Question about Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper
I have another puncture on my front on my Rascal 302 le how do a get my front wheel off
    Scholar:
  • 61 Answers
I am assuming you are talking about the castor wheels. You just need to remove the center bolt/axle. You will need a 5mm and 6mm Allen wrench. Once you get the screw out of one side, you should be able to push the axle out and drop off the tire for maintenance. This is generally a solid tire.
Posted on Apr 19, 2014
I have to push joystick back to go forward. An forward to go back. Much faster in reverse too
if you look under the seat and see that there are little black switches, one of them maybe broken. if there are no switches on the seat post. then your joystick thinks you are a front wheel drive instead of a rear wheel drive chair. Someone with a programmer can reverse this. get ahold of these people at this link I give you to find a technician close to you.1-800-257-7955 or Mobility Parts and Service Official Rascal Parts Supplier
or http://www.meritsusa.com/
May 02, 2016 | Rascal 318 Electric Scooter
I have a puncture on my front wheel tyre on a rascal 302 le how do i get it off
Remove the axle and drop off the tire. Tools needed are a 5mm and 6 mm Allen wrench
Feb 10, 2014 | Electric Mobility Shoprider Electric Power...
Puncture in one of my front tyre how do l remove it
To remove wheel there is one center bolt in the middle of the wheel(13mm). The wheel is a split rim so on the inside of the wheel there is more 13mm nuts undo them and the wheel comes apart.(no need for tire levers)
Please find users manual for Rascal 329 LE disabled scooter
The following link may be helpful for the users manual for your rascal scooter:
http://www.rascalscooters.com/manuals/300_manual.pdf
You can also call the manufacturer and they will send you one. The manufacturer is
Electric mobility at 1-800-MOBILITY or 800-662-4548. Hope this helps.
Nov 22, 2010 | Electric Health & Beauty
I have a Rascal 245 Mobility Scooter which is 3 wheeled. How can I make it more stable than the little caster wheelers they use?
Obtaining a 4-wheeled front section is the best way to improve stability. The 3-wheeled front section on rascal 235 and 245 scooters easily detaches and interchanges with the 4-wheeled front sections(235 models are a little shorter (less legroom).
Sep 24, 2010 | Golden Technologies Golden CompanioN II -...
I have a 245 Rascal Scooter. I need to know if I can lower the seat?
most rascal 235 and 245 scooters come equiped with power seat height control. you turn the key to the left and then the throttle lever becomes the seat height controller. the seat motor is ditectly uuder front of seat post. if it will not run follow wires to see that they are plugged up good.
Jun 09, 2010 | Golden Technologies Golden CompanioN II -...
HAVE LE CODE ON SAMSUNG WF316LAS/XAA WASHER LE CODE AND BEEPS
LE is a water level issue.
- The part of the hose where the water level sensor is
located is damaged (punctured).
- The hose is clogged with foreign material.
- The hose is folded.
- Too much lubricant has been applied to the insertion
part of the air hose.
- Hose engagement error (disengaged)
- Part fault (Faulty internal soldering)
- The water level sensor terminal is disengaged.
- Main PBA fault.
Dec 19, 2009 | Samsung WF316BAC 3.79 cu.ft High...
I took front wheel off bike to fix puncture. i
Loosen up the hub nuts. Center the wheel between brake pads. Put something like a screw driver in the space between wheel and frame to keep the wheel centered and not moving as you tighten the nuts.
Oct 02, 2009 | Cycling
I have a puncture in my front wheel of my Suzuki FXR150 2001
Lift the front wheel, use jack or put something under the exhaust. Loosen the front wheel nut and pull out the bolt. Pull out the speedometer cap. Pull out the wheel. Now you got your front wheel off your bike. The rear wheel is harder to handle. You can bring the wheel to bike workshop or you can do it yourself provided that you got all the tools.
Mar 14, 2009 | 2001 Suzuki FXR 150
Electric Mobility Shoprider Electric Power Wheelchairs Scooters Trooper Logo
82 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
