Question about Toshiba Satellite L655-S5101 Laptop
Cant get to the system restore option
If you click repair system itll load files the go to microsoft logo then quickly black screen, if i try to go to safe more or laod last settings option itll display the files then stop and wont go any further
SOURCE: My Toshiba L300 satellite pro wont load up
USE A BOOT CD AND RECOVER THE FILE AND MAKE SCAN VIRUS
rapidshare.com/files/51117041/ERD-2007.rar
IF YOU HAVE SATA DISK DISABILITATE SATA IN BIOS... TRY....
Posted on May 08, 2009
mopar2009
  • 32 Answers
SOURCE: Cannot start up
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
Posted on Sep 15, 2009
naofrk
  • 35 Answers
SOURCE: how to repair satellite a215-S4807 black display?
your user profile may be corrupt. after turning on your laptop press F8. choose "last known good configuration" and see if that resolves the problem. if not, next choose "safemode". from safemode click "yes" to continue and restart the computer from the start menu. if this doesn't work, go back into safemode. click "no", and restore the computer to a early date when it was working.
Posted on Nov 18, 2009
  • 6771 Answers
SOURCE: Toshiba satelite l655 wont boot windows or safe mode
The hard drive has failed, or windows has corrupted files. If you made a backup cd installation disc that would be the next step to try and load windows, if no change! the hardware needs to be tested for possible replacement.
Posted on Apr 20, 2012
  • 6771 Answers
SOURCE: Toshiba stuck on start-up screen.
The windows files have been corrupted, I was hoping you might get into safe mode to try a system restore but your system will not allow it. If you can find your recovery disc a clean install is the best way to go. Try www.toshiba.com contact customer support about a replacement recovery disc.
Posted on Jul 21, 2012
Acer
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. if this hails to fix the problem http://support.microsoft.com/kb/307545/ restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download you could select the option start with command prompt you should be in DOS mode black screen type chkdsk/r/f which will scan for and attempt recovery any bad sectors and automatically fix any corrupt files on your hard drive you should have no input while chkdsk utility is in progress any input might further damage your hard drive
Apr 06, 2013 | Acer Aspire One Zg5
Screen goes blank after windows corporation logo
perhaps you need to reinstall the operating system,the system files might be corrupted because of power problem,and there's "windows loading files" thing,so the windows cannot go further because it cannot find some files while loading. do you need any help with installing operating system?
Aug 25, 2012 | Toshiba Satellite Pro L300 Notebook
My laptop won't start, stuck on black screen. i have been trying to start my gateway laptop andevery time the welcom finishs' running it defaults back to the black sreen. why is this?
This could mean that the copy of Windows installed in your computer is either corrupted or damage and reinstalling or repairing your Windows should fix the problem.
But try doing System Restore first on safe mode before doing a Windows reinstallation or repair to save you from loosing all you files in your computer.
To do system restore on safe mode:
1. Restart your computer and when the Dell Logo comes up and keep pressing F8 until an option shows
2. Use arrows to navigate then choose safe mode
3. Click start button then choose All programs or Program depending on the Windows installed in your computer
4. Click on System tools then choose System Restore
5. Follow the intructions on the System Restore windows on how to restore your machine back to a previous date before this issue happen.
6. Your computer will automatically restart after restore is done
If the safe mode doesnt work then your last option is to reinstall or repair your windows:
1. Press F1 to go to BIOS then change boot priority - make sure your DVD drive is the first boot
2. When your done changing boot sequence press F10 to save and exit
3. Insert you Windows CD and and a meesage will appear on a black scrren "Press and key to continue" press any key. Windows file will load and options for Repair or Installation will appear
4. Choose 1 of the option then follow the instruction (Installing a fresh copy of windows is recommended)
Hope this information will be helpful. Thank you for using FIXYA.
Apr 16, 2011 | Gateway Computers & Internet
I have a dell inspiron 1545 and i need to format the hard drive how do i do it
Hi there are 2 Ways to Do it. You Choose .If this is the first time you are trying to do it on this 1545 if it was never formatted in the past use Method 1 if it was already formatted once in the past then use method 2 because method 1 wont be available. Method 2 is lengthy process.
Method 1 : Restore the computer's software to original condition.
Using Dell Factory Image Restore in Windows Vista
new_notice.jpg Notice: Restoring the original factory image erases ALL existing data. This includes files, folders, programs, drivers, E-mails, photos. Before performing a PC Restore, back up all personal files. If you do not back up your personal files, the data will be lost.
