Question about Refrigerators
Fridge & freezer not quite cold enough
We recently given a used KitchenAid KSRS25ILSS01. It was working/running when we went to pick it up, although it was empty and we didn't check the inside temp it 'felt' cool/cold. We brought it home, cleaned it up and plugged it no. Powered up but wouldn't cool. Determined the compressor wasn't coming on (it was before we brought it home). Replaced the start components. Compressor came on unit started to cool. Fast forward to 2 weeks later - neither the fridge or freezer have ever gotten quite cool enough. This unit has a digital temp setting, we have the freezer set at zero and fridge at 33 - both are the lowest settings. The freezer is about 8 degrees and the fridge is at 38-40. Nothing blocking any of the vents. The fan in the back of the unit next to the compressor is running. There is air flowing in both the fridge and freezer. There is no ice build up on the coils in the back of the freezer. Ideas? Thanks in advance!
4 Suggested Answers
  • 2920 Answers
SOURCE: Fridge not cooling down stays at 68 degrees
you may be low on freon..thats one thing about fridges if you are low one side will still stay cold while the other side gets warm
Posted on Jan 12, 2009
  • 17 Answers
SOURCE: ice build up on coil inside freezer
it can be two things the refrgerator probably has a small refrigerant leak therefore it ices up, or the defrosting heater on the begining of the coil is faulty.
Posted on Feb 10, 2009
sekjr
  • 3 Answers
SOURCE: Freezer cold not frozen, fridge cool but not cold enough.
Is the refrig running constantly? and still can't get to 0deg???
You say it's 30deg in there! I assume you are using a thermometer IN the freezer. Is the fan in there running (you can hear it). If it is, and you say you aren't cold enough, you lost freon...
Posted on Aug 16, 2012
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
I have a kitchenaid superba ksrs25ilwh side by side fridge. The freezer is working fine but the fridge wont get cold enough even at the lowest temp
check the damper vent door for proper opening and closing as if this door is frozen shut or broken and jammed it cant open to let cold air in from freezer it will be behind a plastic grille between the freezer and fridge compartments and you should hear a fan in there running to move cold air too
Jul 02, 2011 | Refrigerators
Fridge side not getting cool, freezer works great
is the fan running in the freezer?.
is ther ice build up on the back wall of the freezer?
check fridge control, set midway, same with freezer control
Jul 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer isn't staying cold
What is the solution? What can we do to engage the refrig. again?
Mar 31, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Jun 07, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Fridge not getting cold enough
listen for the compressor running in the back at the bottom. when you hear that running, open the freezer section. do you hear a fan blowing inside the freezer? if not, the evaporator fan motor is jammed with ice build-up or it's bad. hope this helps.
Nov 01, 2007 | KitchenAid Superba Architect KSCS25INSS...
Superba kitchenaid fridge not very cold, freezer is fine
do you have any frost build up it the freezer back wall... fan blowing in freezer and in back ...condeser coils clean... if all the above is ok ...must have temp. sensor or themostate cold control problem
Sep 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
