Question about Casio fx-300ES Calculator
How make your casio fx-300es divide decimals - Casio fx-300ES Calculator
SOURCE: How do I get decimal answers
I had the same problem. To change the output to decimals, do the following:
Go to Math mode, then SHIFT, MODE (set-up), 2 (lineIO). This will cause answers to show in decimal format. I hope this helps.
I was able to find a manual at: http://www.generalmanual.com/Calculators/Casio-FX-300ES-Scientific-Financial-Calculator.htm
Posted on Jan 25, 2008
SOURCE: When I divide, it turns the answer into a fraction. How do I get back so the answer will be a decimal?
Press the S<>D key, (located right above "DEL"). This will shift the answer from fraction to decimal. This sounds like a pain but having both functions available can be a big plus.
Posted on May 20, 2009
  • 41 Answers
SOURCE: how to divide numbers in to decimals with out it
'shift' 'mode' 'v' (down-arrow) '4' (select 'Disp') '1' (select 'Dot')
Posted on Sep 15, 2009
  • 7993 Answers
SOURCE: Casio fx-300ES Default answer readout?
Generally, MathIO gives results in fractions or radicals. But sometimes it does not. I tried multiplying or dividing fractions or radicals by integer numbers, and once in while I got a decimal result and was unable to cast it into a fraction or a radical. I was not able to find the pattern.
In lineIO you only get decimal results.
What can one tell you that you cannot determine for yourself? If you appreciate the functionalities of the MathIO, it seems like an insignificant price to pay to press ONE button to switch between displays. It needs to be done ONLY once, for the last result one wants to record.
Your calculator, Your rules. But sometimes one cannot eat the cake and have it too.
Posted on Oct 21, 2009
  • 7993 Answers
SOURCE: CASIO fx-300ES
Storing
  1. To store numerical values in the variables A,B,C,D,X,Y and M you use the [SHIFT][RCL] key combination to access the (STOre) function.
  2. In what follows [ key] is the physical key and (key) is the SHIFTED key
  3. ex: store the value 13 in variable A
  4. 13 [SHIFT][RCL] (STORE) [(-)] (A)
  5. The calculator displays 13 --> A on top line and 13.000.. on bottom line.
Recalling
  • To recall a value stored in a variable ex: recall value stored in variable A
  • Press [RCL][(-)] (A)
  • Calculator displays A on top line and 13 on bottom line.
If you need to use the variables A,B,C,D,X,Y, and the = sign to create an expression to be solved with the solve( function you must press the [ALPHA] key
=: [ALPHA] [CALC](=)
A: [ALPHA][(-)] (A)
B: [ALPHA][ 0 ' "] (B)
X: [ALPHA][ ) ] (X)
Y:[ALPHA][S<=>D] (Y)
etc.
Posted on Jan 15, 2010
When i try and divide it just gives me the answer back as a fraction
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select the LineIO mode.
Oct 09, 2010 | Casio fx-300ES Calculator
When I type 3 divided by 2 and hit enter, I get a fraction. How do I get the decimal instead?
To convert a single result to decimal, press the SD key. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
Sep 17, 2010 | Casio fx-300ES Calculator
Whenever i try to divide, the calculator gives me a fraction as an answer
To convert a single result to decimal, press SD. To have all results come out in decimal, press SHIFT MODE 2 to select LineIO mode.
My fx-300ES calculator keeps giving me a fraction wheniever i try to divide. help me please!
To convert a single result to decimal, press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Oct 20, 2009 | Casio fx-300ES Calculator
How to divide numbers in to decimals with out it turning into a fraction on the fx-300es?
Sep 09, 2009 | Casio fx-300ES Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
Nov 06, 2007 | Casio fx-300ES Calculator
Casio fx-300ES Calculator Logo
19 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
