Question about Memorex Telex 1174 Communication Controller/terminal 1174-90r 900281-102
What direction does the front fan on a memorex 1174 face?
    Novelist:
  • 242 Answers
Out the front.. in the back...
Posted on Dec 04, 2014
Which way do I insert Memorex lens cleaner for DVD player. Instructions don't say which way to put it in - shiny side toward or away from me? Thanks.
You insert the lens cleaner disc like any CD/DVD. For the 32LA30RQD, the shiny reflective side needs to face the front of the TV. See page 32 (page 33 of the PDF) of the manual. The manual is available from Sears Parts Direct on the product page: https://www.searspartsdirect.com/partsdirect/user-manuals/32LA30RQD-Rca-Parts-LCDTV-manual . The direct link to download the manual is https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L1003503.pdf .
I hope this helps.
Mar 23, 2018 | RCA Televison & Video
Want to get information on fan with serial # 208 KL? It is a large teal fan with 2 sets of fan blades one facing forward on the bottom and one facing the rear on top.
your best bet is to go directly to Westinghouse, the divison should be marked in the id tag on the fan along with model number.
remember, you need the model, not serial number, but having both on hand when calling is useful.
Apr 03, 2016 | Westinghouse Dryers
What is 1174 litres to cubic inches ?
1174 L X 61.0237 CU IN =7164.CU INS +.182
Apr 06, 2015 | Cars & Trucks
What direction does the fron fan face?
pushes the air out the front of the unit.. does NOT draw air into the unit from the front.
Feb 10, 2014 | Memorex Telex 1174 Communication...
Maza 323 radiator fan rotating direction
the direction of fan rotation will be on the motor body but check that th curved edge ( leading edge) of the fan blade is facing the radiator and that air is being pulled through th radiator. THe motors are dc operation and can spin in both directions and the fans themselves are made to fit in front of the radiator( a/c fan) and blow air through the radiator. So checking these points is necessary
Jan 19, 2013 | Mazda 323 Cars & Trucks
Memorex Dvd Remote Codes
Hello
Setup codes for Memorex DVD with Direct TV [TC RC32] universal remote are>
20695, 20831, 21270
OK.
Oct 31, 2011 | Memorex MVD2022 DVD Player
May i know the rotation of the two auxillary fan along the radiator to reduced the heat on it
The fans can spin in either direction based on how the fan blade is position. If you're worried about the fan facing the right direction here's how to verify it. When the fan is on it is suppose to pull the air through the radiator and pushing it out into the engine compartment. Basically the fan helps more air come into the front of the car which in return cools down the radiator. So just check which way the air is being sucked in and pushed out, the outwards air should be going in the direction towards the rear of the vehicle. If you have any more questions please let me know.
Mar 25, 2011 | 1996 Nissan Maxima
The cooling fan on the driver side of the radiator does not work i just put a new one where the water hose side is and now it runs but the other one does not. I put one new thermostat and one new fan...
One of the fans is for your radiator and the other is your condenser fan (for your air conditioning). The condenser fan starts at a higher temp than your radiator fan.
To test the condenser fan (the one on the right side, facing the car) unplug the electrical connector at the motor and use jumper wires to connect the fan directly to the battery. If it runs, check the fuses (engine compartment far upper left as you face the car), then the relay (right front corner of the engine compartment as you face it). The radiator fan typically engages between 189 and 199 degrees, but the condenser fan typically engages between 217 and 232 degrees. In other words they don't necessarily run at the same time. First of all, try letting the car run until the engine is warm WITH the ac running. If the condenser far does not run, then go through the checking procedure.
I hope this gets you started on a fix.
Oct 22, 2009 | 1995 Honda Accord
Just wondering which way the fans in an Asus barebone desktop vintage-ph1 should face and the direction they sould blow at the back of the desktop.
They should _push_ the HOT air "out" of the inside of the case.
A fan at the FRONT of a case should _pull_ air into the case.
The fan inside the power-supply always _pushes_ hot air out of the interior.
Sep 18, 2009 | ASUS Computers & Internet
Brand new one won't open
try to put needle to small hole on front face of drive, but I recommend you to take warranty and get new drive, sometimes you buy faulty new things, that is normal, when almost every hardware is made in China...
Jul 10, 2009 | Memorex (32023244) CD-RW/DVD-ROM Combo...
Memorex Telex 1174 Communication Controller/terminal 1174-90r 900281-102 Logo
112 people viewed this question
Top Memorex Computers & Internet Experts
Jax Planet
Jax Planet
Jose Velazquez
Jose Velazquez
Gbenga
Are you a Memorex Computer and Internet Expert? Answer questions, earn points and help others