1 Turn on the computer.
2 As the computer starts, press on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press before the Windows logo appears on the screen. If you press after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
3 Press the on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press .
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Dell Factory Image Restore.
7 In the Dell Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
9 Click Next.
The computer is restored to the default factory configuration.
10 When the restore operation is completed, click Finish to restart the computer.
The software is now installed as it was when the computer was first received.
__________________________________________________________________________________
Method 2: Reinstall the operating system from the OS Setup Disk. For Windows Vista
1 Insert the Windows Install DVD into the DVD drive, and then restart your computer. When the message Press any key to boot from the CD or DVD ... appears, press a key to continue booting to the DVD.
new_note.jpg Note: If the computer does not boot to DVD, follow these instructions. If it does boot to DVD ignore this note.
1 Power on the system and watch for the Dell logo to appear.
2 When the Dell logo appears, press the key to load the Boot Menu. If the menu does not appear, restart the system and tap several times at the Dell logo screen.
3 When the Boot Menu appears, highlight the CD/DVD drive (listed as "CDROM", "CD/DVD" or "CD/DVD/CD-RW") entry from the list and press .
2 After Vista Setup loads, confirm the Language, Time, Currency and Keyboard Method settings are correct then click Next.
3 On the Windows Vista Installation page, click Install Now.
4 Review the terms and click I accept the license terms to proceed.
5 On the Which type of installation do you want? window, click Custom (advanced).
6 On the Where do you want to install Windows window, make sure the largest Primary Partition is selected then click Next. If the Primary partition has 0GB free, there should be a separate line for Unallocated Space. Select this unallocated space and click Next.
new_note.jpg Note: Your computer will restart several times during installation.
7 When the Setup window appears, select a user name, password, and picture for your user account.
8 On the next couple of screens, use the default or recommended settings prompted and click Next until you see the Time & Date screen.
9 Click to select your time zone then click Next.
10 After the Thank You message appears, click Start.
If you need more details go to this page Source from Dell support site
How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Feb 04, 2011 | Computers & Internet
Mi inspiron 6000 went into hybernation by itself.. now when i turn it on i got a black screen and only the mouse move what can i do?
We wish you a Merry Christmas and a Happy New Year.
Its a Black screen error.
Which is the operating system?
When does this happen,as soon as you start the computer or after the windows logo?
Access the link below and try to perform a starup repair, as it might help us to fix the issue.
http://support.microsoft.com/kb/925810
If the issue persists after performing the startup repair, try to perform a system restore.
1. Insert the installation disc.
Note The computer must be configured to start from a CD or from a DVD. For information about how to configure the computer to start from a CD or from a DVD, see the information that came with the computer.
2. Restart the computer. To do this, click Start , click the arrow next to the Lock button, and then click Restart .
Note If you cannot restart the computer by using this method, use the power button to turn off the computer. Then, turn the computer back on.
3. Set your language preference, and then click Next .
Note In most cases, the startup repair process starts automatically, and you do not have the option to select it in the System Recovery Options menu.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, click the operating system that you want to repair, and then click Next.
6. In the System Recovery Options menu, click System Restore.
7. In the System Restore dialog box, click Choose a different restore point, and then click Next.
8. In the list of restore points, click a restore point that was created before you began to experience the issue, and then click Next.
Click Finish.
The computer restarts, and the system files and settings are returned to the state that they were in at the time that the restore point was created.
Post back if non of the above works.
Hope this helps.
Cheers!!
Jan 01, 2011 | Dell Inspiron 6000 Notebook
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
It's start off good then after Microsoft XP Logo shows it restarts by itself.
your windows xp is serious damage so if you reinstall windows xp again it will work just fine thanks
Oct 27, 2009 | HP Compaq dc5000 PC Desktop
Loads dell logo then goes to load xp then screen goes blank
Try going into safe mode if you can by pressing the F8 key when you first turn on the laptop.
If you get into safe mode then go into the system configuration utility underneath the system tools folder. Click on the startup tab and then click on the button that says disable all. This will keep programs from loading when windows boots up. Reboot the computer and see if you can get into windows normally. If you can then you know its a program thats causing the problem. If you still can't get into windows normally then you'll have to wipe out the drive and restore your computer back to factory default.
You also will have to do this if you can't get into safe mode as well.
May 04, 2009 | Computers & Internet
Toshiba Satellite L655-S5101 Laptop Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
