Question about HP Dandelion Breeze Laptop
How do i get it 2 work n turn on again??
I removed battery put back in held power button down n it still wont turn on or anything
    New Friend:
  • 62 Answers
Is the battery charged?
Maybe the battery is dead from the power cord having a short in it.
Will it turn on when the power cord is connected with the battery in it?
Posted on Feb 10, 2014
Testimonial: "no laptop wont turn on with battery in it n connected 2 powercord. dont believe theres short in power cord"
  • 5 more comments
  • Casper Crowley
    Casper Crowley Feb 10, 2014
    DO any leds turn on wile its plugged in like charging led oranything happen when you press the power button?
  • kara kirkpatrick
    kara kirkpatrick Feb 11, 2014
    no led lights turn on nothing happens when i press power button
  • Casper Crowley
    Casper Crowley Feb 11, 2014
    My guess was maybe the power button, but if you dont get any lights at all when its plugged in the motherboard and/or processor may be fried. A suggestion would be to buy an external hard drive case, take out your hard drive from your laptop, put it in the case, then connect it to another computer. I would do this so you can make sure you still have all your stuff and can back it up.
  • Casper Crowley
    http://www.ebay.com/itm/like/36078098740...
  • Casper Crowley
    Thats a link to a case
  • kara kirkpatrick
    thank you
  • Casper Crowley
    Your welcome sorry I didn't have more for you.
4 Suggested Answers
  • 89 Answers
SOURCE: Black Screen / Computer Stays in Standby Mode
Completely remove the battery and unplug the power cord for a few minutes. Reinsert battery and power up. You can also hit F8 when starting and see if you can boot into safe mode.
Posted on Sep 06, 2007
benwabnick
  • 2404 Answers
SOURCE: HP Pavilion laptop went black as I was surfing
Okay if you have lights then I would suggest with the laptop turned off, try reseating the memory then only hook up the AC adaptor with the battery out and see if you get video. If that doesn't work then try putting the memory into another slot and trying the process again. Also make sure there is no dust or dirt on the memory or in the slots. A quick blow of a can of air softly can do the trick to make sure things are clean on the memory and the slots.
If after this you still have no video and the hard drive light is not flickering like its trying to load windows then your motherboard is bad.
Posted on Feb 09, 2009
  • 111 Answers
SOURCE: HP 530 Laptop, NO Power
Um apart from growling at the dog lol you will probably need a new keyboard section.
Posted on Apr 26, 2009
I have an alcatel fierce one touch phone just went black? Fully charged.wont do anything? Help please!
Do the one two three method. While the phone is still on, remove the battery. Once it is removed, hold down the power button for ONE minute. This will drain any remaining power with the battery removed. After one minute of holding down the power button, replace the battery and see if it is still black, if it is, repeat only this time hold that power button down for a full TWO minutes and again put the battery back in and see if that fixes it, if it doesn't then do the same for a full THREE minutes. Basically you need to drain any remaining power from the phone before putting the battery back in to fix the problem. Hopefully this will fix your problem.
Jan 09, 2017 | Alcatel Cell Phones
My alcatel fierce just went black. Fully charged, wont do anything?
Okay my sister had her tablet she turned it on and it froze at the go screen. So I pushed and held down. The power button and it turned off, and then I don't know why I pressed the reset button but it...
Do a factory reset. Remove all power including internal battery. Let the unit discharge completely. Plug into external power supply and try to start up. If it starts. shut down, put the external cord out , replace internal battery, and recharge for an hour. Now try a strat from the internal batter. If it fails, that s the problem.
Feb 03, 2015 | Tablets & eReaders
Asus wont start up
Put a bit of more pressure on the power button and move your finger around it a bit. It's possible the button could have dislocated. If it does not turn on, then it could be a problem with your laptop's motherboard, or something else inside preventing it from powering on.
and try :-
Remove the power supply, and then take out the battery.
Hold down the power button for 15 to 30 seconds...then put the battery back in and plug the power supply in.
Now press the power button again.
Jul 08, 2013 | Computers & Internet
My usb overheated and now wont light up and let me see my files
This is WORKED FOR ME!--->I turned off my computer than unplugged cable and took out battery, held down power button for 1-2mins and than put everything back in (battery and charger) and tried to start it...the screen was still black. I than turned it off again, than pressed ESC, while holding down ESC I pressed and held power button until it briefly turned on and back off. Than I let go of both the buttons and pressed power back on and VOILA the screen came back on. Make sure your charger isn't loose, and than you're aren't surging too much power through the outlets-sometimes these can make the screen black too.
Hope this helps others out there, I have an old Toshiba Satellite running on Windows Vista
Jul 27, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
Cant get Y values when i type in X values in table
Well first of all you can try to reset your calculator, just follow the below steps to know how to reset it -
1. Turn off your TI-83 Plus.
2. Open the battery panel on the back of the calculator and remove one of the AAA batteries. Keep this battery handy, as you'll need it again.
3. Press the "Clear" button, and keep it held down.
4. Put the battery back in and turn on the calculator, with the "Clear" button still held down. When the calculator's screen displays the message "RAM Cleared," release the "Clear" button.
5. Remove one of the calculator's batteries again. This time, hold down the "Del" key.
6. Reinsert the battery and turn on the calculator. Release the "Del" key when the screen reads "Waiting...Please install calculator software now."
7. Use the TI Connectivity cable to connect your calculator to your computer. Run the TI Connect software to reinstall the calculator's operating system. If you don't have an up-to-date copy of TI Connect, see Resources.
8. Turn off the calculator and disconnect the TI Connectivity cable. Remove the AAA batteries, as well as the small, circular lithium battery.
9. Wait five minutes before putting the batteries back in. Turn on your calculator.
Hope it helps ..........
Good Luck!!
Thanks
Jan 06, 2010 | Texas Instruments TI-83 Plus Calculator
WHEN I TURN ON MY asus pc 701sd IT LIGHTS UP THE SCREEN FLASHES FOR A 1/2 SEC AND DONT TURN ON I TRYED EVERYTHING TURNED IT ON AND OFF TOOK THE BATTERY OFF I WAS JUST USING IT LIKE 1 HOUR AGO AND OPENED IT...
try removing the battery, and holding the power button down for 1 minute( with the computer unplugged of course) - put the battery back in and try to power it on again. this may or may not help
Oct 31, 2009 | ASUS Eee PC 701SD
My mp3 player is frozen
just hold the power button until it turns off. It worked for me.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
Left connected when shutdown
This happens to me every other time I connect to charge the battery. I remove the screws on the back and remove and reinstall the battery then back to normal but still without a full charge.
Apr 12, 2007 | SanDisk Sansa e260 MP3 Player
HP Dandelion Breeze Laptop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
