dryer
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
Jun 22, 2012 | Dryers
Can anyone help me with my washing machine (aeg lavamat 66840 l).After choose a washing cycle and the timer displays 2.20 h , the washing cycle finishes in 1.45 h !?Any ideas?
HI HAVE YOUR PUMP FILTER CHECKED IF OK CHECK HEATING ELEMENT ..SEE IF ITS IN CIRCUIT.. THATS WHAT NORM HAPPENS IF THESE ARE NOT HAPPY.BET OF LUCK.
MARK 07779933829
Nov 22, 2011 | Washing Machines
I have a 6 station orbit timer and I have problem with station 2 odd days coming on again after station 4 odd days the time is set to come on at 6 am and run for 60 min an10 min after it shuts off to start...
I am somewhat confused about your station numbers. How many stations do you have? What is Ihappening with stations 1, 3, 5, 6?
Regardless, this is probably what is happening.
No matter how many stations you have, YOU ONLY PUT IN ONE START TIME. That one start time begins the cycle that starts with station 1 and proceeds to the other stations based on your station RUN times.
If you have one start time of 6:00 am, and a run time of 60 minutes for each zone, then
At 6:00 am station 1 starts.
at 7:00, station 1 shuts off & station 2 starts.
at 8:00, station 2 shuts and station 3 starts, etc.
You are not programming the individual start times for each station.
If you put in more than one start time, the timer remembers and will run all stations then go back and begin again and if there is a third start time, it will begin a third time.
Gary
Sep 02, 2011 | Orbit 57882 9 Station Super Dial...
My indesit dryer is IDV65, the drum is spinning but the dryer is not heating up and the clothes are still wet.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 05, 2011 | Indesit Dryers
Stuck on 6 min and wont finish the cyrcle.
if its not on sensa dry the timer is bad
Apr 22, 2010 | LG DLE2512W Electric Dryer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
