Need to take top off wdd960 so I can unlock door
Somehow the freezer door became locked and I can't figure out how to unlock it.
There is no lock on your refrigerator for either door. The lock/unlock button is only for the dispenser to keep small children from dispensing ice or water. If your door won't open it could be a few things. First, a package on one of the shelves dropped and is jamming the door on the inside. May require removal of the top hinge so you can tilt the door top forward and look inside to see what happened. Next, you may have one of the door hinges that actually broke and is keeping the door from opening. You will need to look close at both hinges but I would guess the bottom hinge would cause this more that the top since the door weight is all on the bottom hinge. The only thing that holds the doors closed is a magnetic gasket on most side by side models under normal conditions.
Mar 30, 2015 | Whirlpool Refrigerators
Whirlpool washer serial CSP262604220 control locked , wow do I cancel this ?
turn off the mains
wait till it clicks
if you cant get it open after 5 mins
you need to manualy open it
by taking the tops off {mains off slide the top of andreach down put you knee agaist the door push it in a you can manuver the door catch}
your machine prob needs either the vacume switch fixed
or after a long power off and it wont easily unlock
and you need to manually unlock it
then the door interlock has failed
you need too release the door and then replace the switch unit
Mar 04, 2015 | Whirlpool Washing Machines
Hotpoint washing machine wdd960 is leaking from underneath.
either tub has a leak or one of the hoses has a leak somewhere? if u remove the cabinet then run machine u can see and locate ur leak more easily? by the way a tub leak can be repaired some times with some water proof selant
Jan 09, 2015 | Hotpoint Washing Machines
Hotpoint wdd960
This is usually because there is water in pump which does not get drained over time. Leave the porthole door open from time to time to let the odour out. Make sure the laundry drain backflow has not dried up causing sewer smell to come through.
Run the washing machine empty using a packet of cleaning agent available from supermarket. see this site
http://www.hillmark.com.au/products/scalexplus.aspx
Apr 22, 2014 | Washing Machines
Door willnot unlock after wash is complete
switch is stuck. need to take the top off. and move the door lock to the side and open the door at same time make sure it is up plugged and has no power wile ding this. sometimes it can be easier and just turn the power off at the wall and wait 10min and it will be able to open. but if the switch has failed as they can do you need to do it the way at top of this. when open don't use until the door switch is fix as it will keep doing this on every wash.
Oct 06, 2013 | Asko W6021 Front Load Washer
Wdd960 f13 error code
you could have a problem with the fill valve,shut the water supply off,remove the hoses from the back of washer and mark them so you put them back the same way,stick the hoses into the washer or a bucket and turn the water on,if water comes out of hoses you'll know it's the washer and not the house water valve.if water comes out look into the washer valve where the hoses connect,if you see alot of junk on the screens change the water valve.i want to tell you that i haven't worked on this machine yet,i looked up your error code and it sounds like you're having water issues from what i've read,there's a tech sheet in the washer sometimes down near the bottom cover or taped onto the side wall,it will have all the error codes and tell you how to run the machine in a diagnostics mode to check everything in it,also next time you write in send the full model number off of the machine you're having problems with so whoever is trying to help you can look up your machine,usually you open the door and look around the opening where the door closes in and you should see a tag with the model and serial numbers.hope this helps,best thing to do is find the tech sheet and run it in diagnostics
Jun 23, 2013 | Washing Machines
Hotpoint wdd960 washer dryer error f05
f05 means blockage and cannot drain-switch off at mains to reset error-turn to drain if pump runs but dont drain filter in sump blocked/if no pump action then somthing is jammed inn pump
Nov 08, 2009 | Washing Machines
Can't Unlock oven doors after "self-Clean" maytag double oven
I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
Dec 22, 2008 | Maytag Kitchen Ranges
Oven door locks and un locks code F90
The F90 fault indicates that the maximum time allowed for oven door unlock was exceeded. The control attempted to unlock the door. The door lock motor or mechanism failed to unlock the door within the maximum amount of time it is allowed to be energized by the control board.
It is unlikely that you will be able to reset this fault code. You can try to completely disconnect electrical power and leave it off for 5 minutes. After reconnecting power, the fault code will probably reappear since the control will still detect that the oven door is locked. The only way to clear the fault code is to disassemble the range and repair or reset the oven door lock assembly. You will need a service technician to complete this repair.
Dec 16, 2008 | Kenmore 79013 Stainless Steel Gas Kitchen...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
