Question about Clothing Accessories
THE LENS HAS COME AWAY FROM THE ARM
LACOSTE
Where can I buy a replacement watch strap for my Lacoste 2500g watch?
Any good watch shop should be able to fit a band to any watch
Jan 28, 2015 | Lacoste Watches
My lens keeps popping out. Is there somewhere I can send to get repaired.
You might be able to take them back to the shop to get them repaired if they are faulty (:
Apr 26, 2011 | Lacoste Clothing Accessories
I need a replacement band for my lacoste watch model 3530G
Contact Lacoste at: (309) 692-2837 use extension 508 for the parts department.
Jan 19, 2011 | Watches
Regrding Olympus Stylus 500.. When turned on the lens cover opens half way twice then closes with a green flashing light and beeping sound.
Have just solved similar problem with mine. Problem turned out to be that the lens cover was very slightly dented in. It didn't really look dented at all, but just wasn't quite symmetrical and was a bit more recessed on the side away from the shutter button. This was causing it to rub on the case when it tried to slide. (Mine had been not sliding completely shut for a while before it stopped opening properly too).
To fix it I undid two small cross head screws which let the front panel be prised off. On mine, with the front panel off, the lens and lens cover mechanism all worked perfectly, as the problem was that the lens cover was rubbing on the front panel. If yours is still broken with the front panel removed, then your problem is not the same as mine...
I used a small screwdriver to push out the metal bar on which the top of the lens cover slides, pushing on the right hand end of the bar to slide it left and out through the USB connector compartment door. That lets the top of the cover come off the bar and move freely. To take the cover off, it has to be detached from the arm which moves it. There is a pivot trapped in a slot in the arm, but once the cover is off the bar at the top, it can be moved down so that the pivot reaches the bigger hole at the bottom end of the slot in the arm. This lets the whole lens cover come off the camera.
I then used a screwdriver to gently push out the middle of the cover until its shape was more symmetrical. (I'm not sure a screwdriver was ideal for this, as there are now tiny lumps in the cover where I was pushing it).
Putting it back together was the reverse of taking it apart, although you can test whether it's fixed or not before doing up the screws holding the front panel on.
Apr 28, 2010 | Olympus ? Stylus 500 Digital Camera
How to remove rear wiper arm from 2005 mazda
if there is a nut in the middle at the base of the arm remove the nut if there is no nut then lift the wiper arm away from the window and you will see a small tab that will pull away from the base of the arm pull this away and hold it while you let the wiper back down the wiper will hold the arm up and lock the tab out now gently pry or pull the arm off
Jan 11, 2010 | 2005 Mazda 6
My Panasonic PT-AX1000U projector has a problem with automatically shutting off after about 30 secs. I've read on the avs forum that this is a problem with the iris. Can you help?
take off light cover take out light there will be the iris arm on left hand side of lens put a small dab of oil on q tip very small amount put it on arm stay away from lens at all time use a small tool to move arm up and down a few times until it unfreeze`s that should help you out if not it could be the timer on bulb if so reset bulb time by going to option bulb time and hold down center key on remote for 3 seconds hope this helps
Nov 19, 2008 | Televison & Video
Won't load
My player was doing the same thing and I noticed that the lens arm was stuck near where the disc snaps into place. I gently pushed the arm away from the center (being careful not to touch the lens). I restarted the dvd player and put a disc in...started right away.
Aug 13, 2008 | Sony DVP-FX810 Portable DVD Player
Clothing Accessories Logo
132 people viewed this question
Top Clothing Accessories Experts
Da Doc
ray gallant
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
