Question about Caleffi 573009A Backflow Preventor and AutoFill Combo Valve
Where is Caleffi 573009A Pre-adjustavle filling unit installed on a Dunkirk DXL-200? The user manual shows it on the return (bottom) of the boiler. But the Dunkirk diagram shows the water inlet and f
Water inlet may be installed in wrong place on Dunkirk DXL-200. Circulator pump is on supply side (top) pulling hot water from the boiler.
I've got a Worcester Bosch boiler had a leak In the pipe On the landing so a friend emptied the boiler an I fixed the pipe but I don't know how to refill the boiler
Can you get the manual online? You have the Manufacturer info so you probably have the model number too. I found a manual on Manuals.com for my boiler so they may have yours too which will hopefully have some information on filling boiler although I realize each installation is somewhat different but that's why it's difficult to answer you question. Usually there is a manual pressure valve that regulates the water pressure in the boiler which is usually pretty low...like less than 20 lbs. The manual should tell you the pressure as well. But this pressure valve has a flip handle that comes off the cold water line to the boiler to do just what you want to do...refill it with water. When refilling the boiler (if you find the valve, you may have to purge the air out of the lines which there is a whole other process for. But you shouldn't allow cold water into a hot boiler...it could crack it when the cold water hits the hot cast iron. So make sure the boiler is cool when filling it up.
Now go try to find that manual!
Nov 22, 2015 | Bosch Water Heaters
Why can't i fill my boiler
You didn't specify what kind of boiler you have. Some low pressure steam boilers have a manual fill valve as well as an automatic float switch valve. Hot water boilers have a pressure reducing valve that constantly monitor the boiler pressure and maintain 12 to 18 PSI for the safety of the boiler. If the boiler runs out of water there is a good chance it will rupture and become unrepairable. If you are saying your boiler won't fill, and its a hot water boiler, the pressure reducing valve is probably blocked with sediment and needs replacement. The valve is in the water line that feeds directly into the boiler return line from city water. Hope this helps.
Oct 01, 2014 | Water Heaters
Installed a year-and-a-half ago, problems so far: thermostat replaced on hot water tank within one month of installation, one pump replaced, leaking plug in the front of boiler with Dunkirk rep never
Its probably time for small claims court and a new company to install good equipment. Have a couple different companies/contractors give an estimate and possibly expert advice/witness you would then be able to use in court so you can get reimbursed from a bad company. Hope it all works out.
Apr 20, 2013 | Dunkirk Q90-75 Quantum High Efficiency...
Thanks for that mike, it is a worcester bosch combi 24cdi heating and water can stay on for an hour then everything goes off and the red light flashes. it will come straight back on when reset, but then...
Check the pressure reading, should be about 1 bar when system is cold. Various models in the range of 24cdi. If you do not have a manual, go to,
http://www.centralheating.co.uk/Boiler-Manuals/worcester-bosch-boiler-manuals/worcester-bosch-discontinued-boiler-manuals.
Get the manual for your unit, to wards the end of install manual it has a fault finder, Also has a basic 1 in the user manual. Number of flashes how fast the light flashes which one flashing can all mean different, So get the manual and check, Some parts are easy to fix, as long as you do not touch the gas side the rest is plumbing. Come back if needed.
Mar 05, 2013 | Water Heaters
Boiler Programmer user manual
contat worcester bosch they will be happy to send you a manual as you already have there product installed.
Dec 11, 2012 | Water Heaters
New Vaillant 360 eco plus boiler, takes almost 3/4s an hour for rads to come up to a decent temp. Hot water is fine. Called out install Engineer who is an excellent tradesman but he says everything
We have just had our old system boiler replaced with a vaillant ecotec plus 837 and sounds like a similar working operation to ours. At first I was a little concerned,but I was told by our installer that he was told by vaillant that these very latest boilers size the system on start up for about 10 mins, then take temperature to target flow which you set boiler at. So even by setting target flow temperature very high you still get the initial sizing cycle, which ours was about 30-35c temp. These boilers seem to run biased for efficiency as after a while they modulate the boiler burner down and the radiators run more on the side of warm than really hot like the old type boilers. You also get better efficiency as at lower temperature the boiler condenses better. You will also find you get a more constant temperature in your home rather than over shoots. I was concerned at first, shame there was no info/explanation in user manual as people do need to know that this is normal operation. We are used to ours now, took a month and by the way these boilers can make a creaking noise but was told this normal expansion/ contraction but annoying when sited in bedroom cupboard. Best of luck!
Oct 27, 2012 | Water Heaters
I need to fill up my combi boiler
find filler loop which should be near boiler it is connected to the main and connects to flow or return on your boiler and only fill to 1and a half millibars which is a dial on your boiler
Nov 14, 2011 | Water Heaters
My pressure is low on my halstead eden cbx24 boiler, i can find the loop to fill it up but dont know where to put the water in, can anyone help?
Do you have a sight glass that shows water level in boiler on this loop? If so is it marked where normal water level is supposed to be? There should be a water line connected to boiler with a valve on it. This will be a manually operated valve unless it has auto fill control. Locate this valve and slowly add water until level in sight glass is back where it should be,then shut valve.While you are doing this the boiler should be at operating temperature because hot water expands and you don't want to overfill. There should be a temperature and pressure relief valve on top of your boiler to prevent unsafe conditions but I wouldn't count on it working properly if it is very old. My main concern is for your safety so if you are unsure of something don't do it. If your boiler has a automatic water make-up on it then you need to have a service tech. find out if it's not working,and repair or replace it. I hope this helps you. Thanks
Nov 24, 2010 | Water Heaters
Caleffi 573009A Backflow Preventor and AutoFill Combo Valve Logo
24 people viewed this question
Top Caleffi Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Caleffi Water Heater Expert? Answer questions, earn points and help others
