Question about Cell Phones
On my samsung gt-e2152 2nd card is always offline. on the side a button for changing connection of network.but it doesnt matter,2nd card shows offline.how can i repair it?
erone47
  • 458 Answers
SOURCE: My Nokia 3250 in "offline" mode.
The problem is with the sim card. try to remove the sim, clean it with a dry cloth and put it back in. if the problem is not solved, take back the sim to your network provider and get a replacement, asuming the sim is damaged
Posted on May 18, 2008
  • 4 Answers
SOURCE: Nokia offline
where did you bought your phone? if you bought it from a telecom's promo it means that your phone is locked to a single network provided only. you can ask a technician to have your phone OPENLINE for you to be able to use any kinds of sims.
if it's not the case, check the slot for sim and make sure that the sim is properly placed. restart it without the sim and then restart again but now with the sim.
Posted on Jul 01, 2008
SOURCE: have done hard reset on samsung j700 but still have network prblm
just go to network and select the band select 900 1800
Posted on May 16, 2009
aashum
SOURCE: My phone is always show offline mode.
sim ic jumper
Posted on Jul 03, 2009
  • 160 Answers
SOURCE: how can i access the
Make sure your internet setting are correct, you can get the setting from your network provide.
Posted on Feb 08, 2011
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Always shows "Printer offline" status (Mac OSX)
Have you installed the printer driver for the selected printer??
Oct 30, 2017 | Samsung Clp-325 Colour Laser Printer
Why gt s5570 doesnt showing simcard and always ask to insert simcard
Check whether the SIM CARD slot is working properly by insearting a different sim card if doesn't work then your sim card slot is corrupted...
May 26, 2014 | Samsung Galaxy GT-S5570
I cant get my wifi to work at all no matter where i am pulic with wireless or someone who has a router
Glad to help YOU!
I'd start by checking if your WLAN card was not DISABLED. To do so go
- right-click on MY COMPUTER > PROPERTIES > HARDWARE > DEVICE MANAGER and see what is showing you for Network Adapters.
If your Wi-Fi card appears to be valid, just right-click on it and select PROPERTIES then UPDATE DRIVER (also check if device is notified as working properly).
Second check if your Wi-Fi ON/OFF switch (it should be on your left side - or on your right side, just under the LEDs) is in ON position when you want to connect to a wireless network.
My best wishes!
PS: Try the both above and come back with extra-details if you still cannot connect!
Mar 16, 2011 | Computers & Internet
My c309 printer and fax photosmart premium is always offline and i cant print anything. how do i change it to online. I run win 7
If I am correct you are using it on wireless/network. If yes, you can try following steps.
On printer press Setup(wrench) button >>>> select Network >>>> select Wireless Setup Wizard >>>> This should show your network on printer >>>> Select your network and enter network password or wep key >>>> Printer should say "connected to network"
It will automatically go to online on computer now.
Dec 23, 2010 | HP Photosmart Premium C309A All-In-One...
PHONE IN OFFLINE MODE . hOW DO YOU CHANGE IT TO on line mode
Ok let me give you solution about this problem....
Offline mode is the mode in cell phones which barred your every calls sms and even your internet connection simply you can say that...
It stops all of your connection......and you can use only those things which do not need the connection or network.
So to deactivate this offline mode their is two way
1. You can restart your phone after inserting sim card and if the sim card is in good condition and readable then the cell phone will ask you wheather to continue in offline mode?
Just press no that is upper right button of your cell phone and it will be deactivated.
2. Just press on/off button gently and it will show you profile i.e. to select mode
General, silent, meeting etc. you can select any of them except offline mode.and again it will be in normal mode.i hope that it will help you,
By: Neuron
http://www.digixtream.blogspot.in
Jun 15, 2010 | Nokia E51 Cellular Phone
Wireless vgn-n130g i did wireless but it doent working can you help me how i take other software installer for wireless sony Thank you !
check is wi-fi driver install in device manager->network controller->network card names if it install close that on the right hand side there is a icon of network connection click on wireless ->refresh avil. network-> it show some connection select one of them u like click on connect button enter yr passkey you are now connected to your wifi if there are no network show that mean there some other problem rate my tips thank u
Mar 05, 2010 | Sony VAIO VGN-N130G/W Notebook
I keep tuning on my wireless internet on my dell lattitude d600 and my wireless internet wont come on it doesnt show anything wen i press fn and f2
check the error message when you try to search for your network. If it says it cannot find network in range and wireless zero configuration utility is turned off than click on start go to run and type : services.msc, click ok, on right hand side scroll the window to the bottom and you'll see wireless zero configuration >> double click on it >> change the start up type to automatic and click apply then change service to started and click on ok.
Afterwards check if you see your network name or else
click on start >> go to control panel >> double click on network and internet connections >> right click on wireless network connection >> click on properties and go to wireless tab >> check the box at the top that says use windows utility >> click on ok and than right click on wireless network connection and click view available wireless networks. It will show you your network name. click and connect to your network
try it!
Feb 22, 2010 | Dell Latitude D600 Notebook
Printer Offline Message
If your system is showing Printer Offline message, then you need to check the status of the printer in control panel. If it is offline then you need to set it online. The following steps will help:-
1) Click start -> Control Panel -> Hardware and Sound -> Select Printer.
2) If the printer is online it shows "Ready". and if the printer is offline, then it shows "offline".
3) Set the printer online if it is showing offline.
4) Now right click the printer and select "Use Printer Online".
5) The display should change to ready.
Note:- If still you are facing the issues, then update the printer driver or you can also take assistance from any tech support provider such as AskPCExperts. To know more you can also visit: http://www.askpcexperts.com.
Jan 07, 2010 | Epson Aculaser C1100 Printer
6630 offline
press the side button or check the phone's user profiles, there you will need to select the phone to connect online.
you will need to set your phone to become connected
Nov 22, 2008 | Nokia 6630 Cellular Phone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
